SIP Vicious Protection
Todd Bruner
Hello:
We are starting to get more and more SIP Vicious scans.  Today, we received a scan and now when some (but not all) of our phones dial extension 100, instead of "To: 100" we see "To: sipvicious".
I understand most SIPV scans are attempts to enumerate VOIP systems for potential exploitation with the end goal often being using the switch to dial out at no cost to the attacker.  Listed below are the things I'm checking, since the owner and staff are freaking out a bit:
  • The CDR records (nothing suspicious there)
  • The VOIP trunk provider CDR logs (nothing suspicious there)
  • System Logs (nothing suspicious, but do not go back to the timeframe of the scan)
So I have a couple of questions:
1.  Why is "sipvicious" showing  up when a  user dials 100?  (I've looked through all config options on UC320W but didn't see anything amiss)
2.  Are there known sip vulnerabilities in firmware 2.3.2(6)?
3.  Are there settings in the UC320W that would help mitigate these SIP Scans?
Thank you for help,
Todd
mainkiller12
I am facing this problem too.
Can some one advise if using Cisco Firepower can fix those scan?
