Bookmark
Subscribe
3750
SPA525G2: trouble with provisioning
Joerg -
Hi there,
I have a SPA525G2 I'd like to provision via tftp. But unfortunately it does not work as hoped...
I did the following in order to get the provisioning up an running:
1.     Set up a DHCP server on a 1841:
          ip dhcp pool Telefon_2
             host 172.20.2.51 255.255.255.0
             client-identifier 0150.3de5.0f03.00
             client-name Telefon_2
             default-router 172.20.2.254
             dns-server 172.20.2.251
             option 66 ip 172.20.2.251
                                 option 150 ip 172.20.2.251
          The IP adress is given correctly to the SPA525G2 but option 66 does not seem to work...
2.     I set up a tftp server on an OpenSUSE 11.4 and put a SPA525G2.cfg with
               <flat-profile>
                    <Resync_On_Reset>Yes</Resync_On_Reset>
                    <Resync_Periodic>600</Resync_Periodic>
                    <Profile_Rule>tftp://172.20.2.251/phones/SPA525G2/spa$MA.xml</Profile_Rule>
               </flat-profile>
           in the root. The spa503de50f0400.xml, created with the SPA525G SPC, has  been modified and put into the directory according to the cfg  file           mentioned above.
3.     Rebooted the phone.
As mentioned the phone get the correct IP but nothing more...
On my Windows 7 machine I can download the files from the tftp server via tftp get...
Any idea what I am missing...???
Best regards,
Joerg
5 Replies 5
Joerg -
Update:
Regarding to the status page on the SPA525G2 the xml file is not loaded because it is corrupt.
The xml file has been created with the SPC compiler tool for firmware 7.4.8.
Even a config backup via http://172.20.2.51/admin/spacfg.xml is corrupt if I save this as spa$MA.xml ($MA stands for the actual IP... Just to avoid a misunderstanding ).
This seems to be VERY strange...
Has anyone similar experiences?? Or even a workaround??
Best regards,
Joerg
Hi there,
is there really no advice or hint???
Joerg
Dear poster,
Can you please attache your spacfg.xml file for investigation?
Also, the $MA mactro resolves to the MAC address of the device not the IP address.
Another good start point would be to fire up a WireShark and do some packet capturing so we can see what is really happening on the network regarding DHCP requests and acknowledgements and TFTP requests.
Thanks and regards,
Zsolt
Hi Zsolt,
thanks for the answer.
Of course I meant the MAC adress and not the ip adress... My mistake...
Attached you'll find the spacfg.xml and the spa$MAC.xml.
This weekend I'll do the wireshark trace.
Thanks a lot,
Joerg
Hi Sir.
Together with wireshark traces could you get the syslog from the phone?
Please let me know if you need help to do that.
thanks
