SPA303 problem with https XML Applications
I'm trying to load a simple xml from https://192.168.1.21/test/menu.xml and it doesn't work.
If I load the same url from http it does work, what is the problem with https?
PS: Syslog is attached
PS2: More info here.
17 Replies 17
The LAN use the DNS from the telephony/internet provider, it would be annoying to set a local DNS server for only a single entry.
The only clients will be phones, Firefox and Chrome.
Firefox and Chrome can use the server perfectly from both IP (https://192.168.1.21/) and Windows computer name (https://reception/) and certificate validate perfectly in both cases using SNA so Subject is useless in these cases.
The problem of the phone is that it cannot access
https://reception/
also from normal http.
You are using technology (SSL) known to work better with DNS names, so for the sake of reliability, you should consider to have working one.
Just my recommendation. The final decision is sovereignty of particular responsible person.
https://reception/
No way to work as long as there's no DNS server willing to resolve reception name into IP address.
Well, I cannot expect it supporting a Windows workgroup.
I have to thought about it.
But besides that it still would be nice to have a complete SNA support.
