02-23-2009 11:20 AM - edited 03-21-2019 12:57 AM
now we testing LDAP connection, every works fine only i have one question. In AD i have IP Phone number, Mobile and Home.
i use this string
"a=cn;a=ipPhone,n=Pevna,t=p;a=mobile,n=Mobilni,t=p;a=homePhone,n=Soukrome,t=p;"
But how i can dial Mobile? everytime phone dialing ipPhone and i havent chance change dialed number
Thank you
Tomas
02-23-2009 03:12 PM
Hi Tomas,
This is a limitation of the current LDAP functionality in the SPA phones. Currently only the first defined t=p device is used.
The only work-around I can suggest is:
Multiple entries per user, something along the lines of so the user can select which contact method they wish to use and select an appropriate entry:
Patrick Born [mobile]
Patrick Born [office]
Patrick Born [home]
I have shared your information with the phone's product manager for feature enhancement.
Patrick
02-24-2009 12:36 AM
Thank you
Tomas
