spa500S sidecar with Intermedia 2.0 hosted pbx
mo000000111
Hello and Thanks in advance
using spa504g phones with spa500s side car; I want to have the side-car work as per article
http://sbkb.cisco.com/CiscoSB/ukp.aspx?vw=1&docid=7aa7fdd7d543437ab12a3dbb0940aebe_Configure_Attendent_Console_Key_LED_Pattern_on_SPA500S_SPA50.xml&pid=3&respid=0&snid=1&dispid=0&cpage=search
entries to attendant console unit 1 key X with syntax below:
fnc=blf+sd+cp;sub=102@$PROXY:6060;nme=102
fnc=blf+sd+cp;sub=113@$PROXY:6060;nme=113
Orange blinking show on the unit 1 key X  with an entries above.
I believe this is a syntax error message?
Is there a syntax error in my entry above?  What syntax will work?
side-car configure key(s) stop blinking if in field "Serv Subscribing LED"  when either c=o (keys turn off)  or if c=g (keys turn green)
Mo===
artlcle 1.  http://sbkb.cisco.com/CiscoSB/ukp.aspx?vw=1&docid=7aa7fdd7d543437ab12a3dbb0940aebe_Configure_Attendent_Console_Key_LED_Pattern_on_SPA500S_SPA50.xml&pid=3&respid=0&snid=1&dispid=0&cpage=search
Dan Lukes
Orange blink pattern mean the phone is unable to subscribe for the requested feature on target $PROXY
Verify the phone is sending SUBSCRIBE requests to proper target, check $PROXY logs,
