UC520 dual WAN
johnroche_2
Is it possible to have/support two WAN lins on a UC520.
I have a DSL service which uses PPPOE and a Sat Link using DHCP.
Ca this be done in CCA or CLI?
David Trad
Hi John,
This is not possible directly from the UC-500 as such, it would be highly recommended that you consider using an interfacing device such as the SRP541W which is a dual-wan router and works quite well with the UC's
There might be a way to use the WAN port for the PPPoE and then use a LAN port for the Sat Link, but you issues will be then things like Load Balance, Fail Over and split path I.E working out which devices go where, and you might have to put the SAT link on a separate VLAN.
Hope this gives you something to look at.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
David Trad
Hi John,
Cheers,
David.
