UC320 SPA 8800
Matt Waechter
How can I debug/ log my calls for the lines in the SPA8800? I would also like to do the FXO impedence tests on those lines but don't have the option.
wenyang
Level 4
Level 4
Hi Matt,
Please contact small business support center. One of our engineers will be able to assist you to debug SPA8800.
FXO impedance testing is not available for SPA8800 FXO ports. But you can connect the SPA8800 phone line to UC320W FXO port, run impedance matching tool, manually write down the parameters and fill them into SPA8800 ports and connect the phone line back to SPA8800.
Hope this helps.
Best regards,
Wendy Yang
Thank you as always Wendy
