Hello.I am having trouble finding int fa0/1/8 physically on the uc520. I see 0/1/0 through 0/1/7...I could not find a diagram showing me that.Thank you for your assistance.Dave
I have an SPA232 with a couple of SPA302 handsets. I want to add the blind transfer and remove the regular transfer.I found the setting (Blind Attn-Xfer Enable) in the 232's web admin and enabled it. After doing a firmware update the handsets picke...
Hi, SPA3102 doesn't receive IP from DHCP and still flashing signal LED. I can access it via http and rebooted it several times via phone and 2 times flashed the newest firmware but all this for nothing - LED is blinking all the time.Please help me.
Does anyone have any experience with configuring the SPA 3102 with the Ooma Telo devise. I have been around and around on this with no luck. I have been able to get into my 3102 ip address fine, but I need a proxy server to configure the 3102 with my...
Hello, we have 10 users in our network and we have 4 FXO port and lines connected to them, we would like to implement this on UC540 below; 2 users will have access to FXO port 13 users will have access to FXO port 23 users will have access to FXO por...
SPA303-G1 not booting. Tried with multiple other power supply units and outlets with no luck, the power supply unit that was originally used on this device does work on other phones. Any suggestions?Also an off topic question: We have quite a few ...
Just upgraded my UC520 to the latest sw pack and when I get message notifications the stored name comes up as "pending". Prior to the upgrade all external messaged said unknown caller.How can this be fixed to show the calling party's name?
I have 2 x Cisco 7925G phones that are running 1.4.1 SR1. If I upgrade the phones by USB to 1.4.5, will I run into any issues. I can't upgrade the firmware through the UC520 since its newer than the software pack. I guess the same question would a...
Hi guys, I am in big need of help, I have no ideas left.In our company we had analog and voip lines together, now we changed all to voip with an external provider. The problem is: In random times the calls are just simply drop out and going to a busy...
I've been trying and trying to create a custom ringtone for my Cisco 303SPA but I haven't been able to!According to this FAQ the Cisco 303SPA ringtone format is G.726-32, and Ring Tone Suffix is .726. However when I try to create the ringtone, it doe...
We have SIP trunks on a UC560 and we need to edit local number i.e. 123456 to insert the area code before sending out as the SIP provider needs the area code.Is this straight forward?
Hello!I needed help setting up a netowrk. How can I have a sonicwall act as a DHCP server for the UC320 I have?The computers are connected via LAN. And the Sonicwall is connected via WAN.Thanks for your help.
Hi everyone, I have a problem with my UC540, below is my network diagram: Internet---------887----------UC540 I have successfully configured UC540, incoming and outgoing call working perfect, but when I changed IP address on UC540's F0/0 which connec...
Hi all!We have a Cisco 7926 desk phone connected to a Jabra Pro wireless headset. It's connected with a headset cable from the phone to the base station and set up correctly according to the instructions from Jabra. My problem is that when we use the...
