08-04-2011 04:29 AM - edited 03-21-2019 04:27 AM
Hi all,
I have an issue with a UC520 cutting off voicemail recording after approximately 10 seconds when using SIP trunk for the incomming call.
We are using the latest software pack (8.2.0) but the issue existed before that. (Was waiting for the update before posting, in case that had resolved my issue).
We tested an incomming call using SIP and we get the issue. When dialing in on an FXO port the voicemail records for longer, with no apparent cut-off.
It *may be* that there is some 'keep-alive' that is missing during the SIP call... but I can't actually track this down.
A normal, not-to-voicemail SIP trunk call does not cut off prematurely, stays active until we finish the call.
P.S. New CCA made the Software Pack upgrade really smooth... never had 100% success before, always having to 'nurse' the UC520 in to accepting an upgrade of the correct language (UK).
Mark
08-06-2011 07:02 PM
Hi, Mark:
We need to know who send BYE, CUE or SIP provider.
If you can capture the wireshark SIP log, then it will help us to narrow down the cause.
-David
08-07-2011 09:23 AM
Hi David,
Thanks for the reply.
I will attach the log I have been able to make, which should be the SIP trace from the UC520.
(I have done some text substitutions to hide our info)
I am not 100% up to speed with the SIP protocol, so having a little trouble decoding what is going on. Not sure how the call gets transferred from ringing to voicemail... but we know that bit works okay.
As far as I can tell the BYE comes from the SIP provider... but I don't know why... Work fine if not a call to voicemail.
SIP provider is HostComm.co.uk ...
In the following trace, I placed an incomming call from my mobile to the office (UC520) number. The console phone rang (x201) correctly... I waited for it to go to voicemail, and the call cut off after 6 to 10 seconds (correctly recording that partial message).
***Can't see how to attach a file to this message so have pasted it below***
Text Substitutions;
Caller's Number: CALLERS-NUMBER
Dialled (Our) Number: DIALLED-NUMBER
UC520 Public IP: UC520-PUBLIC-IP
UC520 Internal IP: UC520-PRIVATE-IP
--------------------------show logging--------------------------
Syslog logging: enabled (0 messages dropped, 2 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: disabled
Monitor logging: disabled
Buffer logging: level debugging, 2445 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
Persistent logging: disabled
No active filter modules.
Trap logging: level informational, 7009 message lines logged
Log Buffer (1000000 bytes):
007005: Aug 7 16:12:16.022: %SYS-5-CONFIG_I: Configured from console by root on vty0 (192.168.144.108)
007006: Aug 7 16:12:33.518: //-1/xxxxxxxxxxxx/RXRULE/regxrule_get_profile_from_trunkgroup_internal:
Voice port 0x88A3D9F0 dsl=-1 timeslot=0 does not belong to any trunk group
007007: Aug 7 16:12:33.518: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=BCD, Called Number=, Voice-Interface=0x88A3D9F0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
007008: Aug 7 16:12:33.518: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ANSWER; Calling Number=BCD
007009: Aug 7 16:12:33.518: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Is Incoming=TRUE, Number Expansion=FALSE
007010: Aug 7 16:12:33.518: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=, Expanded String=, Calling Number=BCDT
Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
007011: Aug 7 16:12:33.518: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
007012: Aug 7 16:12:33.518: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
007013: Aug 7 16:12:33.518: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ORIGINATE; Calling Number=BCD
007014: Aug 7 16:12:33.518: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007015: Aug 7 16:12:33.518: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007016: Aug 7 16:12:33.518: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Incoming Dial-peer=20001 Is Matched
007017: Aug 7 16:12:33.518: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
007018: Aug 7 16:12:33.518: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=20001
007019: Aug 7 16:12:33.518: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
007020: Aug 7 16:12:33.518: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerSPI:exit@6561
007021: Aug 7 16:12:33.522: //-1/82BFC9FEB7EE/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=BCD
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=0 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
007022: Aug 7 16:12:33.522: //-1/82BFC9FEB7EE/CCAPI/cc_api_call_setup_ind_common:
Interface=0x88A3D9F0, Call Info(
Calling Number=BCD,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Incoming Dial-peer=20001, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
007023: Aug 7 16:12:33.522: //-1/82BFC9FEB7EE/CCAPI/ccCheckClipClir:
In: Calling Number=BCD(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
007024: Aug 7 16:12:33.522: //-1/82BFC9FEB7EE/CCAPI/ccCheckClipClir:
Out: Calling Number=BCD(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
007025: Aug 7 16:12:33.522: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007026: Aug 7 16:12:33.522: :cc_get_feature_vsa malloc success
007027: Aug 7 16:12:33.522: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007028: Aug 7 16:12:33.522: cc_get_feature_vsa count is 3
007029: Aug 7 16:12:33.522: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007030: Aug 7 16:12:33.522: :FEATURE_VSA attributes are: feature_name:0,feature_time:2296339296,feature_id:13878
007031: Aug 7 16:12:33.522: //24447/82BFC9FEB7EE/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=BCD(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown))
007032: Aug 7 16:12:33.522: //-1/82BFC9FEB7EE/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x8A46CD54; count=1
007033: Aug 7 16:12:33.522: //-1/82BFC9FEB7EE/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x88EA7CF4
007034: Aug 7 16:12:33.526: //24447/82BFC9FEB7EE/CCAPI/cc_process_call_setup_ind:
Event=0x87F2C158
007035: Aug 7 16:12:33.526: //24447/82BFC9FEB7EE/CCAPI/ccCallSetContext:
Context=0x860552FC
007036: Aug 7 16:12:33.526: //24447/82BFC9FEB7EE/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 24447 with tag 20001 to app "_ManagedAppProcess_Default"
007037: Aug 7 16:12:33.526: //-1/82BFC9FEB7EE/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x8A46CD54; count=1
007038: Aug 7 16:12:33.526: //24447/82BFC9FEB7EE/CCAPI/ccCallSetupAck:
Call Id=24447
007039: Aug 7 16:12:33.526: //24447/82BFC9FEB7EE/CCAPI/cc_api_set_transfer_info:
Transfer Number=, Transfer Reason=0x0
007040: Aug 7 16:12:33.526: //24447/82BFC9FEB7EE/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=TRUE, Tone=Dial Tone,
Tone Direction=Network, Params=0x0, Call Id=24447
007041: Aug 7 16:12:33.526: //24447/82BFC9FEB7EE/CCAPI/ccSetDigitTimeouts:
Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
007042: Aug 7 16:12:33.526: //24447/82BFC9FEB7EE/CCAPI/ccSetDigitTimeouts:
Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
007043: Aug 7 16:12:33.526: //24447/82BFC9FEB7EE/CCAPI/ccCallReportDigits:
(callID=0x5F7F, digit_event=0x1, enable=TRUE, consume=FALSE)
007044: Aug 7 16:12:33.526: //24447/82BFC9FEB7EE/CCAPI/ccCallReportDigits:
Enabled=TRUE, Call Id=24447
007045: Aug 7 16:12:33.530: //24447/82BFC9FEB7EE/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x88A3D9F0, callID=0x5F7F, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
007046: Aug 7 16:12:33.530: //24447/82BFC9FEB7EE/CCAPI/cc_api_call_report_digits_done:
Enabled=TRUE, Disposition=0x0, Interface=0x88A3D9F0, Call Id=24447
007047: Aug 7 16:12:33.530: //24447/82BFC9FEB7EE/CCAPI/cc_api_call_report_digits_done:
Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=5000(ms))
007048: Aug 7 16:12:33.530: //24447/82BFC9FEB7EE/CCAPI/cc_api_call_digit_begin:
Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Source Call Id=24447, Digit=A, DigitBeginFlags=0x0,
Rtp Timestamp=0x50246738, Rtp Expiration=0x0
007049: Aug 7 16:12:33.530: //24447/82BFC9FEB7EE/CCAPI/cc_api_call_digit_end:
Source Call Id=24447, Digit=A, Duration=100,
Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
007050: Aug 7 16:12:33.530: //24447/82BFC9FEB7EE/CCAPI/cc_api_call_digit_end:
Call Entry(Handoff Depth=0)
007051: Aug 7 16:12:33.530: //24447/82BFC9FEB7EE/CCAPI/cc_api_call_digit_begin:
Source Call Id=24447, Digit=B, DigitBeginFlags=0x0,
Rtp Timestamp=0x5024E438, Rtp Expiration=0x0
007052: Aug 7 16:12:33.530: //24447/82BFC9FEB7EE/CCAPI/cc_api_call_digit_end:
Source Call Id=24447, Digit=B, Duration=100,
007053: Aug 7 16:12:33.530: //24447/82BFC9FEB7EE/CCAPI/cc_api_call_digit_end:
007054: Aug 7 16:12:33.530: //24447/82BFC9FEB7EE/CCAPI/cc_api_call_digit_begin:
Source Call Id=24447, Digit=C, DigitBeginFlags=0x0,
Rtp Timestamp=0x50256138, Rtp Expiration=0x0
007055: Aug 7 16:12:33.530: //24447/82BFC9FEB7EE/CCAPI/cc_api_call_digit_end:
Source Call Id=24447, Digit=C, Duration=100,
007056: Aug 7 16:12:33.530: //24447/82BFC9FEB7EE/CCAPI/cc_api_call_digit_end:
007057: Aug 7 16:12:33.538: //-1/82BFC9FEB7EE/DPM/dpMatchPeersCore:
Calling Number=, Called Number=A, Peer Info Type=DIALPEER_INFO_SPEECH
007058: Aug 7 16:12:33.538: //-1/82BFC9FEB7EE/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=A
007059: Aug 7 16:12:33.538: //-1/82BFC9FEB7EE/DPM/dpMatchCore:
Dial String=A, Expanded String=A, Calling Number=
Timeout=FALSE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
007060: Aug 7 16:12:33.538: //-1/82BFC9FEB7EE/DPM/MatchNextPeer:
Result=MORE_DIGITS_NEEDED(1); Outgoing Dial-peer=5
007061: Aug 7 16:12:33.538: //-1/82BFC9FEB7EE/DPM/dpMatchCore:
Result=1
007062: Aug 7 16:12:33.538: //-1/82BFC9FEB7EE/DPM/dpMatchPeersCore:
Result=Partial Matches(1) after DP_MATCH_DEST
007063: Aug 7 16:12:33.538: //-1/82BFC9FEB7EE/DPM/dpMatchSafModulePlugin:
dialstring=A, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
007064: Aug 7 16:12:33.538: //-1/82BFC9FEB7EE/DPM/dpMatchPeersMoreArg:
007065: Aug 7 16:12:33.538: //-1/82BFC9FEB7EE/DPM/dpMatchPeersCore:
Calling Number=, Called Number=AB, Peer Info Type=DIALPEER_INFO_SPEECH
007066: Aug 7 16:12:33.538: //-1/82BFC9FEB7EE/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=AB
007067: Aug 7 16:12:33.538: //-1/82BFC9FEB7EE/DPM/dpMatchCore:
Dial String=AB, Expanded String=AB, Calling Number=
007068: Aug 7 16:12:33.538: //-1/82BFC9FEB7EE/DPM/MatchNextPeer:
007069: Aug 7 16:12:33.538: //-1/82BFC9FEB7EE/DPM/dpMatchCore:
Result=1
007070: Aug 7 16:12:33.538: //-1/82BFC9FEB7EE/DPM/dpMatchPeersCore:
007071: Aug 7 16:12:33.542: //-1/82BFC9FEB7EE/DPM/dpMatchSafModulePlugin:
dialstring=AB, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
007072: Aug 7 16:12:33.542: //-1/82BFC9FEB7EE/DPM/dpMatchPeersMoreArg:
007073: Aug 7 16:12:33.542: //-1/82BFC9FEB7EE/DPM/dpMatchPeersCore:
Calling Number=, Called Number=ABC, Peer Info Type=DIALPEER_INFO_SPEECH
007074: Aug 7 16:12:33.542: //-1/82BFC9FEB7EE/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=ABC
007075: Aug 7 16:12:33.542: //-1/82BFC9FEB7EE/DPM/dpMatchCore:
Dial String=ABC, Expanded String=ABC, Calling Number=
007076: Aug 7 16:12:33.542: //-1/82BFC9FEB7EE/DPM/MatchNextPeer:
Result=Success(0); Outgoing Dial-peer=5 Is Matched
007077: Aug 7 16:12:33.542: //-1/82BFC9FEB7EE/DPM/dpMatchPeersCore:
Result=Success(0) after DP_MATCH_DEST
007078: Aug 7 16:12:33.542: //-1/82BFC9FEB7EE/DPM/dpMatchSafModulePlugin:
dialstring=ABC, saf_enabled=1, saf_dndb_lookup=0, dp_result=0
007079: Aug 7 16:12:33.542: //-1/82BFC9FEB7EE/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=5
007080: Aug 7 16:12:33.542: //24447/82BFC9FEB7EE/CCAPI/ccCallReportDigits:
(callID=0x5F7F, digit_event=0x0, enable=FALSE, consume=FALSE)
007081: Aug 7 16:12:33.542: //24447/82BFC9FEB7EE/CCAPI/ccCallReportDigits:
007082: Aug 7 16:12:33.542: //24447/82BFC9FEB7EE/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x88A3D9F0, callID=0x5F7F, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
007083: Aug 7 16:12:33.542: //24447/82BFC9FEB7EE/CCAPI/cc_api_call_report_digits_done:
007084: Aug 7 16:12:33.542: //24447/82BFC9FEB7EE/CCAPI/cc_api_call_report_digits_done:
007085: Aug 7 16:12:33.542: //24447/82BFC9FEB7EE/CCAPI/ccCallProceeding:
Progress Indication=NULL(0)
007086: Aug 7 16:12:33.546: //-1/82BFC9FEB7EE/DPM/dpMatchPeersCore:
007087: Aug 7 16:12:33.546: //-1/82BFC9FEB7EE/DPM/dpMatchPeersCore:
007088: Aug 7 16:12:33.546: //-1/82BFC9FEB7EE/DPM/dpMatchCore:
Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
007089: Aug 7 16:12:33.546: //-1/82BFC9FEB7EE/DPM/MatchNextPeer:
007090: Aug 7 16:12:33.546: //-1/82BFC9FEB7EE/DPM/dpMatchPeersCore:
007091: Aug 7 16:12:33.546: //-1/82BFC9FEB7EE/DPM/dpMatchSafModulePlugin:
dialstring=ABC, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
007092: Aug 7 16:12:33.546: //-1/82BFC9FEB7EE/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=5
007093: Aug 7 16:12:33.546: //-1/82BFC9FEB7EE/DPM/dpMatchPeersCore:
007094: Aug 7 16:12:33.546: //-1/82BFC9FEB7EE/DPM/dpMatchPeersCore:
007095: Aug 7 16:12:33.546: //-1/82BFC9FEB7EE/DPM/dpMatchCore:
007096: Aug 7 16:12:33.546: //-1/82BFC9FEB7EE/DPM/MatchNextPeer:
007097: Aug 7 16:12:33.546: //-1/82BFC9FEB7EE/DPM/dpMatchPeersCore:
007098: Aug 7 16:12:33.546: //-1/82BFC9FEB7EE/DPM/dpMatchSafModulePlugin:
007099: Aug 7 16:12:33.546: //-1/82BFC9FEB7EE/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=5
007100: Aug 7 16:12:33.546: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=ABC, Called Number=ABC, Peer Info Type=DIALPEER_INFO_SPEECH
007101: Aug 7 16:12:33.546: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007102: Aug 7 16:12:33.546: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=ABC, Expanded String=ABC, Calling Number=ABCT
007103: Aug 7 16:12:33.546: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007104: Aug 7 16:12:33.546: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007105: Aug 7 16:12:33.546: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007106: Aug 7 16:12:33.546: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=5
007107: Aug 7 16:12:33.546: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=, Called Number=, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
007108: Aug 7 16:12:33.546: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=NO_MATCH(-1) After All Match Rules Attempt
007109: Aug 7 16:12:33.546: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
007110: Aug 7 16:12:33.546: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6610
007111: Aug 7 16:12:33.546: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=ABC, Called Number=, Voice-Interface=0x0,
007112: Aug 7 16:12:33.546: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ANSWER; Calling Number=ABC
007113: Aug 7 16:12:33.546: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007114: Aug 7 16:12:33.546: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=, Expanded String=, Calling Number=ABCT
007115: Aug 7 16:12:33.546: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
007116: Aug 7 16:12:33.546: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
007117: Aug 7 16:12:33.546: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ORIGINATE; Calling Number=ABC
007118: Aug 7 16:12:33.546: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007119: Aug 7 16:12:33.546: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007120: Aug 7 16:12:33.546: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Incoming Dial-peer=5 Is Matched
007121: Aug 7 16:12:33.550: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
007122: Aug 7 16:12:33.550: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007123: Aug 7 16:12:33.550: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007124: Aug 7 16:12:33.550: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6610
007125: Aug 7 16:12:33.550: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007126: Aug 7 16:12:33.550: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007127: Aug 7 16:12:33.550: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007128: Aug 7 16:12:33.550: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007129: Aug 7 16:12:33.550: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007130: Aug 7 16:12:33.550: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007131: Aug 7 16:12:33.550: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=5
007132: Aug 7 16:12:33.550: //-1/82BFC9FEB7EE/DPM/dpMatchPeersCore:
007133: Aug 7 16:12:33.550: //-1/82BFC9FEB7EE/DPM/dpMatchPeersCore:
007134: Aug 7 16:12:33.550: //-1/82BFC9FEB7EE/DPM/dpMatchCore:
007135: Aug 7 16:12:33.550: //-1/82BFC9FEB7EE/DPM/MatchNextPeer:
007136: Aug 7 16:12:33.550: //-1/82BFC9FEB7EE/DPM/dpMatchPeersCore:
007137: Aug 7 16:12:33.550: //-1/82BFC9FEB7EE/DPM/dpMatchSafModulePlugin:
dialstring=ABC, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
007138: Aug 7 16:12:33.550: //-1/82BFC9FEB7EE/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=5
007139: Aug 7 16:12:33.550: //-1/82BFC9FEB7EE/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x8A46CD54; count=2
007140: Aug 7 16:12:33.550: //-1/82BFC9FEB7EE/RXRULE/regxrule_dp_translate: No profile found in peer 5 for outgoing direction
007141: Aug 7 16:12:33.550: //-1/82BFC9FEB7EE/RXRULE/regxrule_dp_translate: calling_number=BCD calling_octet=0x0
called_number=ABC called_octet=0x80
redirect_number= redirect_type=0 redirect_plan=0 redirect_PI=0 redirect_SI=0
007142: Aug 7 16:12:33.550: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number ABC
007143: Aug 7 16:12:33.550: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
007144: Aug 7 16:12:33.550: : updating existing feature vsa
007145: Aug 7 16:12:33.554: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
007146: Aug 7 16:12:33.554: feature call basic
007147: Aug 7 16:12:33.554: //24447/82BFC9FEB7EE/CCAPI/ccCallDisconnect:
Cause Value=17, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
007148: Aug 7 16:12:33.554: //24447/82BFC9FEB7EE/CCAPI/ccCallDisconnect:
Cause Value=17, Call Entry(Responsed=TRUE, Cause Value=17)
007149: Aug 7 16:12:33.554: //24447/82BFC9FEB7EE/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
007150: Aug 7 16:12:33.566: //24447/82BFC9FEB7EE/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x88A3D9F0, Tag=0x0, Call Id=24447,
Call Entry(Disconnect Cause=17, Voice Class Cause Code=0, Retry Count=0)
007151: Aug 7 16:12:33.566: //-1/82BFC9FEB7EE/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x8A46CD54; count=2
007152: Aug 7 16:12:33.566: //-1/82BFC9FEB7EE/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x88EA82BC
007153: Aug 7 16:12:33.566: //24447/82BFC9FEB7EE/CCAPI/cc_api_call_disconnect_done:
Call Disconnect Event Sent
007154: Aug 7 16:12:33.566: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007155: Aug 7 16:12:33.566: :cc_free_feature_vsa freeing 88DF5B58
007156: Aug 7 16:12:33.566: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007157: Aug 7 16:12:33.566: vsacount in free is 2
007158: Aug 7 16:12:36.246: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on FastEthernet0/1/8 (not half duplex), with SEP00e075244b3c port 1 (half duplex).
007159: Aug 7 16:12:36.458: //24446/7890FA6DB7E8/CCAPI/cc_api_call_disconnected:
Cause Value=19, Interface=0x88873CA4, Call Id=24446
007160: Aug 7 16:12:36.458: //24446/7890FA6DB7E8/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=TRUE, Cause Value=19, Retry Count=0)
007161: Aug 7 16:12:36.458: //24445/7890FA6DB7E8/CCAPI/ccCallReleaseResources:
release reserved xcoding resource.
007162: Aug 7 16:12:36.458: //24446/7890FA6DB7E8/CCAPI/cc_api_get_transfer_info:
007163: Aug 7 16:12:36.458: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
type=6 redirecting_number=201
007164: Aug 7 16:12:36.458: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=, Called Number=399, Peer Info Type=DIALPEER_INFO_SPEECH
007165: Aug 7 16:12:36.458: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=399
007166: Aug 7 16:12:36.458: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=399, Expanded String=399, Calling Number=
007167: Aug 7 16:12:36.458: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Outgoing Dial-peer=2000 Is Matched
007168: Aug 7 16:12:36.458: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007169: Aug 7 16:12:36.458: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=399, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
007170: Aug 7 16:12:36.458: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=2000
007171: Aug 7 16:12:36.458: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectNumber:
type=6 Original Called Number=201, Called Number=201, Calling Number=CALLERS-NUMBER, Calling DN=-1 Calling Id=24445,
Redirect Number=399, Redirect Reason=2
007172: Aug 7 16:12:36.458: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=, Called Number=CALLERS-NUMBER, Peer Info Type=DIALPEER_INFO_SPEECH
007173: Aug 7 16:12:36.458: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=CALLERS-NUMBER
007174: Aug 7 16:12:36.458: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=CALLERS-NUMBER, Expanded String=CALLERS-NUMBER, Calling Number=
007175: Aug 7 16:12:36.458: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
007176: Aug 7 16:12:36.458: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
007177: Aug 7 16:12:36.458: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=CALLERS-NUMBER, saf_enabled=0, saf_dndb_lookup=1, dp_result=-1
007178: Aug 7 16:12:36.462: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
007179: Aug 7 16:12:36.462: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007180: Aug 7 16:12:36.462: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007181: Aug 7 16:12:36.462: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007182: Aug 7 16:12:36.462: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007183: Aug 7 16:12:36.462: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007184: Aug 7 16:12:36.462: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007185: Aug 7 16:12:36.462: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
007186: Aug 7 16:12:36.462: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
007187: Aug 7 16:12:36.462: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007188: Aug 7 16:12:36.462: :cc_get_feature_vsa malloc success
007189: Aug 7 16:12:36.462: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007190: Aug 7 16:12:36.462: cc_get_feature_vsa count is 3
007191: Aug 7 16:12:36.462: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007192: Aug 7 16:12:36.462: :FEATURE_VSA attributes are: feature_name:0,feature_time:2296339296,feature_id:13879
007193: Aug 7 16:12:36.462: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
007194: Aug 7 16:12:36.462: feature_vsa is 88DF5DF8,featname is 0
007195: Aug 7 16:12:36.462: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007196: Aug 7 16:12:36.462: :cc_get_feature_vsa malloc success
007197: Aug 7 16:12:36.462: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007198: Aug 7 16:12:36.462: cc_get_feature_vsa count is 4
007199: Aug 7 16:12:36.462: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007200: Aug 7 16:12:36.462: :FEATURE_VSA attributes are: feature_name:0,feature_time:2296339520,feature_id:13880
007201: Aug 7 16:12:36.462: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
007202: Aug 7 16:12:36.462: : Generating new featurevsa,inserting it
007203: Aug 7 16:12:36.462: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
007204: Aug 7 16:12:36.462: feature call forward featname is 3
007205: Aug 7 16:12:36.462: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
007206: Aug 7 16:12:36.462: feature_vsa is 88DF5D18,featname is 0
007207: Aug 7 16:12:36.462: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007208: Aug 7 16:12:36.462: :cc_get_feature_vsa malloc success
007209: Aug 7 16:12:36.462: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007210: Aug 7 16:12:36.462: cc_get_feature_vsa count is 5
007211: Aug 7 16:12:36.462: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007212: Aug 7 16:12:36.462: :FEATURE_VSA attributes are: feature_name:0,feature_time:2296340192,feature_id:13881
007213: Aug 7 16:12:36.462: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
007214: Aug 7 16:12:36.462: : Generating new featurevsa,inserting it
007215: Aug 7 16:12:36.462: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
007216: Aug 7 16:12:36.462: feature call forward featname is 3
007217: Aug 7 16:12:36.462: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007218: Aug 7 16:12:36.462: :cc_free_feature_vsa freeing 88DF5B58
007219: Aug 7 16:12:36.462: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007220: Aug 7 16:12:36.462: vsacount in free is 4
007221: Aug 7 16:12:36.462: //24446/7890FA6DB7E8/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=19)
007222: Aug 7 16:12:36.462: //24446/7890FA6DB7E8/CCAPI/ccCallDisconnect:
Cause Value=19, Call Entry(Responsed=TRUE, Cause Value=19)
007223: Aug 7 16:12:36.466: //24446/7890FA6DB7E8/CCAPI/cc_api_get_transfer_info:
007224: Aug 7 16:12:36.470: //24446/7890FA6DB7E8/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x88873CA4, Tag=0x0, Call Id=24446,
Call Entry(Disconnect Cause=19, Voice Class Cause Code=0, Retry Count=0)
007225: Aug 7 16:12:36.470: //-1/7890FA6DB7E8/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x0
007226: Aug 7 16:12:36.474: //24446/7890FA6DB7E8/CCAPI/cc_api_call_disconnect_done:
007227: Aug 7 16:12:36.474: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007228: Aug 7 16:12:36.474: :cc_free_feature_vsa freeing 88DF5ED8
007229: Aug 7 16:12:36.474: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007230: Aug 7 16:12:36.474: vsacount in free is 3
007231: Aug 7 16:12:36.474: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007232: Aug 7 16:12:36.474: vsacount in free is 2
007233: Aug 7 16:12:36.474: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007234: Aug 7 16:12:36.474: :cc_get_feature_vsa malloc success
007235: Aug 7 16:12:36.474: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007236: Aug 7 16:12:36.474: cc_get_feature_vsa count is 3
007237: Aug 7 16:12:36.474: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007238: Aug 7 16:12:36.474: :FEATURE_VSA attributes are: feature_name:0,feature_time:2296339744,feature_id:13882
007239: Aug 7 16:12:36.474: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
007240: Aug 7 16:12:36.474: feature call forward featname is 3
007241: Aug 7 16:12:36.474: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007242: Aug 7 16:12:36.474: :cc_free_feature_vsa freeing 88DF5D18
007243: Aug 7 16:12:36.474: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007244: Aug 7 16:12:36.474: vsacount in free is 2
007245: Aug 7 16:12:36.474: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=399, Called Number=, Voice-Interface=0x0,
007246: Aug 7 16:12:36.474: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ANSWER; Calling Number=399
007247: Aug 7 16:12:36.474: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007248: Aug 7 16:12:36.474: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=, Expanded String=, Calling Number=399T
007249: Aug 7 16:12:36.474: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
007250: Aug 7 16:12:36.474: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
007251: Aug 7 16:12:36.474: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ORIGINATE; Calling Number=399
007252: Aug 7 16:12:36.474: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007253: Aug 7 16:12:36.474: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007254: Aug 7 16:12:36.474: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Incoming Dial-peer=2000 Is Matched
007255: Aug 7 16:12:36.478: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
007256: Aug 7 16:12:36.478: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007257: Aug 7 16:12:36.478: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007258: Aug 7 16:12:36.478: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6610
007259: Aug 7 16:12:36.478: //-1/8482D72EB7F2/DPM/dpMatchPeersCore:
007260: Aug 7 16:12:36.478: //-1/8482D72EB7F2/DPM/dpMatchPeersCore:
007261: Aug 7 16:12:36.478: //-1/8482D72EB7F2/DPM/dpMatchCore:
007262: Aug 7 16:12:36.478: //-1/8482D72EB7F2/DPM/MatchNextPeer:
007263: Aug 7 16:12:36.478: //-1/8482D72EB7F2/DPM/dpMatchPeersCore:
007264: Aug 7 16:12:36.478: //-1/8482D72EB7F2/DPM/dpMatchSafModulePlugin:
dialstring=399, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
007265: Aug 7 16:12:36.478: //-1/8482D72EB7F2/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
007266: Aug 7 16:12:36.478: //-1/8482D72EB7F2/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x8A46D11C; count=3
007267: Aug 7 16:12:36.478: //-1/8482D72EB7F2/RXRULE/regxrule_profile_translate_internal: number=CALLERS-NUMBER type=unknown plan=unknown numbertype=calling
007268: Aug 7 16:12:36.478: //-1/8482D72EB7F2/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
007269: Aug 7 16:12:36.478: //-1/8482D72EB7F2/RXRULE/regxrule_profile_match_internal: Error: ruleset for calling number not found
007270: Aug 7 16:12:36.478: //-1/8482D72EB7F2/RXRULE/regxrule_profile_translate_internal: No match: number=CALLERS-NUMBER type=unknown plan=unknown
007271: Aug 7 16:12:36.478: //-1/8482D72EB7F2/RXRULE/regxrule_profile_translate_internal: number=399 type=unknown plan=unknown numbertype=called
007272: Aug 7 16:12:36.478: //-1/8482D72EB7F2/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
007273: Aug 7 16:12:36.478: //-1/8482D72EB7F2/RXRULE/regxrule_profile_match_internal: Error: ruleset for called number not found
007274: Aug 7 16:12:36.478: //-1/8482D72EB7F2/RXRULE/regxrule_profile_translate_internal: No match: number=399 type=unknown plan=unknown
007275: Aug 7 16:12:36.478: //-1/8482D72EB7F2/RXRULE/regxrule_profile_translate_internal: number= type=unknown plan=unknown numbertype=redirect-target
007276: Aug 7 16:12:36.478: //-1/8482D72EB7F2/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
007277: Aug 7 16:12:36.478: //-1/8482D72EB7F2/RXRULE/regxrule_profile_match_internal: Error: ruleset for redirect-target number not found
007278: Aug 7 16:12:36.478: //-1/8482D72EB7F2/RXRULE/regxrule_profile_translate_internal: No match: number= type=unknown plan=unknown
007279: Aug 7 16:12:36.478: //-1/8482D72EB7F2/RXRULE/regxrule_profile_translate_internal: number=201 type=unknown plan=unknown numbertype=redirect-called
007280: Aug 7 16:12:36.478: //-1/8482D72EB7F2/RXRULE/regxrule_match: No match; number=201 rule precedence=1
007281: Aug 7 16:12:36.478: //-1/8482D72EB7F2/RXRULE/regxrule_profile_match_internal: No match found
007282: Aug 7 16:12:36.478: //-1/8482D72EB7F2/RXRULE/regxrule_profile_translate_internal: No match: number=201 type=unknown plan=unknown
007283: Aug 7 16:12:36.478: //-1/8482D72EB7F2/RXRULE/regxrule_dp_translate: calling_number=CALLERS-NUMBER calling_octet=0x0
called_number=399 called_octet=0x0
redirect_number=201 redirect_type=0 redirect_plan=0 redirect_PI=0 redirect_SI=0
007284: Aug 7 16:12:36.478: //24445/7890FA6DB7E8/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=2000, Params=0x86057A9C, Progress Indication=NULL(0)
007285: Aug 7 16:12:36.478: //24445/7890FA6DB7E8/CCAPI/ccCheckClipClir:
In: Calling Number=CALLERS-NUMBER(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
007286: Aug 7 16:12:36.478: //24445/7890FA6DB7E8/CCAPI/ccCheckClipClir:
Out: Calling Number=CALLERS-NUMBER(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
007287: Aug 7 16:12:36.478: //24445/7890FA6DB7E8/CCAPI/ccCallSetupRequest:
Destination Pattern=399, Called Number=399, Digit Strip=FALSE
007288: Aug 7 16:12:36.478: //24445/7890FA6DB7E8/CCAPI/ccCallSetupRequest:
Calling Number=CALLERS-NUMBER(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=399(TON=Unknown, NPI=Unknown),
Redirect Number=201, Display Info=CALLERS-NUMBER
Account Number=CALLERS-NUMBER, Final Destination Flag=TRUE,
Guid=8482D72E-C03E-11E0-B7F2-D9FD5E036138, Outgoing Dial-peer=2000
007289: Aug 7 16:12:36.478: //24445/7890FA6DB7E8/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=CALLERS-NUMBER
cisco-ani=CALLERS-NUMBER
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=399
cisco-desttype=0
cisco-destplan=0
cisco-rdie=73
cisco-rdn=201
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=2 fwd_final_type =0
007290: Aug 7 16:12:36.482: //24445/7890FA6DB7E8/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x872E9C18, Interface Type=3, Destination=, Mode=0x0,
Call Params(Calling Number=CALLERS-NUMBER,(Calling Name=CALLERS-NUMBER)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=399(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=2000, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
007291: Aug 7 16:12:36.482: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007292: Aug 7 16:12:36.482: :cc_get_feature_vsa malloc success
007293: Aug 7 16:12:36.482: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007294: Aug 7 16:12:36.482: cc_get_feature_vsa count is 3
007295: Aug 7 16:12:36.482: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007296: Aug 7 16:12:36.482: :FEATURE_VSA attributes are: feature_name:0,feature_time:2296339744,feature_id:13883
007297: Aug 7 16:12:36.482: //-1/8482D72EB7F2/RXRULE/regxrule_profile_translate_internal: number=201 type=unknown plan=unknown numbertype=redirect-called
007298: Aug 7 16:12:36.482: //-1/8482D72EB7F2/RXRULE/regxrule_match: No match; number=201 rule precedence=1
007299: Aug 7 16:12:36.482: //-1/8482D72EB7F2/RXRULE/regxrule_profile_match_internal: No match found
007300: Aug 7 16:12:36.482: //-1/8482D72EB7F2/RXRULE/regxrule_profile_translate_internal: No match: number=201 type=unknown plan=unknown
007301: Aug 7 16:12:36.482: //24448/7890FA6DB7E8/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
007302: Aug 7 16:12:36.482: //24448/7890FA6DB7E8/CCAPI/ccCallSetContext:
Context=0x86057A4C
007303: Aug 7 16:12:36.482: //24445/7890FA6DB7E8/CCAPI/ccSaveDialpeerTag:
007304: Aug 7 16:12:36.482: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
007305: Aug 7 16:12:36.482: feature call forward featname is 3
007306: Aug 7 16:12:36.482: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
007307: Aug 7 16:12:36.482: feature_vsa is 88DF5D18,featname is 0
007308: Aug 7 16:12:36.482: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007309: Aug 7 16:12:36.482: :cc_get_feature_vsa malloc success
007310: Aug 7 16:12:36.482: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007311: Aug 7 16:12:36.482: cc_get_feature_vsa count is 4
007312: Aug 7 16:12:36.482: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007313: Aug 7 16:12:36.482: :FEATURE_VSA attributes are: feature_name:0,feature_time:2296340192,feature_id:13884
007314: Aug 7 16:12:36.482: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
007315: Aug 7 16:12:36.482: : Generating new featurevsa,inserting it
007316: Aug 7 16:12:36.482: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
007317: Aug 7 16:12:36.482: feature call forward featname is 3
007318: Aug 7 16:12:36.486: //-1/8482D72EB7F2/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x8A46D11C; count=3
007319: Aug 7 16:12:36.486: //-1/8482D72EB7F2/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x88EA7CF4
007320: Aug 7 16:12:36.486: //-1/8482D72EB7F2/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x8A46D11C; count=3
007321: Aug 7 16:12:36.486: //24448/7890FA6DB7E8/CCAPI/cc_api_call_proceeding:
Interface=0x872E9C18, Progress Indication=NULL(0)
007322: Aug 7 16:12:36.490: //24448/8482D72EB7F2/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:399@10.1.10.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.10.2:5060;branch=z9hG4bK13361343
From: "CALLERS-NUMBER" <>>CALLERS-NUMBER@contact-pro4.co.uk>;tag=188CD62C-13E1
To: <399>399>
Date: Sun, 07 Aug 2011 15:12:36 GMT
Call-ID: 84840F7E-C03E11E0-B7F6D9FD-5E036138@contact-pro4.co.uk
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 2223167278-3225293280-3086146045-1577279800
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1312729956
Contact:
Call-Info: <10.1.10.2:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"10.1.10.2:5060>
Diversion: <>>201@contact-pro4.co.uk>;privacy=off;reason=no-answer;counter=1;screen=no
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 68
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 162
v=0
o=CiscoSystemsSIP-GW-UserAgent 9087 2403 IN IP4 10.1.10.2
s=SIP Call
t=0 0
m=audio 18018 RTP/AVP 0
c=IN IP4 10.1.10.2
a=rtpmap:0 PCMU/8000
a=ptime:20
007323: Aug 7 16:12:36.498: //24448/8482D72EB7F2/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <399>399>
CSeq: 101 INVITE
Content-Length: 0
007324: Aug 7 16:12:36.546: //24448/8482D72EB7F2/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <399>;tag=ds5f2826c4399>
CSeq: 101 INVITE
Content-Length: 0
Contact: <399>399>
Allow: INVITE, BYE, CANCEL, ACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO
Cisco-Gcid: 84840F7E-C03E11E0-B7F6D9FD-5E036138@contact-pro4.co.uk
007325: Aug 7 16:12:36.550: //24448/7890FA6DB7E8/CCAPI/cc_api_call_alert:
Interface=0x872E9C18, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
007326: Aug 7 16:12:36.550: //24448/7890FA6DB7E8/CCAPI/cc_api_call_alert:
Call Entry(Retry Count=0, Responsed=TRUE)
007327: Aug 7 16:12:36.550: //24445/7890FA6DB7E8/CCAPI/ccCallAlert:
007328: Aug 7 16:12:36.550: //24445/7890FA6DB7E8/CCAPI/ccCallAlert:
Call Entry(Responsed=TRUE, Alert Sent=TRUE)
007329: Aug 7 16:12:36.550: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007330: Aug 7 16:12:36.550: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007331: Aug 7 16:12:36.550: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007332: Aug 7 16:12:36.550: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
007333: Aug 7 16:12:36.550: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007334: Aug 7 16:12:36.550: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007335: Aug 7 16:12:36.550: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=NO_MATCH(-1)
007336: Aug 7 16:12:36.550: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007337: Aug 7 16:12:36.550: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007338: Aug 7 16:12:36.550: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007339: Aug 7 16:12:36.550: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007340: Aug 7 16:12:36.550: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
007341: Aug 7 16:12:36.550: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
007342: Aug 7 16:12:36.550: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007343: Aug 7 16:12:36.550: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007344: Aug 7 16:12:36.550: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007345: Aug 7 16:12:36.550: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007346: Aug 7 16:12:36.550: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
007347: Aug 7 16:12:36.550: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007348: Aug 7 16:12:36.550: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007349: Aug 7 16:12:36.550: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6610
007350: Aug 7 16:12:36.554: //24445/7890FA6DB7E8/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
Via: SIP/2.0/UDP 88.208.249.40:5060;branch=z9hG4bK1d2e.c20225b1.0
To:
Date: Sun, 07 Aug 2011 15:12:16 GMT
Call-ID: 6ea1da1a539967c857a0bc55605ae591@88.208.249.40
CSeq: 102 INVITE
Contact: <399>399>
Record-Route: <88.208.249.40>88.208.249.40>
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
007351: Aug 7 16:12:36.598: //24448/8482D72EB7F2/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 101 INVITE
Content-Length: 126
Contact: <399>399>
Call-Info: <10.1.10.1:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"10.1.10.1:5060>
v=0
o=CUE 13467803 2 IN IP4 10.1.10.1
s=SIP Call
c=IN IP4 10.1.10.1
t=0 0
m=audio 20806 RTP/AVP 0
007352: Aug 7 16:12:36.602: //24448/7890FA6DB7E8/CCAPI/cc_set_post_tagdata:
CALL_ERROR; Avlist Removal Is Failed
007353: Aug 7 16:12:36.602: //24448/7890FA6DB7E8/CCAPI/cc_api_caps_ind:
Destination Interface=0x0, Destination Call Id=-1, Source Call Id=24448,
Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Modem=0x0, Codec Bytes=160, Signal Type=2)
007354: Aug 7 16:12:36.602: //24448/7890FA6DB7E8/CCAPI/cc_api_caps_ind:
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
007355: Aug 7 16:12:36.602: //24445/7890FA6DB7E8/CCAPI/cc_api_caps_ack:
Destination Interface=0x0, Destination Call Id=24448, Source Call Id=24445,
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=1)
007356: Aug 7 16:12:36.602: //24448/7890FA6DB7E8/CCAPI/cc_api_event_indication:
Event=160, Call Id=24448
007357: Aug 7 16:12:36.602: //24448/7890FA6DB7E8/CCAPI/cc_api_event_indication:
Event Is Sent To Conferenced SPI(s) Directly
007358: Aug 7 16:12:36.602: //24448/7890FA6DB7E8/CCAPI/cc_api_call_connected:
Interface=0x872E9C18, Data Bitmask=0x1, Progress Indication=NULL(0),
Connection Handle=0
007359: Aug 7 16:12:36.602: //24448/7890FA6DB7E8/CCAPI/cc_api_call_connected:
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
007360: Aug 7 16:12:36.606: //24445/7890FA6DB7E8/CCAPI/ccConferenceCreate:
(confID=0x88F8D360, callID1=0x5F7D, gcid=78919695-C03E11E0-B7EBD9FD-5E036138, tag=0x0)
007361: Aug 7 16:12:36.606: //24448/7890FA6DB7E8/CCAPI/ccConferenceCreate:
(confID=0x88F8D360, callID2=0x5F80, gcid=78919695-C03E11E0-B7EBD9FD-5E036138, tag=0x0)
007362: Aug 7 16:12:36.606: //24445/7890FA6DB7E8/CCAPI/ccConferenceCreate:
Conference Id=0x88F8D360, Call Id1=24445, Call Id2=24448, Tag=0x0
007363: Aug 7 16:12:36.606: //24445/7890FA6DB7E8/CCAPI/ccConferenceCreate:
007364: Aug 7 16:12:36.606: ccConferenceCreate: ret1=0, codecMask1=1, bytes1=160, negot1=1, dtmf1=6
ret2=0, codecMask2=1, bytes2=160, negot2=1, dtmf2=8,
tx_dynamic_pt1=0, rx_dynamic_pt1=0, codec_mode1=0, params_bitmap1 =0
tx_dynamic_pt2=0, rx_dynamic_pt2=0, codec_mode2=0, params_bitmap2 =0
007365: Aug 7 16:12:36.606: //24445/7890FA6DB7E8/CCAPI/ccConferenceCreate:
delay media to slow start case, codec negotation is not done
007366: Aug 7 16:12:36.606: //24445/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
007367: Aug 7 16:12:36.606: cc_api_get_xcode_stream : 4682
007368: Aug 7 16:12:36.606: //24445/7890FA6DB7E8/CCAPI/cc_api_bridge_done:
Conference Id=0x20, Source Interface=0x872E9C18, Source Call Id=24445,
Destination Call Id=24448, Disposition=0x0, Tag=0x0
007369: Aug 7 16:12:36.606: //24448/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
007370: Aug 7 16:12:36.606: cc_api_get_xcode_stream : 4682
007371: Aug 7 16:12:36.606: //24448/7890FA6DB7E8/CCAPI/cc_api_bridge_done:
Conference Id=0x20, Source Interface=0x872E9C18, Source Call Id=24448,
Destination Call Id=24445, Disposition=0x0, Tag=0x0
007372: Aug 7 16:12:36.606: //24445/7890FA6DB7E8/CCAPI/cc_generic_bridge_done:
007373: Aug 7 16:12:36.606: //24445/7890FA6DB7E8/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x20, Destination Call Id=24448)
007374: Aug 7 16:12:36.606: //24448/7890FA6DB7E8/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x20, Destination Call Id=24445)
007375: Aug 7 16:12:36.606: //24445/7890FA6DB7E8/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x20, Call Id1=24445, Call Id2=24448
007376: Aug 7 16:12:36.610: //24448/8482D72EB7F2/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:399@10.1.10.1:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.1.10.2:5060;branch=z9hG4bK13371908
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
007377: Aug 7 16:12:36.610: //24445/7890FA6DB7E8/CCAPI/ccCallConnect:
Progress Indication=NULL(0), Data Bitmask=0x1
007378: Aug 7 16:12:36.610: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007379: Aug 7 16:12:36.610: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007380: Aug 7 16:12:36.610: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007381: Aug 7 16:12:36.610: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
007382: Aug 7 16:12:36.610: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007383: Aug 7 16:12:36.610: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007384: Aug 7 16:12:36.610: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=NO_MATCH(-1)
007385: Aug 7 16:12:36.610: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007386: Aug 7 16:12:36.610: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007387: Aug 7 16:12:36.610: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007388: Aug 7 16:12:36.610: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007389: Aug 7 16:12:36.610: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
007390: Aug 7 16:12:36.610: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
007391: Aug 7 16:12:36.610: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007392: Aug 7 16:12:36.610: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007393: Aug 7 16:12:36.610: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007394: Aug 7 16:12:36.610: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007395: Aug 7 16:12:36.610: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
007396: Aug 7 16:12:36.610: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007397: Aug 7 16:12:36.610: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007398: Aug 7 16:12:36.614: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6610
007399: Aug 7 16:12:36.614: //24445/7890FA6DB7E8/CCAPI/ccCallConnect:
Call Entry(Connected=TRUE, Responsed=TRUE)
007400: Aug 7 16:12:36.614: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=CALLERS-NUMBER, Called Number=, Voice-Interface=0x0,
007401: Aug 7 16:12:36.614: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ANSWER; Calling Number=CALLERS-NUMBER
007402: Aug 7 16:12:36.614: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007403: Aug 7 16:12:36.614: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=, Expanded String=, Calling Number=CALLERS-NUMBERT
007404: Aug 7 16:12:36.614: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
007405: Aug 7 16:12:36.614: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
007406: Aug 7 16:12:36.614: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ORIGINATE; Calling Number=CALLERS-NUMBER
007407: Aug 7 16:12:36.614: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007408: Aug 7 16:12:36.614: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007409: Aug 7 16:12:36.614: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
007410: Aug 7 16:12:36.614: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
007411: Aug 7 16:12:36.614: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007412: Aug 7 16:12:36.614: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007413: Aug 7 16:12:36.614: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6610
007414: Aug 7 16:12:36.618: //24445/7890FA6DB7E8/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To:
CSeq: 102 INVITE
Contact:
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 230
v=0
o=CiscoSystemsSIP-GW-UserAgent 1310 9361 IN IP4 UC520-PRIVATE-IP
s=SIP Call
t=0 0
m=audio 18366 RTP/AVP 0 101
c=IN IP4 UC520-PRIVATE-IP
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
007415: Aug 7 16:12:36.670: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:DIALLED-NUMBER@UC520-PRIVATE-IP:5060 SIP/2.0
Via: SIP/2.0/UDP 88.208.249.40:5060;branch=z9hG4bK1d2e.c20225b1.2
Max-Forwards: 69
To:
Contact:
CSeq: 102 ACK
User-Agent: ContactPro4
Content-Length: 0
007416: Aug 7 16:12:59.690: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:DIALLED-NUMBER@UC520-PRIVATE-IP:5060 SIP/2.0
Via: SIP/2.0/UDP 88.208.249.40:5060;branch=z9hG4bK2d2e.7a9bcae1.0
Max-Forwards: 69
To:
CSeq: 103 BYE
X-Asterisk-HangupCause: Normal Clearing
X-Asterisk-HangupCauseCode: 16
Content-Length: 0
007417: Aug 7 16:12:59.690: //24448/7890FA6DB7E8/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Null,
Tone Direction=Sum Network, Params=0x0, Call Id=24448
007418: Aug 7 16:12:59.690: //24445/7890FA6DB7E8/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x872E9C18, Call Id=24445
007419: Aug 7 16:12:59.690: //24445/7890FA6DB7E8/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
007420: Aug 7 16:12:59.690: //24445/7890FA6DB7E8/CCAPI/ccConferenceDestroy:
Conference Id=0x20, Tag=0x0
007421: Aug 7 16:12:59.690: //24445/7890FA6DB7E8/CCAPI/cc_api_bridge_drop_done:
007422: Aug 7 16:12:59.690: //24448/7890FA6DB7E8/CCAPI/cc_api_bridge_drop_done:
007423: Aug 7 16:12:59.690: //24445/7890FA6DB7E8/CCAPI/cc_generic_bridge_done:
007424: Aug 7 16:12:59.694: //24445/7890FA6DB7E8/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
007425: Aug 7 16:12:59.694: //24445/7890FA6DB7E8/CCAPI/ccCallDisconnect:
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
007426: Aug 7 16:12:59.694: //24448/7890FA6DB7E8/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
007427: Aug 7 16:12:59.694: //24448/7890FA6DB7E8/CCAPI/ccCallDisconnect:
007428: Aug 7 16:12:59.694: //24445/7890FA6DB7E8/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x872E9C18, Tag=0x0, Call Id=24445,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
007429: Aug 7 16:12:59.694: //-1/7890FA6DB7E8/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x8A46D11C; count=3
007430: Aug 7 16:12:59.694: //-1/7890FA6DB7E8/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x88EA7CF4
007431: Aug 7 16:12:59.694: //24445/7890FA6DB7E8/CCAPI/cc_api_call_disconnect_done:
007432: Aug 7 16:12:59.694: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007433: Aug 7 16:12:59.694: :cc_free_feature_vsa freeing 88DF5C38
007434: Aug 7 16:12:59.694: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007435: Aug 7 16:12:59.694: vsacount in free is 3
007436: Aug 7 16:12:59.694: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007437: Aug 7 16:12:59.694: vsacount in free is 2
007438: Aug 7 16:12:59.698: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To:
Date: Sun, 07 Aug 2011 15:12:59 GMT
CSeq: 103 BYE
Reason: Q.850;cause=16
Content-Length: 0
007439: Aug 7 16:12:59.698: //24448/8482D72EB7F2/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:399@10.1.10.1:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.1.10.2:5060;branch=z9hG4bK13386D8
Max-Forwards: 70
Timestamp: 1312729979
CSeq: 102 BYE
Content-Length: 0
007440: Aug 7 16:12:59.706: //24448/8482D72EB7F2/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 102 BYE
Content-Length: 0
007441: Aug 7 16:12:59.706: //24448/7890FA6DB7E8/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x872E9C18, Tag=0x0, Call Id=24448,
007442: Aug 7 16:12:59.706: //-1/7890FA6DB7E8/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x0
007443: Aug 7 16:12:59.706: //24448/7890FA6DB7E8/CCAPI/cc_api_call_disconnect_done:
007444: Aug 7 16:12:59.706: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007445: Aug 7 16:12:59.706: :cc_free_feature_vsa freeing 88DF5ED8
007446: Aug 7 16:12:59.706: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007447: Aug 7 16:12:59.706: vsacount in free is 1
007448: Aug 7 16:12:59.706: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007449: Aug 7 16:12:59.706: vsacount in free is 0
007450: Aug 7 16:13:00.454: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:A800201@10.1.10.2:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.1.10.1:5060;branch=z9hG4bKaDmQfum218LqaclK01N0tQ~~23
Max-Forwards: 70
To:
Call-ID: 131272998042724@10.1.10.1
CSeq: 100 INVITE
Content-Length: 126
Contact: <399>399>
Cisco-Gcid: A4CDDE0B-0131-1000-4DB7-9A2F8D1F51CC
v=0
o=CUE 13491745 2 IN IP4 10.1.10.1
s=SIP Call
c=IN IP4 10.1.10.1
t=0 0
m=audio 32802 RTP/AVP 0
007451: Aug 7 16:13:00.458: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=A800201, Called Number=A800201, Peer Info Type=DIALPEER_INFO_SPEECH
007452: Aug 7 16:13:00.458: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=A800201
007453: Aug 7 16:13:00.458: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=A800201, Expanded String=A800201, Calling Number=A800201T
007454: Aug 7 16:13:00.458: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Outgoing Dial-peer=20016 Is Matched
007455: Aug 7 16:13:00.458: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007456: Aug 7 16:13:00.458: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=A800201, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
007457: Aug 7 16:13:00.458: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=20016
007458: Aug 7 16:13:00.458: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007459: Aug 7 16:13:00.458: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007460: Aug 7 16:13:00.458: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007461: Aug 7 16:13:00.458: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007462: Aug 7 16:13:00.458: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
007463: Aug 7 16:13:00.458: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
007464: Aug 7 16:13:00.458: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007465: Aug 7 16:13:00.458: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007466: Aug 7 16:13:00.458: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007467: Aug 7 16:13:00.458: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007468: Aug 7 16:13:00.458: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
007469: Aug 7 16:13:00.458: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007470: Aug 7 16:13:00.458: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007471: Aug 7 16:13:00.458: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6610
007472: Aug 7 16:13:00.462: //-1/92CD49A6B7F7/RXRULE/regxrule_profile_translate_internal: number=399 type=unknown plan=unknown numbertype=calling
007473: Aug 7 16:13:00.462: //-1/92CD49A6B7F7/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
007474: Aug 7 16:13:00.462: //-1/92CD49A6B7F7/RXRULE/regxrule_profile_match_internal: Error: ruleset for calling number not found
007475: Aug 7 16:13:00.462: //-1/92CD49A6B7F7/RXRULE/regxrule_profile_translate_internal: No match: number=399 type=unknown plan=unknown
007476: Aug 7 16:13:00.462: //-1/92CD49A6B7F7/RXRULE/regxrule_profile_translate_internal: number=A800201 type=unknown plan=unknown numbertype=called
007477: Aug 7 16:13:00.462: //-1/92CD49A6B7F7/RXRULE/regxrule_match: No match; number=A800201 rule precedence=1
007478: Aug 7 16:13:00.462: //-1/92CD49A6B7F7/RXRULE/regxrule_match: No match; number=A800201 rule precedence=2
007479: Aug 7 16:13:00.462: //-1/92CD49A6B7F7/RXRULE/regxrule_profile_match_internal: No match found
007480: Aug 7 16:13:00.462: //-1/92CD49A6B7F7/RXRULE/regxrule_profile_translate_internal: No match: number=A800201 type=unknown plan=unknown
007481: Aug 7 16:13:00.462: //-1/92CD49A6B7F7/RXRULE/regxrule_profile_translate_internal: number= type=unknown plan=unknown numbertype=redirect-called
007482: Aug 7 16:13:00.462: //-1/92CD49A6B7F7/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
007483: Aug 7 16:13:00.462: //-1/92CD49A6B7F7/RXRULE/regxrule_profile_match_internal: Error: ruleset for redirect-called number not found
007484: Aug 7 16:13:00.462: //-1/92CD49A6B7F7/RXRULE/regxrule_profile_translate_internal: No match: number= type=unknown plan=unknown
007485: Aug 7 16:13:00.462: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007486: Aug 7 16:13:00.462: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007487: Aug 7 16:13:00.462: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007488: Aug 7 16:13:00.462: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007489: Aug 7 16:13:00.462: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
007490: Aug 7 16:13:00.462: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
007491: Aug 7 16:13:00.462: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007492: Aug 7 16:13:00.462: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007493: Aug 7 16:13:00.462: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007494: Aug 7 16:13:00.462: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007495: Aug 7 16:13:00.462: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
007496: Aug 7 16:13:00.462: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007497: Aug 7 16:13:00.462: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007498: Aug 7 16:13:00.462: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6610
007499: Aug 7 16:13:00.462: //-1/92CD49A6B7F7/DPM/dpAssociateIncomingPeerCore:
Calling Number=399, Called Number=A800201, Voice-Interface=0x0,
007500: Aug 7 16:13:00.466: //-1/92CD49A6B7F7/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_VIA_URI; URI=sip:10.1.10.1:5060
007501: Aug 7 16:13:00.466: //-1/92CD49A6B7F7/DPM/dpMatchPeertype:
007502: Aug 7 16:13:00.466: //-1/92CD49A6B7F7/DPM/dpMatchCore:
007503: Aug 7 16:13:00.466: //-1/92CD49A6B7F7/DPM/dpMatchCore:
Result=-1
007504: Aug 7 16:13:00.466: //-1/92CD49A6B7F7/DPM/dpMatchPeertype:exit@5982
007505: Aug 7 16:13:00.466: //-1/92CD49A6B7F7/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_REQUEST_URI; URI=sip:A800201@10.1.10.2:5060;transport=udp
007506: Aug 7 16:13:00.466: //-1/92CD49A6B7F7/DPM/dpMatchPeertype:
007507: Aug 7 16:13:00.466: //-1/92CD49A6B7F7/DPM/dpMatchCore:
007508: Aug 7 16:13:00.466: //-1/92CD49A6B7F7/DPM/dpMatchCore:
Result=-1
007509: Aug 7 16:13:00.466: //-1/92CD49A6B7F7/DPM/dpMatchPeertype:exit@5982
007510: Aug 7 16:13:00.466: //-1/92CD49A6B7F7/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_TO_URI; URI=sip:A800201@10.1.10.2:5060
007511: Aug 7 16:13:00.466: //-1/92CD49A6B7F7/DPM/dpMatchPeertype:
007512: Aug 7 16:13:00.466: //-1/92CD49A6B7F7/DPM/dpMatchCore:
007513: Aug 7 16:13:00.466: //-1/92CD49A6B7F7/DPM/dpMatchCore:
Result=-1
007514: Aug 7 16:13:00.466: //-1/92CD49A6B7F7/DPM/dpMatchPeertype:exit@5982
007515: Aug 7 16:13:00.466: //-1/92CD49A6B7F7/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_FROM_URI; URI=sip:399@10.1.10.1
007516: Aug 7 16:13:00.466: //-1/92CD49A6B7F7/DPM/dpMatchPeertype:
007517: Aug 7 16:13:00.466: //-1/92CD49A6B7F7/DPM/dpMatchCore:
007518: Aug 7 16:13:00.466: //-1/92CD49A6B7F7/DPM/dpMatchCore:
Result=-1
007519: Aug 7 16:13:00.466: //-1/92CD49A6B7F7/DPM/dpMatchPeertype:exit@5982
007520: Aug 7 16:13:00.466: //-1/92CD49A6B7F7/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_INCOMING_DNIS; Called Number=A800201
007521: Aug 7 16:13:00.466: //-1/92CD49A6B7F7/DPM/dpMatchPeertype:
007522: Aug 7 16:13:00.466: //-1/92CD49A6B7F7/DPM/dpMatchCore:
007523: Aug 7 16:13:00.466: //-1/92CD49A6B7F7/DPM/MatchNextPeer:
Result=Success(0); Incoming Dial-peer=6 Is Matched
007524: Aug 7 16:13:00.466: //-1/92CD49A6B7F7/DPM/MatchNextPeer:
Result=Success(0); Incoming Dial-peer=1000 Is Matched
007525: Aug 7 16:13:00.466: //-1/92CD49A6B7F7/DPM/MatchNextPeer:
Result=Success(0); Incoming Dial-peer=1005 Is Matched
007526: Aug 7 16:13:00.466: //-1/92CD49A6B7F7/DPM/dpMatchPeertype:exit@5982
007527: Aug 7 16:13:00.466: //-1/92CD49A6B7F7/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=1005
007528: Aug 7 16:13:00.466: //-1/92CD49A6B7F7/DPM/dpMatchSafModulePlugin:
007529: Aug 7 16:13:00.466: //-1/92CD49A6B7F7/DPM/dpAssociateIncomingPeerSPI:exit@6561
007530: Aug 7 16:13:00.470: //24449/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
Call Entry Is Not Found
007531: Aug 7 16:13:00.470: //-1/92CD49A6B7F7/CCAPI/cc_api_display_ie_subfields:
cisco-username=399
cisco-ani=399
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=A800201
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
007532: Aug 7 16:13:00.470: //-1/92CD49A6B7F7/CCAPI/cc_api_call_setup_ind_common:
Interface=0x872E9C18, Call Info(
Calling Number=399,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=A800201(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=1005, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=24449
007533: Aug 7 16:13:00.470: //-1/92CD49A6B7F7/CCAPI/ccCheckClipClir:
In: Calling Number=399(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
007534: Aug 7 16:13:00.470: //-1/92CD49A6B7F7/CCAPI/ccCheckClipClir:
Out: Calling Number=399(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
007535: Aug 7 16:13:00.470: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007536: Aug 7 16:13:00.470: :cc_get_feature_vsa malloc success
007537: Aug 7 16:13:00.470: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007538: Aug 7 16:13:00.470: cc_get_feature_vsa count is 1
007539: Aug 7 16:13:00.470: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007540: Aug 7 16:13:00.470: :FEATURE_VSA attributes are: feature_name:0,feature_time:2296339744,feature_id:13885
007541: Aug 7 16:13:00.470: //24449/92CD49A6B7F7/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=399(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=A800201(TON=Unknown, NPI=Unknown))
007542: Aug 7 16:13:00.470: //-1/92CD49A6B7F7/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x8A46C7D4; count=1
007543: Aug 7 16:13:00.470: //-1/92CD49A6B7F7/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x88EA9DE8
007544: Aug 7 16:13:00.470: //24449/92CD49A6B7F7/CCAPI/cc_process_call_setup_ind:
Event=0x87F2B738
007545: Aug 7 16:13:00.474: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number A800201
007546: Aug 7 16:13:00.474: //24449/92CD49A6B7F7/CCAPI/ccCallSetContext:
Context=0x86058DF4
007547: Aug 7 16:13:00.474: //24449/92CD49A6B7F7/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 24449 with tag 1005 to app "_ManagedAppProcess_Default"
007548: Aug 7 16:13:00.474: //-1/92CD49A6B7F7/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x8A46C7D4; count=1
007549: Aug 7 16:13:00.474: //24449/92CD49A6B7F7/CCAPI/ccCallProceeding:
007550: Aug 7 16:13:00.474: //-1/92CD49A6B7F7/DPM/dpMatchPeersCore:
Calling Number=, Called Number=A800201, Peer Info Type=DIALPEER_INFO_SPEECH
007551: Aug 7 16:13:00.474: //-1/92CD49A6B7F7/DPM/dpMatchPeersCore:
007552: Aug 7 16:13:00.474: //-1/92CD49A6B7F7/DPM/dpMatchCore:
007553: Aug 7 16:13:00.474: //-1/92CD49A6B7F7/DPM/MatchNextPeer:
007554: Aug 7 16:13:00.474: //-1/92CD49A6B7F7/DPM/dpMatchPeersCore:
007555: Aug 7 16:13:00.474: //-1/92CD49A6B7F7/DPM/dpMatchSafModulePlugin:
dialstring=A800201, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
007556: Aug 7 16:13:00.474: //-1/92CD49A6B7F7/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
007557: Aug 7 16:13:00.474: //-1/92CD49A6B7F7/DPM/dpMatchPeersCore:
007558: Aug 7 16:13:00.474: //-1/92CD49A6B7F7/DPM/dpMatchPeersCore:
007559: Aug 7 16:13:00.474: //-1/92CD49A6B7F7/DPM/dpMatchCore:
007560: Aug 7 16:13:00.474: //-1/92CD49A6B7F7/DPM/MatchNextPeer:
007561: Aug 7 16:13:00.474: //-1/92CD49A6B7F7/DPM/dpMatchPeersCore:
007562: Aug 7 16:13:00.474: //-1/92CD49A6B7F7/DPM/dpMatchSafModulePlugin:
007563: Aug 7 16:13:00.474: //-1/92CD49A6B7F7/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
007564: Aug 7 16:13:00.474: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007565: Aug 7 16:13:00.474: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007566: Aug 7 16:13:00.474: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007567: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007568: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007569: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007570: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
007571: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=A800201, Called Number=, Voice-Interface=0x0,
007572: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ANSWER; Calling Number=A800201
007573: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Is Incoming=TRUE, Number Expansion=FALSE
007574: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=, Expanded String=, Calling Number=A800201T
Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
007575: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
007576: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
007577: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ORIGINATE; Calling Number=A800201
007578: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007579: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007580: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Incoming Dial-peer=20016 Is Matched
007581: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
007582: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007583: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007584: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6610
007585: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007586: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007587: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007588: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007589: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
007590: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
007591: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007592: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007593: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007594: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007595: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
007596: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007597: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007598: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6610
007599: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007600: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007601: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007602: Aug 7 16:13:00.478: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007603: Aug 7 16:13:00.482: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007604: Aug 7 16:13:00.482: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007605: Aug 7 16:13:00.482: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
007606: Aug 7 16:13:00.482: //-1/92CD49A6B7F7/DPM/dpMatchPeersCore:
007607: Aug 7 16:13:00.482: //-1/92CD49A6B7F7/DPM/dpMatchPeersCore:
007608: Aug 7 16:13:00.482: //-1/92CD49A6B7F7/DPM/dpMatchCore:
007609: Aug 7 16:13:00.482: //-1/92CD49A6B7F7/DPM/MatchNextPeer:
007610: Aug 7 16:13:00.482: //-1/92CD49A6B7F7/DPM/dpMatchPeersCore:
007611: Aug 7 16:13:00.482: //-1/92CD49A6B7F7/DPM/dpMatchSafModulePlugin:
007612: Aug 7 16:13:00.482: //-1/92CD49A6B7F7/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
007613: Aug 7 16:13:00.482: //-1/92CD49A6B7F7/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x8A46C7D4; count=2
007614: Aug 7 16:13:00.482: //-1/92CD49A6B7F7/RXRULE/regxrule_dp_translate: No profile found in peer 20016 for outgoing direction
007615: Aug 7 16:13:00.482: //-1/92CD49A6B7F7/RXRULE/regxrule_dp_translate: calling_number=399 calling_octet=0x0
called_number=A800201 called_octet=0x0
redirect_number= redirect_type=0 redirect_plan=0 redirect_PI=-1 redirect_SI=-1
007616: Aug 7 16:13:00.482: //24449/92CD49A6B7F7/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=20016, Params=0x8604C9B4, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
007617: Aug 7 16:13:00.482: //-1/92CD49A6B7F7/RXRULE/regxrule_vp_translate: No profile found in voice port or trunk group for outgoing direction
007618: Aug 7 16:13:00.482: //-1/92CD49A6B7F7/RXRULE/regxrule_vp_translate: calling_number=399 calling_octet=0x0
007619: Aug 7 16:13:00.482: //24449/92CD49A6B7F7/CCAPI/ccCheckClipClir:
007620: Aug 7 16:13:00.482: //24449/92CD49A6B7F7/CCAPI/ccCheckClipClir:
007621: Aug 7 16:13:00.482: //24449/92CD49A6B7F7/CCAPI/ccCallSetupRequest:
Destination Pattern=A800..., Called Number=A800201, Digit Strip=TRUE
007622: Aug 7 16:13:00.482: //24449/92CD49A6B7F7/CCAPI/ccCallSetupRequest:
Redirect Number=, Display Info=
Account Number=399, Final Destination Flag=TRUE,
Guid=92CD49A6-C03E-11E0-B7F7-D9FD5E036138, Outgoing Dial-peer=20016
007623: Aug 7 16:13:00.482: //24449/92CD49A6B7F7/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=399
----- ccCallInfo IE subfields -----
cisco-ani=399
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=A800201
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
final_redirectNumber =
hunt_group_timeout =0
007624: Aug 7 16:13:00.482: //24449/92CD49A6B7F7/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x8887D9EC, Interface Type=6, Destination=, Mode=0x0,
Call Params(Calling Number=399,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=A800201(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=20016, Call Count On=FALSE,
007625: Aug 7 16:13:00.486: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007626: Aug 7 16:13:00.486: :cc_get_feature_vsa malloc success
007627: Aug 7 16:13:00.486: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007628: Aug 7 16:13:00.486: cc_get_feature_vsa count is 2
007629: Aug 7 16:13:00.486: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007630: Aug 7 16:13:00.486: :FEATURE_VSA attributes are: feature_name:0,feature_time:2296340192,feature_id:13886
007631: Aug 7 16:13:00.486: //24450/92CD49A6B7F7/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
007632: Aug 7 16:13:00.486: //24450/92CD49A6B7F7/CCAPI/ccCallSetContext:
Context=0x8604C964
007633: Aug 7 16:13:00.486: //24449/92CD49A6B7F7/CCAPI/ccSaveDialpeerTag:
007634: Aug 7 16:13:00.486: //24450/92CD49A6B7F7/CCAPI/cc_api_update_call_info:
Interface=0x8887D9EC, Call Id=0x5F82
007635: Aug 7 16:13:00.490: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007636: Aug 7 16:13:00.490: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007637: Aug 7 16:13:00.490: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007638: Aug 7 16:13:00.490: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007639: Aug 7 16:13:00.490: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007640: Aug 7 16:13:00.490: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007641: Aug 7 16:13:00.490: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
007642: Aug 7 16:13:00.490: //24450/92CD49A6B7F7/CCAPI/cc_api_call_proceeding:
Interface=0x8887D9EC, Progress Indication=NULL(0)
007643: Aug 7 16:13:00.490: //24450/92CD49A6B7F7/CCAPI/cc_api_call_alert:
Interface=0x8887D9EC, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
007644: Aug 7 16:13:00.494: //24450/92CD49A6B7F7/CCAPI/cc_api_call_alert:
007645: Aug 7 16:13:00.494: //24449/92CD49A6B7F7/CCAPI/ccCallAlert:
007646: Aug 7 16:13:00.494: //24449/92CD49A6B7F7/CCAPI/ccCallAlert:
007647: Aug 7 16:13:00.494: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007648: Aug 7 16:13:00.494: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007649: Aug 7 16:13:00.494: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007650: Aug 7 16:13:00.494: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007651: Aug 7 16:13:00.494: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Result=Success(0) after DP_MATCH_DEST
007652: Aug 7 16:13:00.494: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
007653: Aug 7 16:13:00.494: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
007654: Aug 7 16:13:00.494: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=A800000, Called Number=, Voice-Interface=0x0,
007655: Aug 7 16:13:00.494: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ANSWER; Calling Number=A800000
007656: Aug 7 16:13:00.494: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007657: Aug 7 16:13:00.494: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=, Expanded String=, Calling Number=A800000T
007658: Aug 7 16:13:00.494: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
007659: Aug 7 16:13:00.494: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
007660: Aug 7 16:13:00.494: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ORIGINATE; Calling Number=A800000
007661: Aug 7 16:13:00.494: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007662: Aug 7 16:13:00.494: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007663: Aug 7 16:13:00.494: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007664: Aug 7 16:13:00.494: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
007665: Aug 7 16:13:00.494: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007666: Aug 7 16:13:00.494: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007667: Aug 7 16:13:00.494: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6610
007668: Aug 7 16:13:00.498: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007669: Aug 7 16:13:00.498: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007670: Aug 7 16:13:00.498: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
007671: Aug 7 16:13:00.498: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007672: Aug 7 16:13:00.498: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007673: Aug 7 16:13:00.498: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007674: Aug 7 16:13:00.498: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
007675: Aug 7 16:13:00.498: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007676: Aug 7 16:13:00.498: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007677: Aug 7 16:13:00.498: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007678: Aug 7 16:13:00.498: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007679: Aug 7 16:13:00.498: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007680: Aug 7 16:13:00.498: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007681: Aug 7 16:13:00.498: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
007682: Aug 7 16:13:00.498: //24450/92CD49A6B7F7/CCAPI/ccCallFeature:
Feature Type=25, Call Id=24450
007683: Aug 7 16:13:00.498: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007684: Aug 7 16:13:00.498: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007685: Aug 7 16:13:00.498: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007686: Aug 7 16:13:00.498: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007687: Aug 7 16:13:00.498: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007688: Aug 7 16:13:00.498: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007689: Aug 7 16:13:00.498: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
007690: Aug 7 16:13:00.498: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=, Called Number=A800000, Peer Info Type=DIALPEER_INFO_SPEECH
007691: Aug 7 16:13:00.498: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=A800000
007692: Aug 7 16:13:00.498: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=A800000, Expanded String=A800000, Calling Number=
007693: Aug 7 16:13:00.498: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007694: Aug 7 16:13:00.498: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007695: Aug 7 16:13:00.502: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007696: Aug 7 16:13:00.502: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
007697: Aug 7 16:13:00.502: //24449/92CD49A6B7F7/CCAPI/ccCallNotify:
Data Bitmask=0x7, Call Id=24449
007698: Aug 7 16:13:00.502: //24449/92CD49A6B7F7/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To:
Date: Sun, 07 Aug 2011 15:13:00 GMT
CSeq: 100 INVITE
Content-Length: 0
007699: Aug 7 16:13:00.502: //24449/92CD49A6B7F7/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To:
CSeq: 100 INVITE
Contact:
Content-Length: 0
007700: Aug 7 16:13:02.722: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:UC520-PUBLIC-IP:56225 SIP/2.0
Via: SIP/2.0/UDP 88.208.249.40:5060;branch=z9hG4bK381a.0.0
To: sip:UC520-PUBLIC-IP:56225
Call-ID: aa9e8761-9b8954d4-601e23@88.208.249.40
CSeq: 1 OPTIONS
Content-Length: 0
007701: Aug 7 16:13:02.722: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=voipnow, Called Number=, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
007702: Aug 7 16:13:02.722: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ANSWER; Calling Number=voipnow
007703: Aug 7 16:13:02.722: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007704: Aug 7 16:13:02.722: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=, Expanded String=, Calling Number=voipnowT
007705: Aug 7 16:13:02.722: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
007706: Aug 7 16:13:02.722: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
007707: Aug 7 16:13:02.722: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ORIGINATE; Calling Number=voipnow
007708: Aug 7 16:13:02.722: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007709: Aug 7 16:13:02.722: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007710: Aug 7 16:13:02.722: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
007711: Aug 7 16:13:02.722: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
007712: Aug 7 16:13:02.722: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=NO_MATCH(-1) After All Match Rules Attempt
007713: Aug 7 16:13:02.722: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
007714: Aug 7 16:13:02.722: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6610
007715: Aug 7 16:13:02.722: //-1/94275B11B7FC/DPM/dpAssociateIncomingPeerCore:
007716: Aug 7 16:13:02.722: //-1/94275B11B7FC/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_VIA_URI; URI=sip:88.208.249.40:5060
007717: Aug 7 16:13:02.726: //-1/94275B11B7FC/DPM/dpMatchPeertype:
007718: Aug 7 16:13:02.726: //-1/94275B11B7FC/DPM/dpMatchCore:
007719: Aug 7 16:13:02.726: //-1/94275B11B7FC/DPM/dpMatchCore:
Result=-1
007720: Aug 7 16:13:02.726: //-1/94275B11B7FC/DPM/dpMatchPeertype:exit@5982
007721: Aug 7 16:13:02.726: //-1/94275B11B7FC/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_REQUEST_URI; URI=sip:UC520-PUBLIC-IP:56225
007722: Aug 7 16:13:02.726: //-1/94275B11B7FC/DPM/dpMatchPeertype:
007723: Aug 7 16:13:02.726: //-1/94275B11B7FC/DPM/dpMatchCore:
007724: Aug 7 16:13:02.726: //-1/94275B11B7FC/DPM/dpMatchCore:
Result=-1
007725: Aug 7 16:13:02.726: //-1/94275B11B7FC/DPM/dpMatchPeertype:exit@5982
007726: Aug 7 16:13:02.726: //-1/94275B11B7FC/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_TO_URI; URI=sip:UC520-PUBLIC-IP:56225
007727: Aug 7 16:13:02.726: //-1/94275B11B7FC/DPM/dpMatchPeertype:
007728: Aug 7 16:13:02.726: //-1/94275B11B7FC/DPM/dpMatchCore:
007729: Aug 7 16:13:02.726: //-1/94275B11B7FC/DPM/dpMatchCore:
Result=-1
007730: Aug 7 16:13:02.726: //-1/94275B11B7FC/DPM/dpMatchPeertype:exit@5982
007731: Aug 7 16:13:02.726: //-1/94275B11B7FC/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_FROM_URI; URI=sip:voipnow@88.208.249.40
007732: Aug 7 16:13:02.726: //-1/94275B11B7FC/DPM/dpMatchPeertype:
007733: Aug 7 16:13:02.726: //-1/94275B11B7FC/DPM/dpMatchCore:
007734: Aug 7 16:13:02.726: //-1/94275B11B7FC/DPM/dpMatchCore:
Result=-1
007735: Aug 7 16:13:02.726: //-1/94275B11B7FC/DPM/dpMatchPeertype:exit@5982
007736: Aug 7 16:13:02.726: //-1/94275B11B7FC/DPM/dpAssociateIncomingPeerCore:
007737: Aug 7 16:13:02.726: //-1/94275B11B7FC/DPM/dpMatchPeertype:
007738: Aug 7 16:13:02.726: //-1/94275B11B7FC/DPM/dpMatchCore:
007739: Aug 7 16:13:02.726: //-1/94275B11B7FC/DPM/dpMatchCore:
Result=-1
007740: Aug 7 16:13:02.726: //-1/94275B11B7FC/DPM/dpMatchPeertype:exit@5982
007741: Aug 7 16:13:02.726: //-1/94275B11B7FC/DPM/dpAssociateIncomingPeerCore:
007742: Aug 7 16:13:02.726: //-1/94275B11B7FC/DPM/dpMatchPeertype:
007743: Aug 7 16:13:02.726: //-1/94275B11B7FC/DPM/dpMatchCore:
007744: Aug 7 16:13:02.726: //-1/94275B11B7FC/DPM/dpMatchCore:
Result=-1
007745: Aug 7 16:13:02.726: //-1/94275B11B7FC/DPM/dpMatchPeertype:exit@5982
007746: Aug 7 16:13:02.726: //-1/94275B11B7FC/DPM/dpAssociateIncomingPeerCore:
007747: Aug 7 16:13:02.726: //-1/94275B11B7FC/DPM/dpMatchSafModulePlugin:
007748: Aug 7 16:13:02.726: //-1/94275B11B7FC/DPM/dpAssociateIncomingPeerSPI:exit@6561
007749: Aug 7 16:13:02.730: //24451/94275B11B7FC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:UC520-PUBLIC-IP:56225;tag=188D3CA8-5DC
Date: Sun, 07 Aug 2011 15:13:02 GMT
CSeq: 1 OPTIONS
Accept: application/sdp
Content-Length: 178
v=0
o=CiscoSystemsSIP-GW-UserAgent 4332 3833 IN IP4 UC520-PRIVATE-IP
s=SIP Call
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15 3
007750: Aug 7 16:13:03.518: //-1/xxxxxxxxxxxx/RXRULE/regxrule_get_profile_from_trunkgroup_internal:
Voice port 0x88A3D9F0 dsl=-1 timeslot=0 does not belong to any trunk group
007751: Aug 7 16:13:03.518: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=BCD, Called Number=, Voice-Interface=0x88A3D9F0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
007752: Aug 7 16:13:03.518: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ANSWER; Calling Number=BCD
007753: Aug 7 16:13:03.518: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007754: Aug 7 16:13:03.518: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=, Expanded String=, Calling Number=BCDT
007755: Aug 7 16:13:03.518: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
007756: Aug 7 16:13:03.518: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
007757: Aug 7 16:13:03.518: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ORIGINATE; Calling Number=BCD
007758: Aug 7 16:13:03.518: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007759: Aug 7 16:13:03.518: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007760: Aug 7 16:13:03.518: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Incoming Dial-peer=20001 Is Matched
007761: Aug 7 16:13:03.518: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
007762: Aug 7 16:13:03.518: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=20001
007763: Aug 7 16:13:03.518: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007764: Aug 7 16:13:03.518: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerSPI:exit@6561
007765: Aug 7 16:13:03.522: //-1/94A16CFEB7FD/CCAPI/cc_api_display_ie_subfields:
cisco-username=
cisco-ani=BCD
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=0 fwd_final_type =0
007766: Aug 7 16:13:03.522: //-1/94A16CFEB7FD/CCAPI/cc_api_call_setup_ind_common:
Interface=0x88A3D9F0, Call Info(
Calling Number=BCD,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Incoming Dial-peer=20001, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
007767: Aug 7 16:13:03.522: //-1/94A16CFEB7FD/CCAPI/ccCheckClipClir:
In: Calling Number=BCD(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
007768: Aug 7 16:13:03.522: //-1/94A16CFEB7FD/CCAPI/ccCheckClipClir:
Out: Calling Number=BCD(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
007769: Aug 7 16:13:03.522: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007770: Aug 7 16:13:03.522: :cc_get_feature_vsa malloc success
007771: Aug 7 16:13:03.522: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007772: Aug 7 16:13:03.522: cc_get_feature_vsa count is 3
007773: Aug 7 16:13:03.522: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007774: Aug 7 16:13:03.522: :FEATURE_VSA attributes are: feature_name:0,feature_time:2296339968,feature_id:13887
007775: Aug 7 16:13:03.522: //24452/94A16CFEB7FD/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=BCD(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown))
007776: Aug 7 16:13:03.522: //-1/94A16CFEB7FD/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x8A46BFEC; count=1
007777: Aug 7 16:13:03.522: //-1/94A16CFEB7FD/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x88EA78E8
007778: Aug 7 16:13:03.526: //24452/94A16CFEB7FD/CCAPI/cc_process_call_setup_ind:
Event=0x87F2B738
007779: Aug 7 16:13:03.526: //24452/94A16CFEB7FD/CCAPI/ccCallSetContext:
Context=0x86053F54
007780: Aug 7 16:13:03.526: //24452/94A16CFEB7FD/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 24452 with tag 20001 to app "_ManagedAppProcess_Default"
007781: Aug 7 16:13:03.526: //-1/94A16CFEB7FD/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x8A46BFEC; count=1
007782: Aug 7 16:13:03.526: //24452/94A16CFEB7FD/CCAPI/ccCallSetupAck:
Call Id=24452
007783: Aug 7 16:13:03.526: //24452/94A16CFEB7FD/CCAPI/cc_api_set_transfer_info:
Transfer Number=, Transfer Reason=0x0
007784: Aug 7 16:13:03.526: //24452/94A16CFEB7FD/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=TRUE, Tone=Dial Tone,
Tone Direction=Network, Params=0x0, Call Id=24452
007785: Aug 7 16:13:03.526: //24452/94A16CFEB7FD/CCAPI/ccSetDigitTimeouts:
Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
007786: Aug 7 16:13:03.526: //24452/94A16CFEB7FD/CCAPI/ccSetDigitTimeouts:
Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
007787: Aug 7 16:13:03.526: //24452/94A16CFEB7FD/CCAPI/ccCallReportDigits:
(callID=0x5F84, digit_event=0x1, enable=TRUE, consume=FALSE)
007788: Aug 7 16:13:03.526: //24452/94A16CFEB7FD/CCAPI/ccCallReportDigits:
Enabled=TRUE, Call Id=24452
007789: Aug 7 16:13:03.526: //24452/94A16CFEB7FD/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x88A3D9F0, callID=0x5F84, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
007790: Aug 7 16:13:03.526: //24452/94A16CFEB7FD/CCAPI/cc_api_call_report_digits_done:
Enabled=TRUE, Disposition=0x0, Interface=0x88A3D9F0, Call Id=24452
007791: Aug 7 16:13:03.526: //24452/94A16CFEB7FD/CCAPI/cc_api_call_report_digits_done:
Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=5000(ms))
007792: Aug 7 16:13:03.530: //24452/94A16CFEB7FD/CCAPI/cc_api_call_digit_begin:
Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Source Call Id=24452, Digit=A, DigitBeginFlags=0x0,
Rtp Timestamp=0x5025E608, Rtp Expiration=0x0
007793: Aug 7 16:13:03.530: //24452/94A16CFEB7FD/CCAPI/cc_api_call_digit_end:
Source Call Id=24452, Digit=A, Duration=100,
Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
007794: Aug 7 16:13:03.530: //24452/94A16CFEB7FD/CCAPI/cc_api_call_digit_end:
Call Entry(Handoff Depth=0)
007795: Aug 7 16:13:03.530: //24452/94A16CFEB7FD/CCAPI/cc_api_call_digit_begin:
Source Call Id=24452, Digit=B, DigitBeginFlags=0x0,
Rtp Timestamp=0x50266308, Rtp Expiration=0x0
007796: Aug 7 16:13:03.530: //24452/94A16CFEB7FD/CCAPI/cc_api_call_digit_end:
Source Call Id=24452, Digit=B, Duration=100,
007797: Aug 7 16:13:03.530: //24452/94A16CFEB7FD/CCAPI/cc_api_call_digit_end:
007798: Aug 7 16:13:03.530: //24452/94A16CFEB7FD/CCAPI/cc_api_call_digit_begin:
Source Call Id=24452, Digit=C, DigitBeginFlags=0x0,
Rtp Timestamp=0x5026E008, Rtp Expiration=0x0
007799: Aug 7 16:13:03.530: //24452/94A16CFEB7FD/CCAPI/cc_api_call_digit_end:
Source Call Id=24452, Digit=C, Duration=100,
007800: Aug 7 16:13:03.530: //24452/94A16CFEB7FD/CCAPI/cc_api_call_digit_end:
007801: Aug 7 16:13:03.534: //-1/94A16CFEB7FD/DPM/dpMatchPeersCore:
Calling Number=, Called Number=A, Peer Info Type=DIALPEER_INFO_SPEECH
007802: Aug 7 16:13:03.534: //-1/94A16CFEB7FD/DPM/dpMatchPeersCore:
007803: Aug 7 16:13:03.534: //-1/94A16CFEB7FD/DPM/dpMatchCore:
Dial String=A, Expanded String=A, Calling Number=
Timeout=FALSE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
007804: Aug 7 16:13:03.538: //-1/94A16CFEB7FD/DPM/MatchNextPeer:
Result=MORE_DIGITS_NEEDED(1); Outgoing Dial-peer=5
007805: Aug 7 16:13:03.538: //-1/94A16CFEB7FD/DPM/dpMatchCore:
Result=1
007806: Aug 7 16:13:03.538: //-1/94A16CFEB7FD/DPM/dpMatchPeersCore:
Result=Partial Matches(1) after DP_MATCH_DEST
007807: Aug 7 16:13:03.538: //-1/94A16CFEB7FD/DPM/dpMatchSafModulePlugin:
dialstring=A, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
007808: Aug 7 16:13:03.538: //-1/94A16CFEB7FD/DPM/dpMatchPeersMoreArg:
007809: Aug 7 16:13:03.538: //-1/94A16CFEB7FD/DPM/dpMatchPeersCore:
Calling Number=, Called Number=AB, Peer Info Type=DIALPEER_INFO_SPEECH
007810: Aug 7 16:13:03.538: //-1/94A16CFEB7FD/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=AB
007811: Aug 7 16:13:03.538: //-1/94A16CFEB7FD/DPM/dpMatchCore:
Dial String=AB, Expanded String=AB, Calling Number=
007812: Aug 7 16:13:03.538: //-1/94A16CFEB7FD/DPM/MatchNextPeer:
007813: Aug 7 16:13:03.538: //-1/94A16CFEB7FD/DPM/dpMatchCore:
Result=1
007814: Aug 7 16:13:03.538: //-1/94A16CFEB7FD/DPM/dpMatchPeersCore:
007815: Aug 7 16:13:03.538: //-1/94A16CFEB7FD/DPM/dpMatchSafModulePlugin:
dialstring=AB, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
007816: Aug 7 16:13:03.538: //-1/94A16CFEB7FD/DPM/dpMatchPeersMoreArg:
007817: Aug 7 16:13:03.542: //-1/94A16CFEB7FD/DPM/dpMatchPeersCore:
Calling Number=, Called Number=ABC, Peer Info Type=DIALPEER_INFO_SPEECH
007818: Aug 7 16:13:03.542: //-1/94A16CFEB7FD/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=ABC
007819: Aug 7 16:13:03.542: //-1/94A16CFEB7FD/DPM/dpMatchCore:
Dial String=ABC, Expanded String=ABC, Calling Number=
007820: Aug 7 16:13:03.542: //-1/94A16CFEB7FD/DPM/MatchNextPeer:
Result=Success(0); Outgoing Dial-peer=5 Is Matched
007821: Aug 7 16:13:03.542: //-1/94A16CFEB7FD/DPM/dpMatchPeersCore:
007822: Aug 7 16:13:03.542: //-1/94A16CFEB7FD/DPM/dpMatchSafModulePlugin:
dialstring=ABC, saf_enabled=1, saf_dndb_lookup=0, dp_result=0
007823: Aug 7 16:13:03.542: //-1/94A16CFEB7FD/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=5
007824: Aug 7 16:13:03.542: //24452/94A16CFEB7FD/CCAPI/ccCallReportDigits:
(callID=0x5F84, digit_event=0x0, enable=FALSE, consume=FALSE)
007825: Aug 7 16:13:03.542: //24452/94A16CFEB7FD/CCAPI/ccCallReportDigits:
007826: Aug 7 16:13:03.542: //24452/94A16CFEB7FD/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x88A3D9F0, callID=0x5F84, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
007827: Aug 7 16:13:03.542: //24452/94A16CFEB7FD/CCAPI/cc_api_call_report_digits_done:
007828: Aug 7 16:13:03.542: //24452/94A16CFEB7FD/CCAPI/cc_api_call_report_digits_done:
007829: Aug 7 16:13:03.542: //24452/94A16CFEB7FD/CCAPI/ccCallProceeding:
007830: Aug 7 16:13:03.546: //-1/94A16CFEB7FD/DPM/dpMatchPeersCore:
007831: Aug 7 16:13:03.546: //-1/94A16CFEB7FD/DPM/dpMatchPeersCore:
007832: Aug 7 16:13:03.546: //-1/94A16CFEB7FD/DPM/dpMatchCore:
007833: Aug 7 16:13:03.546: //-1/94A16CFEB7FD/DPM/MatchNextPeer:
007834: Aug 7 16:13:03.546: //-1/94A16CFEB7FD/DPM/dpMatchPeersCore:
007835: Aug 7 16:13:03.546: //-1/94A16CFEB7FD/DPM/dpMatchSafModulePlugin:
dialstring=ABC, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
007836: Aug 7 16:13:03.546: //-1/94A16CFEB7FD/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=5
007837: Aug 7 16:13:03.546: //-1/94A16CFEB7FD/DPM/dpMatchPeersCore:
007838: Aug 7 16:13:03.546: //-1/94A16CFEB7FD/DPM/dpMatchPeersCore:
007839: Aug 7 16:13:03.546: //-1/94A16CFEB7FD/DPM/dpMatchCore:
007840: Aug 7 16:13:03.546: //-1/94A16CFEB7FD/DPM/MatchNextPeer:
007841: Aug 7 16:13:03.546: //-1/94A16CFEB7FD/DPM/dpMatchPeersCore:
007842: Aug 7 16:13:03.546: //-1/94A16CFEB7FD/DPM/dpMatchSafModulePlugin:
007843: Aug 7 16:13:03.546: //-1/94A16CFEB7FD/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=5
007844: Aug 7 16:13:03.546: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=ABC, Called Number=ABC, Peer Info Type=DIALPEER_INFO_SPEECH
007845: Aug 7 16:13:03.546: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007846: Aug 7 16:13:03.546: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=ABC, Expanded String=ABC, Calling Number=ABCT
007847: Aug 7 16:13:03.546: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007848: Aug 7 16:13:03.546: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007849: Aug 7 16:13:03.546: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007850: Aug 7 16:13:03.546: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=5
007851: Aug 7 16:13:03.546: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=, Called Number=, Voice-Interface=0x0,
007852: Aug 7 16:13:03.546: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007853: Aug 7 16:13:03.546: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007854: Aug 7 16:13:03.546: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6610
007855: Aug 7 16:13:03.546: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=ABC, Called Number=, Voice-Interface=0x0,
007856: Aug 7 16:13:03.546: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ANSWER; Calling Number=ABC
007857: Aug 7 16:13:03.546: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007858: Aug 7 16:13:03.546: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=, Expanded String=, Calling Number=ABCT
007859: Aug 7 16:13:03.546: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
007860: Aug 7 16:13:03.546: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
007861: Aug 7 16:13:03.546: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ORIGINATE; Calling Number=ABC
007862: Aug 7 16:13:03.546: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007863: Aug 7 16:13:03.546: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007864: Aug 7 16:13:03.546: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Incoming Dial-peer=5 Is Matched
007865: Aug 7 16:13:03.546: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
007866: Aug 7 16:13:03.550: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007867: Aug 7 16:13:03.550: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007868: Aug 7 16:13:03.550: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6610
007869: Aug 7 16:13:03.550: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007870: Aug 7 16:13:03.550: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007871: Aug 7 16:13:03.550: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007872: Aug 7 16:13:03.550: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007873: Aug 7 16:13:03.550: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007874: Aug 7 16:13:03.550: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007875: Aug 7 16:13:03.550: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=5
007876: Aug 7 16:13:03.550: //-1/94A16CFEB7FD/DPM/dpMatchPeersCore:
007877: Aug 7 16:13:03.550: //-1/94A16CFEB7FD/DPM/dpMatchPeersCore:
007878: Aug 7 16:13:03.550: //-1/94A16CFEB7FD/DPM/dpMatchCore:
007879: Aug 7 16:13:03.550: //-1/94A16CFEB7FD/DPM/MatchNextPeer:
007880: Aug 7 16:13:03.550: //-1/94A16CFEB7FD/DPM/dpMatchPeersCore:
007881: Aug 7 16:13:03.550: //-1/94A16CFEB7FD/DPM/dpMatchSafModulePlugin:
dialstring=ABC, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
007882: Aug 7 16:13:03.550: //-1/94A16CFEB7FD/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=5
007883: Aug 7 16:13:03.550: //-1/94A16CFEB7FD/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x8A46BFEC; count=2
007884: Aug 7 16:13:03.550: //-1/94A16CFEB7FD/RXRULE/regxrule_dp_translate: No profile found in peer 5 for outgoing direction
007885: Aug 7 16:13:03.550: //-1/94A16CFEB7FD/RXRULE/regxrule_dp_translate: calling_number=BCD calling_octet=0x0
called_number=ABC called_octet=0x80
redirect_number= redirect_type=0 redirect_plan=0 redirect_PI=0 redirect_SI=0
007886: Aug 7 16:13:03.550: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number ABC
007887: Aug 7 16:13:03.550: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
007888: Aug 7 16:13:03.550: : updating existing feature vsa
007889: Aug 7 16:13:03.550: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
007890: Aug 7 16:13:03.550: feature call basic
007891: Aug 7 16:13:03.554: //24452/94A16CFEB7FD/CCAPI/ccCallDisconnect:
Cause Value=17, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
007892: Aug 7 16:13:03.554: //24452/94A16CFEB7FD/CCAPI/ccCallDisconnect:
Cause Value=17, Call Entry(Responsed=TRUE, Cause Value=17)
007893: Aug 7 16:13:03.554: //24452/94A16CFEB7FD/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
007894: Aug 7 16:13:03.566: //24452/94A16CFEB7FD/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x88A3D9F0, Tag=0x0, Call Id=24452,
Call Entry(Disconnect Cause=17, Voice Class Cause Code=0, Retry Count=0)
007895: Aug 7 16:13:03.566: //-1/94A16CFEB7FD/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x8A46BFEC; count=2
007896: Aug 7 16:13:03.566: //-1/94A16CFEB7FD/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x88EA95D0
007897: Aug 7 16:13:03.566: //24452/94A16CFEB7FD/CCAPI/cc_api_call_disconnect_done:
Call Disconnect Event Sent
007898: Aug 7 16:13:03.566: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007899: Aug 7 16:13:03.566: :cc_free_feature_vsa freeing 88DF5DF8
007900: Aug 7 16:13:03.566: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007901: Aug 7 16:13:03.566: vsacount in free is 2
007902: Aug 7 16:13:05.466: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CANCEL sip:A800201@10.1.10.2:5060;transport=udp SIP/2.0
Max-Forwards: 70
To:
CSeq: 100 CANCEL
Content-Length: 0
007903: Aug 7 16:13:05.466: //24449/92CD49A6B7F7/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x872E9C18, Call Id=24449
007904: Aug 7 16:13:05.466: //24449/92CD49A6B7F7/CCAPI/cc_api_call_disconnected:
007905: Aug 7 16:13:05.466: //24450/92CD49A6B7F7/CCAPI/ccCallDisconnect:
007906: Aug 7 16:13:05.466: //24450/92CD49A6B7F7/CCAPI/ccCallDisconnect:
007907: Aug 7 16:13:05.466: //24450/92CD49A6B7F7/CCAPI/cc_api_get_transfer_info:
007908: Aug 7 16:13:05.470: //24449/92CD49A6B7F7/CCAPI/ccCallDisconnect:
007909: Aug 7 16:13:05.470: //24449/92CD49A6B7F7/CCAPI/ccCallDisconnect:
007910: Aug 7 16:13:05.474: //24450/92CD49A6B7F7/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x8887D9EC, Tag=0x0, Call Id=24450,
007911: Aug 7 16:13:05.474: //-1/92CD49A6B7F7/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x0
007912: Aug 7 16:13:05.474: //24450/92CD49A6B7F7/CCAPI/cc_api_call_disconnect_done:
007913: Aug 7 16:13:05.474: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007914: Aug 7 16:13:05.474: :cc_free_feature_vsa freeing 88DF5ED8
007915: Aug 7 16:13:05.474: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007916: Aug 7 16:13:05.474: vsacount in free is 1
007917: Aug 7 16:13:05.478: //24449/92CD49A6B7F7/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To:
Date: Sun, 07 Aug 2011 15:13:05 GMT
CSeq: 100 CANCEL
Content-Length: 0
007918: Aug 7 16:13:05.478: //24449/92CD49A6B7F7/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 487 Request Cancelled
To:
CSeq: 100 INVITE
Allow-Events: telephone-event
Content-Length: 0
007919: Aug 7 16:13:05.518: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:A800201@10.1.10.2:5060;transport=udp SIP/2.0
Max-Forwards: 70
To:
CSeq: 100 ACK
Content-Length: 0
007920: Aug 7 16:13:05.522: //24449/92CD49A6B7F7/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x872E9C18, Tag=0x0, Call Id=24449,
007921: Aug 7 16:13:05.522: //-1/92CD49A6B7F7/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x8A46C7D4; count=2
007922: Aug 7 16:13:05.522: //-1/92CD49A6B7F7/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x88EA8884
007923: Aug 7 16:13:05.522: //24449/92CD49A6B7F7/CCAPI/cc_api_call_disconnect_done:
007924: Aug 7 16:13:05.522: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007925: Aug 7 16:13:05.522: :cc_free_feature_vsa freeing 88DF5D18
007926: Aug 7 16:13:05.522: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007927: Aug 7 16:13:05.522: vsacount in free is 0
007928: Aug 7 16:13:33.518: //-1/xxxxxxxxxxxx/RXRULE/regxrule_get_profile_from_trunkgroup_internal:
007929: Aug 7 16:13:33.518: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007930: Aug 7 16:13:33.518: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007931: Aug 7 16:13:33.518: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007932: Aug 7 16:13:33.518: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007933: Aug 7 16:13:33.518: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
007934: Aug 7 16:13:33.518: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
007935: Aug 7 16:13:33.518: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007936: Aug 7 16:13:33.518: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007937: Aug 7 16:13:33.518: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007938: Aug 7 16:13:33.518: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007939: Aug 7 16:13:33.518: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
007940: Aug 7 16:13:33.518: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007941: Aug 7 16:13:33.518: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007942: Aug 7 16:13:33.518: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerSPI:exit@6561
007943: Aug 7 16:13:33.522: //-1/A6830FFEB801/CCAPI/cc_api_display_ie_subfields:
cisco-username=
cisco-ani=BCD
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
007944: Aug 7 16:13:33.522: //-1/A6830FFEB801/CCAPI/cc_api_call_setup_ind_common:
007945: Aug 7 16:13:33.522: //-1/A6830FFEB801/CCAPI/ccCheckClipClir:
007946: Aug 7 16:13:33.522: //-1/A6830FFEB801/CCAPI/ccCheckClipClir:
007947: Aug 7 16:13:33.522: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007948: Aug 7 16:13:33.522: :cc_get_feature_vsa malloc success
007949: Aug 7 16:13:33.522: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007950: Aug 7 16:13:33.522: cc_get_feature_vsa count is 1
007951: Aug 7 16:13:33.522: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007952: Aug 7 16:13:33.522: :FEATURE_VSA attributes are: feature_name:0,feature_time:2296339744,feature_id:13888
007953: Aug 7 16:13:33.522: //24453/A6830FFEB801/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
007954: Aug 7 16:13:33.522: //-1/A6830FFEB801/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x8A46BE8C; count=1
007955: Aug 7 16:13:33.522: //-1/A6830FFEB801/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x88EA875C
007956: Aug 7 16:13:33.526: //24453/A6830FFEB801/CCAPI/cc_process_call_setup_ind:
Event=0x87F2C158
007957: Aug 7 16:13:33.526: //24453/A6830FFEB801/CCAPI/ccCallSetContext:
Context=0x8605C8EC
007958: Aug 7 16:13:33.526: //24453/A6830FFEB801/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 24453 with tag 20001 to app "_ManagedAppProcess_Default"
007959: Aug 7 16:13:33.526: //-1/A6830FFEB801/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x8A46BE8C; count=1
007960: Aug 7 16:13:33.526: //24453/A6830FFEB801/CCAPI/ccCallSetupAck:
Call Id=24453
007961: Aug 7 16:13:33.526: //24453/A6830FFEB801/CCAPI/cc_api_set_transfer_info:
007962: Aug 7 16:13:33.526: //24453/A6830FFEB801/CCAPI/ccGenerateToneInfo:
Tone Direction=Network, Params=0x0, Call Id=24453
007963: Aug 7 16:13:33.526: //24453/A6830FFEB801/CCAPI/ccSetDigitTimeouts:
007964: Aug 7 16:13:33.526: //24453/A6830FFEB801/CCAPI/ccSetDigitTimeouts:
007965: Aug 7 16:13:33.526: //24453/A6830FFEB801/CCAPI/ccCallReportDigits:
(callID=0x5F85, digit_event=0x1, enable=TRUE, consume=FALSE)
007966: Aug 7 16:13:33.526: //24453/A6830FFEB801/CCAPI/ccCallReportDigits:
Enabled=TRUE, Call Id=24453
007967: Aug 7 16:13:33.526: //24453/A6830FFEB801/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x88A3D9F0, callID=0x5F85, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
007968: Aug 7 16:13:33.526: //24453/A6830FFEB801/CCAPI/cc_api_call_report_digits_done:
Enabled=TRUE, Disposition=0x0, Interface=0x88A3D9F0, Call Id=24453
007969: Aug 7 16:13:33.526: //24453/A6830FFEB801/CCAPI/cc_api_call_report_digits_done:
007970: Aug 7 16:13:33.530: //24453/A6830FFEB801/CCAPI/cc_api_call_digit_begin:
Source Call Id=24453, Digit=A, DigitBeginFlags=0x0,
Rtp Timestamp=0x502764D8, Rtp Expiration=0x0
007971: Aug 7 16:13:33.530: //24453/A6830FFEB801/CCAPI/cc_api_call_digit_end:
Source Call Id=24453, Digit=A, Duration=100,
007972: Aug 7 16:13:33.530: //24453/A6830FFEB801/CCAPI/cc_api_call_digit_end:
007973: Aug 7 16:13:33.530: //24453/A6830FFEB801/CCAPI/cc_api_call_digit_begin:
Source Call Id=24453, Digit=B, DigitBeginFlags=0x0,
Rtp Timestamp=0x5027E1D8, Rtp Expiration=0x0
007974: Aug 7 16:13:33.530: //24453/A6830FFEB801/CCAPI/cc_api_call_digit_end:
Source Call Id=24453, Digit=B, Duration=100,
007975: Aug 7 16:13:33.530: //24453/A6830FFEB801/CCAPI/cc_api_call_digit_end:
007976: Aug 7 16:13:33.530: //24453/A6830FFEB801/CCAPI/cc_api_call_digit_begin:
Source Call Id=24453, Digit=C, DigitBeginFlags=0x0,
Rtp Timestamp=0x50285ED8, Rtp Expiration=0x0
007977: Aug 7 16:13:33.530: //24453/A6830FFEB801/CCAPI/cc_api_call_digit_end:
Source Call Id=24453, Digit=C, Duration=100,
007978: Aug 7 16:13:33.530: //24453/A6830FFEB801/CCAPI/cc_api_call_digit_end:
007979: Aug 7 16:13:33.534: //-1/A6830FFEB801/DPM/dpMatchPeersCore:
007980: Aug 7 16:13:33.534: //-1/A6830FFEB801/DPM/dpMatchPeersCore:
007981: Aug 7 16:13:33.534: //-1/A6830FFEB801/DPM/dpMatchCore:
007982: Aug 7 16:13:33.538: //-1/A6830FFEB801/DPM/MatchNextPeer:
007983: Aug 7 16:13:33.538: //-1/A6830FFEB801/DPM/dpMatchCore:
Result=1
007984: Aug 7 16:13:33.538: //-1/A6830FFEB801/DPM/dpMatchPeersCore:
007985: Aug 7 16:13:33.538: //-1/A6830FFEB801/DPM/dpMatchSafModulePlugin:
007986: Aug 7 16:13:33.538: //-1/A6830FFEB801/DPM/dpMatchPeersMoreArg:
007987: Aug 7 16:13:33.538: //-1/A6830FFEB801/DPM/dpMatchPeersCore:
007988: Aug 7 16:13:33.538: //-1/A6830FFEB801/DPM/dpMatchPeersCore:
007989: Aug 7 16:13:33.538: //-1/A6830FFEB801/DPM/dpMatchCore:
007990: Aug 7 16:13:33.538: //-1/A6830FFEB801/DPM/MatchNextPeer:
007991: Aug 7 16:13:33.538: //-1/A6830FFEB801/DPM/dpMatchCore:
Result=1
007992: Aug 7 16:13:33.538: //-1/A6830FFEB801/DPM/dpMatchPeersCore:
007993: Aug 7 16:13:33.538: //-1/A6830FFEB801/DPM/dpMatchSafModulePlugin:
007994: Aug 7 16:13:33.538: //-1/A6830FFEB801/DPM/dpMatchPeersMoreArg:
007995: Aug 7 16:13:33.542: //-1/A6830FFEB801/DPM/dpMatchPeersCore:
007996: Aug 7 16:13:33.542: //-1/A6830FFEB801/DPM/dpMatchPeersCore:
007997: Aug 7 16:13:33.542: //-1/A6830FFEB801/DPM/dpMatchCore:
007998: Aug 7 16:13:33.542: //-1/A6830FFEB801/DPM/MatchNextPeer:
007999: Aug 7 16:13:33.542: //-1/A6830FFEB801/DPM/dpMatchPeersCore:
008000: Aug 7 16:13:33.542: //-1/A6830FFEB801/DPM/dpMatchSafModulePlugin:
008001: Aug 7 16:13:33.542: //-1/A6830FFEB801/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=5
008002: Aug 7 16:13:33.542: //24453/A6830FFEB801/CCAPI/ccCallReportDigits:
(callID=0x5F85, digit_event=0x0, enable=FALSE, consume=FALSE)
008003: Aug 7 16:13:33.542: //24453/A6830FFEB801/CCAPI/ccCallReportDigits:
008004: Aug 7 16:13:33.542: //24453/A6830FFEB801/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x88A3D9F0, callID=0x5F85, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
008005: Aug 7 16:13:33.542: //24453/A6830FFEB801/CCAPI/cc_api_call_report_digits_done:
008006: Aug 7 16:13:33.542: //24453/A6830FFEB801/CCAPI/cc_api_call_report_digits_done:
008007: Aug 7 16:13:33.542: //24453/A6830FFEB801/CCAPI/ccCallProceeding:
008008: Aug 7 16:13:33.546: //-1/A6830FFEB801/DPM/dpMatchPeersCore:
008009: Aug 7 16:13:33.546: //-1/A6830FFEB801/DPM/dpMatchPeersCore:
008010: Aug 7 16:13:33.546: //-1/A6830FFEB801/DPM/dpMatchCore:
008011: Aug 7 16:13:33.546: //-1/A6830FFEB801/DPM/MatchNextPeer:
008012: Aug 7 16:13:33.546: //-1/A6830FFEB801/DPM/dpMatchPeersCore:
008013: Aug 7 16:13:33.546: //-1/A6830FFEB801/DPM/dpMatchSafModulePlugin:
008014: Aug 7 16:13:33.546: //-1/A6830FFEB801/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=5
008015: Aug 7 16:13:33.546: //-1/A6830FFEB801/DPM/dpMatchPeersCore:
008016: Aug 7 16:13:33.546: //-1/A6830FFEB801/DPM/dpMatchPeersCore:
008017: Aug 7 16:13:33.546: //-1/A6830FFEB801/DPM/dpMatchCore:
008018: Aug 7 16:13:33.546: //-1/A6830FFEB801/DPM/MatchNextPeer:
008019: Aug 7 16:13:33.546: //-1/A6830FFEB801/DPM/dpMatchPeersCore:
008020: Aug 7 16:13:33.546: //-1/A6830FFEB801/DPM/dpMatchSafModulePlugin:
008021: Aug 7 16:13:33.546: //-1/A6830FFEB801/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=5
008022: Aug 7 16:13:33.546: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
008023: Aug 7 16:13:33.546: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
008024: Aug 7 16:13:33.546: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
008025: Aug 7 16:13:33.546: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
008026: Aug 7 16:13:33.546: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
008027: Aug 7 16:13:33.546: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
008028: Aug 7 16:13:33.546: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=5
008029: Aug 7 16:13:33.546: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008030: Aug 7 16:13:33.546: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008031: Aug 7 16:13:33.546: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
008032: Aug 7 16:13:33.546: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6610
008033: Aug 7 16:13:33.546: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008034: Aug 7 16:13:33.546: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008035: Aug 7 16:13:33.546: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
008036: Aug 7 16:13:33.546: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
008037: Aug 7 16:13:33.546: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
008038: Aug 7 16:13:33.546: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
008039: Aug 7 16:13:33.546: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008040: Aug 7 16:13:33.546: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
008041: Aug 7 16:13:33.546: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
008042: Aug 7 16:13:33.550: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
008043: Aug 7 16:13:33.550: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
008044: Aug 7 16:13:33.550: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008045: Aug 7 16:13:33.550: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
008046: Aug 7 16:13:33.550: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6610
008047: Aug 7 16:13:33.550: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
008048: Aug 7 16:13:33.550: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
008049: Aug 7 16:13:33.550: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
008050: Aug 7 16:13:33.550: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
008051: Aug 7 16:13:33.550: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
008052: Aug 7 16:13:33.550: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
008053: Aug 7 16:13:33.550: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=5
008054: Aug 7 16:13:33.550: //-1/A6830FFEB801/DPM/dpMatchPeersCore:
008055: Aug 7 16:13:33.550: //-1/A6830FFEB801/DPM/dpMatchPeersCore:
008056: Aug 7 16:13:33.550: //-1/A6830FFEB801/DPM/dpMatchCore:
008057: Aug 7 16:13:33.550: //-1/A6830FFEB801/DPM/MatchNextPeer:
008058: Aug 7 16:13:33.550: //-1/A6830FFEB801/DPM/dpMatchPeersCore:
008059: Aug 7 16:13:33.550: //-1/A6830FFEB801/DPM/dpMatchSafModulePlugin:
008060: Aug 7 16:13:33.550: //-1/A6830FFEB801/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=5
008061: Aug 7 16:13:33.550: //-1/A6830FFEB801/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x8A46BE8C; count=2
008062: Aug 7 16:13:33.550: //-1/A6830FFEB801/RXRULE/regxrule_dp_translate: No profile found in peer 5 for outgoing direction
008063: Aug 7 16:13:33.550: //-1/A6830FFEB801/RXRULE/regxrule_dp_translate: calling_number=BCD calling_octet=0x0
008064: Aug 7 16:13:33.550: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
008065: Aug 7 16:13:33.554: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
008066: Aug 7 16:13:33.554: : updating existing feature vsa
008067: Aug 7 16:13:33.554: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
008068: Aug 7 16:13:33.554: feature call basic
008069: Aug 7 16:13:33.554: //24453/A6830FFEB801/CCAPI/ccCallDisconnect:
008070: Aug 7 16:13:33.554: //24453/A6830FFEB801/CCAPI/ccCallDisconnect:
008071: Aug 7 16:13:33.554: //24453/A6830FFEB801/CCAPI/cc_api_get_transfer_info:
008072: Aug 7 16:13:33.566: //24453/A6830FFEB801/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x88A3D9F0, Tag=0x0, Call Id=24453,
008073: Aug 7 16:13:33.566: //-1/A6830FFEB801/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x8A46BE8C; count=2
008074: Aug 7 16:13:33.566: //-1/A6830FFEB801/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x88EA8194
008075: Aug 7 16:13:33.566: //24453/A6830FFEB801/CCAPI/cc_api_call_disconnect_done:
008076: Aug 7 16:13:33.566: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
008077: Aug 7 16:13:33.566: :cc_free_feature_vsa freeing 88DF5D18
008078: Aug 7 16:13:33.566: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
008079: Aug 7 16:13:33.566: vsacount in free is 0
008080: Aug 7 16:13:36.246: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on FastEthernet0/1/8 (not half duplex), with SEP00e075244b3c port 1 (half duplex).
008081: Aug 7 16:13:52.718: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 88.208.249.40:5060;branch=z9hG4bK6b6f.0.0
Call-ID: aa9e8761-519954d4-831e23@88.208.249.40
CSeq: 1 OPTIONS
Content-Length: 0
008082: Aug 7 16:13:52.718: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008083: Aug 7 16:13:52.718: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008084: Aug 7 16:13:52.718: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
008085: Aug 7 16:13:52.718: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
008086: Aug 7 16:13:52.718: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
008087: Aug 7 16:13:52.718: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
008088: Aug 7 16:13:52.718: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008089: Aug 7 16:13:52.718: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
008090: Aug 7 16:13:52.718: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
008091: Aug 7 16:13:52.718: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
008092: Aug 7 16:13:52.718: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
008093: Aug 7 16:13:52.718: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008094: Aug 7 16:13:52.718: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
008095: Aug 7 16:13:52.718: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6610
008096: Aug 7 16:13:52.718: //-1/B1F423E9B805/DPM/dpAssociateIncomingPeerCore:
008097: Aug 7 16:13:52.722: //-1/B1F423E9B805/DPM/dpAssociateIncomingPeerCore:
008098: Aug 7 16:13:52.722: //-1/B1F423E9B805/DPM/dpMatchPeertype:
008099: Aug 7 16:13:52.722: //-1/B1F423E9B805/DPM/dpMatchCore:
008100: Aug 7 16:13:52.722: //-1/B1F423E9B805/DPM/dpMatchCore:
Result=-1
008101: Aug 7 16:13:52.722: //-1/B1F423E9B805/DPM/dpMatchPeertype:exit@5982
008102: Aug 7 16:13:52.722: //-1/B1F423E9B805/DPM/dpAssociateIncomingPeerCore:
008103: Aug 7 16:13:52.722: //-1/B1F423E9B805/DPM/dpMatchPeertype:
008104: Aug 7 16:13:52.722: //-1/B1F423E9B805/DPM/dpMatchCore:
008105: Aug 7 16:13:52.722: //-1/B1F423E9B805/DPM/dpMatchCore:
Result=-1
008106: Aug 7 16:13:52.722: //-1/B1F423E9B805/DPM/dpMatchPeertype:exit@5982
008107: Aug 7 16:13:52.722: //-1/B1F423E9B805/DPM/dpAssociateIncomingPeerCore:
008108: Aug 7 16:13:52.722: //-1/B1F423E9B805/DPM/dpMatchPeertype:
008109: Aug 7 16:13:52.722: //-1/B1F423E9B805/DPM/dpMatchCore:
008110: Aug 7 16:13:52.722: //-1/B1F423E9B805/DPM/dpMatchCore:
Result=-1
008111: Aug 7 16:13:52.722: //-1/B1F423E9B805/DPM/dpMatchPeertype:exit@5982
008112: Aug 7 16:13:52.722: //-1/B1F423E9B805/DPM/dpAssociateIncomingPeerCore:
008113: Aug 7 16:13:52.722: //-1/B1F423E9B805/DPM/dpMatchPeertype:
008114: Aug 7 16:13:52.722: //-1/B1F423E9B805/DPM/dpMatchCore:
008115: Aug 7 16:13:52.722: //-1/B1F423E9B805/DPM/dpMatchCore:
Result=-1
008116: Aug 7 16:13:52.722: //-1/B1F423E9B805/DPM/dpMatchPeertype:exit@5982
008117: Aug 7 16:13:52.722: //-1/B1F423E9B805/DPM/dpAssociateIncomingPeerCore:
008118: Aug 7 16:13:52.722: //-1/B1F423E9B805/DPM/dpMatchPeertype:
008119: Aug 7 16:13:52.722: //-1/B1F423E9B805/DPM/dpMatchCore:
008120: Aug 7 16:13:52.722: //-1/B1F423E9B805/DPM/dpMatchCore:
Result=-1
008121: Aug 7 16:13:52.722: //-1/B1F423E9B805/DPM/dpMatchPeertype:exit@5982
008122: Aug 7 16:13:52.722: //-1/B1F423E9B805/DPM/dpAssociateIncomingPeerCore:
008123: Aug 7 16:13:52.722: //-1/B1F423E9B805/DPM/dpMatchPeertype:
008124: Aug 7 16:13:52.722: //-1/B1F423E9B805/DPM/dpMatchCore:
008125: Aug 7 16:13:52.722: //-1/B1F423E9B805/DPM/dpMatchCore:
Result=-1
008126: Aug 7 16:13:52.722: //-1/B1F423E9B805/DPM/dpMatchPeertype:exit@5982
008127: Aug 7 16:13:52.722: //-1/B1F423E9B805/DPM/dpAssociateIncomingPeerCore:
008128: Aug 7 16:13:52.722: //-1/B1F423E9B805/DPM/dpMatchSafModulePlugin:
008129: Aug 7 16:13:52.722: //-1/B1F423E9B805/DPM/dpAssociateIncomingPeerSPI:exit@6561
008130: Aug 7 16:13:52.726: //24454/B1F423E9B805/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:UC520-PUBLIC-IP:56225;tag=188DFFF4-216C
Date: Sun, 07 Aug 2011 15:13:52 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 1 OPTIONS
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Content-Type: application/sdp
Content-Length: 179
v=0
o=CiscoSystemsSIP-GW-UserAgent 27290 7220 IN IP4 UC520-PRIVATE-IP
s=SIP Call
c=IN IP4 UC520-PRIVATE-IP
t=0 0
008131: Aug 7 16:14:03.518: //-1/xxxxxxxxxxxx/RXRULE/regxrule_get_profile_from_trunkgroup_internal:
008132: Aug 7 16:14:03.518: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008133: Aug 7 16:14:03.518: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008134: Aug 7 16:14:03.518: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
008135: Aug 7 16:14:03.518: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
008136: Aug 7 16:14:03.518: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
008137: Aug 7 16:14:03.518: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
008138: Aug 7 16:14:03.518: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008139: Aug 7 16:14:03.518: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
008140: Aug 7 16:14:03.518: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
008141: Aug 7 16:14:03.518: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
008142: Aug 7 16:14:03.518: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
008143: Aug 7 16:14:03.518: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008144: Aug 7 16:14:03.518: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
008145: Aug 7 16:14:03.518: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerSPI:exit@6561
008146: Aug 7 16:14:03.522: //-1/B864B397B806/CCAPI/cc_api_display_ie_subfields:
cisco-username=
cisco-ani=BCD
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
008147: Aug 7 16:14:03.522: //-1/B864B397B806/CCAPI/cc_api_call_setup_ind_common:
008148: Aug 7 16:14:03.522: //-1/B864B397B806/CCAPI/ccCheckClipClir:
008149: Aug 7 16:14:03.522: //-1/B864B397B806/CCAPI/ccCheckClipClir:
008150: Aug 7 16:14:03.522: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
008151: Aug 7 16:14:03.522: :cc_get_feature_vsa malloc success
008152: Aug 7 16:14:03.522: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
008153: Aug 7 16:14:03.522: cc_get_feature_vsa count is 1
008154: Aug 7 16:14:03.522: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
008155: Aug 7 16:14:03.522: :FEATURE_VSA attributes are: feature_name:0,feature_time:2296339744,feature_id:13889
008156: Aug 7 16:14:03.522: //24455/B864B397B806/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
008157: Aug 7 16:14:03.522: //-1/B864B397B806/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x8A46D06C; count=1
008158: Aug 7 16:14:03.522: //-1/B864B397B806/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x88EA8DB8
008159: Aug 7 16:14:03.522: //24455/B864B397B806/CCAPI/cc_process_call_setup_ind:
Event=0x87F2B738
008160: Aug 7 16:14:03.526: //24455/B864B397B806/CCAPI/ccCallSetContext:
Context=0x8604F0B4
008161: Aug 7 16:14:03.526: //24455/B864B397B806/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 24455 with tag 20001 to app "_ManagedAppProcess_Default"
008162: Aug 7 16:14:03.526: //-1/B864B397B806/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x8A46D06C; count=1
008163: Aug 7 16:14:03.526: //24455/B864B397B806/CCAPI/ccCallSetupAck:
Call Id=24455
008164: Aug 7 16:14:03.526: //24455/B864B397B806/CCAPI/cc_api_set_transfer_info:
008165: Aug 7 16:14:03.526: //24455/B864B397B806/CCAPI/ccGenerateToneInfo:
Tone Direction=Network, Params=0x0, Call Id=24455
008166: Aug 7 16:14:03.526: //24455/B864B397B806/CCAPI/ccSetDigitTimeouts:
008167: Aug 7 16:14:03.526: //24455/B864B397B806/CCAPI/ccSetDigitTimeouts:
008168: Aug 7 16:14:03.526: //24455/B864B397B806/CCAPI/ccCallReportDigits:
(callID=0x5F87, digit_event=0x1, enable=TRUE, consume=FALSE)
008169: Aug 7 16:14:03.526: //24455/B864B397B806/CCAPI/ccCallReportDigits:
Enabled=TRUE, Call Id=24455
008170: Aug 7 16:14:03.526: //24455/B864B397B806/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x88A3D9F0, callID=0x5F87, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
008171: Aug 7 16:14:03.526: //24455/B864B397B806/CCAPI/cc_api_call_report_digits_done:
Enabled=TRUE, Disposition=0x0, Interface=0x88A3D9F0, Call Id=24455
008172: Aug 7 16:14:03.526: //24455/B864B397B806/CCAPI/cc_api_call_report_digits_done:
008173: Aug 7 16:14:03.530: //24455/B864B397B806/CCAPI/cc_api_call_digit_begin:
Source Call Id=24455, Digit=A, DigitBeginFlags=0x0,
Rtp Timestamp=0x5028E3A8, Rtp Expiration=0x0
008174: Aug 7 16:14:03.530: //24455/B864B397B806/CCAPI/cc_api_call_digit_end:
Source Call Id=24455, Digit=A, Duration=100,
008175: Aug 7 16:14:03.530: //24455/B864B397B806/CCAPI/cc_api_call_digit_end:
008176: Aug 7 16:14:03.530: //24455/B864B397B806/CCAPI/cc_api_call_digit_begin:
Source Call Id=24455, Digit=B, DigitBeginFlags=0x0,
Rtp Timestamp=0x502960A8, Rtp Expiration=0x0
008177: Aug 7 16:14:03.530: //24455/B864B397B806/CCAPI/cc_api_call_digit_end:
Source Call Id=24455, Digit=B, Duration=100,
008178: Aug 7 16:14:03.530: //24455/B864B397B806/CCAPI/cc_api_call_digit_end:
008179: Aug 7 16:14:03.530: //24455/B864B397B806/CCAPI/cc_api_call_digit_begin:
Source Call Id=24455, Digit=C, DigitBeginFlags=0x0,
Rtp Timestamp=0x5029DDA8, Rtp Expiration=0x0
008180: Aug 7 16:14:03.530: //24455/B864B397B806/CCAPI/cc_api_call_digit_end:
Source Call Id=24455, Digit=C, Duration=100,
008181: Aug 7 16:14:03.530: //24455/B864B397B806/CCAPI/cc_api_call_digit_end:
008182: Aug 7 16:14:03.534: //-1/B864B397B806/DPM/dpMatchPeersCore:
008183: Aug 7 16:14:03.534: //-1/B864B397B806/DPM/dpMatchPeersCore:
008184: Aug 7 16:14:03.534: //-1/B864B397B806/DPM/dpMatchCore:
008185: Aug 7 16:14:03.538: //-1/B864B397B806/DPM/MatchNextPeer:
008186: Aug 7 16:14:03.538: //-1/B864B397B806/DPM/dpMatchCore:
Result=1
008187: Aug 7 16:14:03.538: //-1/B864B397B806/DPM/dpMatchPeersCore:
008188: Aug 7 16:14:03.538: //-1/B864B397B806/DPM/dpMatchSafModulePlugin:
008189: Aug 7 16:14:03.538: //-1/B864B397B806/DPM/dpMatchPeersMoreArg:
008190: Aug 7 16:14:03.538: //-1/B864B397B806/DPM/dpMatchPeersCore:
008191: Aug 7 16:14:03.538: //-1/B864B397B806/DPM/dpMatchPeersCore:
008192: Aug 7 16:14:03.538: //-1/B864B397B806/DPM/dpMatchCore:
008193: Aug 7 16:14:03.538: //-1/B864B397B806/DPM/MatchNextPeer:
008194: Aug 7 16:14:03.538: //-1/B864B397B806/DPM/dpMatchCore:
Result=1
008195: Aug 7 16:14:03.538: //-1/B864B397B806/DPM/dpMatchPeersCore:
008196: Aug 7 16:14:03.538: //-1/B864B397B806/DPM/dpMatchSafModulePlugin:
008197: Aug 7 16:14:03.538: //-1/B864B397B806/DPM/dpMatchPeersMoreArg:
008198: Aug 7 16:14:03.542: //-1/B864B397B806/DPM/dpMatchPeersCore:
008199: Aug 7 16:14:03.542: //-1/B864B397B806/DPM/dpMatchPeersCore:
008200: Aug 7 16:14:03.542: //-1/B864B397B806/DPM/dpMatchCore:
008201: Aug 7 16:14:03.542: //-1/B864B397B806/DPM/MatchNextPeer:
008202: Aug 7 16:14:03.542: //-1/B864B397B806/DPM/dpMatchPeersCore:
008203: Aug 7 16:14:03.542: //-1/B864B397B806/DPM/dpMatchSafModulePlugin:
008204: Aug 7 16:14:03.542: //-1/B864B397B806/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=5
008205: Aug 7 16:14:03.542: //24455/B864B397B806/CCAPI/ccCallReportDigits:
(callID=0x5F87, digit_event=0x0, enable=FALSE, consume=FALSE)
008206: Aug 7 16:14:03.542: //24455/B864B397B806/CCAPI/ccCallReportDigits:
008207: Aug 7 16:14:03.542: //24455/B864B397B806/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x88A3D9F0, callID=0x5F87, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
008208: Aug 7 16:14:03.542: //24455/B864B397B806/CCAPI/cc_api_call_report_digits_done:
008209: Aug 7 16:14:03.542: //24455/B864B397B806/CCAPI/cc_api_call_report_digits_done:
008210: Aug 7 16:14:03.542: //24455/B864B397B806/CCAPI/ccCallProceeding:
008211: Aug 7 16:14:03.542: //-1/B864B397B806/DPM/dpMatchPeersCore:
008212: Aug 7 16:14:03.542: //-1/B864B397B806/DPM/dpMatchPeersCore:
008213: Aug 7 16:14:03.542: //-1/B864B397B806/DPM/dpMatchCore:
008214: Aug 7 16:14:03.542: //-1/B864B397B806/DPM/MatchNextPeer:
008215: Aug 7 16:14:03.546: //-1/B864B397B806/DPM/dpMatchPeersCore:
008216: Aug 7 16:14:03.546: //-1/B864B397B806/DPM/dpMatchSafModulePlugin:
008217: Aug 7 16:14:03.546: //-1/B864B397B806/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=5
008218: Aug 7 16:14:03.546: //-1/B864B397B806/DPM/dpMatchPeersCore:
008219: Aug 7 16:14:03.546: //-1/B864B397B806/DPM/dpMatchPeersCore:
008220: Aug 7 16:14:03.546: //-1/B864B397B806/DPM/dpMatchCore:
008221: Aug 7 16:14:03.546: //-1/B864B397B806/DPM/MatchNextPeer:
008222: Aug 7 16:14:03.546: //-1/B864B397B806/DPM/dpMatchPeersCore:
008223: Aug 7 16:14:03.546: //-1/B864B397B806/DPM/dpMatchSafModulePlugin:
008224: Aug 7 16:14:03.546: //-1/B864B397B806/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=5
008225: Aug 7 16:14:03.546: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
008226: Aug 7 16:14:03.546: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
008227: Aug 7 16:14:03.546: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
008228: Aug 7 16:14:03.546: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
008229: Aug 7 16:14:03.546: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
008230: Aug 7 16:14:03.546: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
008231: Aug 7 16:14:03.546: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=5
008232: Aug 7 16:14:03.546: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008233: Aug 7 16:14:03.546: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008234: Aug 7 16:14:03.546: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
008235: Aug 7 16:14:03.546: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6610
008236: Aug 7 16:14:03.546: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008237: Aug 7 16:14:03.546: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008238: Aug 7 16:14:03.546: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Is Incoming=TRUE, Number Expansion=FALSE
008239: Aug 7 16:14:03.546: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
008240: Aug 7 16:14:03.546: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
008241: Aug 7 16:14:03.546: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
008242: Aug 7 16:14:03.546: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008243: Aug 7 16:14:03.546: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
008244: Aug 7 16:14:03.546: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
008245: Aug 7 16:14:03.546: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
008246: Aug 7 16:14:03.546: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5982
008247: Aug 7 16:14:03.546: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008248: Aug 7 16:14:03.546: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
008249: Aug 7 16:14:03.546: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6610
008250: Aug 7 16:14:03.546: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
008251: Aug 7 16:14:03.550: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
008252: Aug 7 16:14:03.550: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
008253: Aug 7 16:14:03.550: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
008254: Aug 7 16:14:03.550: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
008255: Aug 7 16:14:03.550: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
008256: Aug 7 16:14:03.550: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=5
008257: Aug 7 16:14:03.550: //-1/B864B397B806/DPM/dpMatchPeersCore:
008258: Aug 7 16:14:03.550: //-1/B864B397B806/DPM/dpMatchPeersCore:
008259: Aug 7 16:14:03.550: //-1/B864B397B806/DPM/dpMatchCore:
008260: Aug 7 16:14:03.550: //-1/B864B397B806/DPM/MatchNextPeer:
008261: Aug 7 16:14:03.550: //-1/B864B397B806/DPM/dpMatchPeersCore:
008262: Aug 7 16:14:03.550: //-1/B864B397B806/DPM/dpMatchSafModulePlugin:
008263: Aug 7 16:14:03.550: //-1/B864B397B806/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=5
008264: Aug 7 16:14:03.550: //-1/B864B397B806/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x8A46D06C; count=2
008265: Aug 7 16:14:03.550: //-1/B864B397B806/RXRULE/regxrule_dp_translate: No profile found in peer 5 for outgoing direction
008266: Aug 7 16:14:03.550: //-1/B864B397B806/RXRULE/regxrule_dp_translate: calling_number=BCD calling_octet=0x0
008267: Aug 7 16:14:03.550: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
008268: Aug 7 16:14:03.550: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
008269: Aug 7 16:14:03.550: : updating existing feature vsa
008270: Aug 7 16:14:03.550: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
008271: Aug 7 16:14:03.550: feature call basic
008272: Aug 7 16:14:03.554: //24455/B864B397B806/CCAPI/ccCallDisconnect:
008273: Aug 7 16:14:03.554: //24455/B864B397B806/CCAPI/ccCallDisconnect:
008274: Aug 7 16:14:03.554: //24455/B864B397B806/CCAPI/cc_api_get_transfer_info:
008275: Aug 7 16:14:03.566: //24455/B864B397B806/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x88A3D9F0, Tag=0x0, Call Id=24455,
008276: Aug 7 16:14:03.566: //-1/B864B397B806/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x8A46D06C; count=2
008277: Aug 7 16:14:03.566: //-1/B864B397B806/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x88EA875C
008278: Aug 7 16:14:03.566: //24455/B864B397B806/CCAPI/cc_api_call_disconnect_done:
008279: Aug 7 16:14:03.566: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
008280: Aug 7 16:14:03.566: :cc_free_feature_vsa freeing 88DF5D18
008281: Aug 7 16:14:03.566: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
008282: Aug 7 16:14:03.566: vsacount in free is 0
08-08-2011 11:22 AM
Hi, Mark:
Yes, the log tells SIP provider send BYE to kill the call.
Why ? It might be due to H450.12 or other issue.
The best bet is to ask SIP provider with this trace.
One thing you can try is to setup CFNA not to Voicemail, but to other internal extension and answered.
Does this scenario work ?
-David
08-08-2011 11:22 PM
Hi Mark,
I might be reading the logs Differently to David, but I am seeing Cause Code "17" shortly after it is transferred to the CUE, and then a little way down from that a code 487 "Interworking Unspecified" and there seems to be a repetition of it.
I do not believe it to be the ITSP terminating the call without something being initiated from the UC-520, whilst there is certainly evidence that that ITSP has sent a BYE message, I believe it to be because the UC-520 has had something go wrong.
I am curious, what is the Codec that is being used with the ITSP?
Can you just get a clean "debug ccsip" without the dial-peer debugging turned on, I would like to just focus on the SIP messages, so you will need to debug the call and also the errors, id suggest the following debug if you wouldn't mind but turn is of straight after the test as it can generate some heat on the system with CPU load and memory maxing.
"debug ccsip all"
Capture if possible at least 5 calls, and if you can vary them between being diverted to VM because of routing rules, and if possible try and throw in at least 2 calls that were done by using the Trans to VM function.
Also if you can follow David's suggestion of asking the ITSP for some call logs that would be great, although often more than not they are not very willing to do this.
Cheers,
David.
08-12-2011 03:53 AM
Sorry for the delay in getting back to everyone...
Most frustrating, but when I enable debug with debug ccsip all ... the voicemail does not cut off!
Tested messages up to 20+ seconds with no issue.
Turn debugging off... problem reappears. Was logging to the buffer not console if that makes any difference.
Struggling to get a meaningfull log showing the problem!
ITSP probably isn't going to be too keen to give us call logs from their end.
01-13-2012 04:39 AM
Again sorry for the delay in following up on this... priorities changed, but now it is important again.
Any ideas as the the best way forwards? As I said before, turning on the debugging all setting actually makes the problem go away. It must be timing related and the debugging slows things enough so it doesn't happen.
Catch22; No debugging captured and the issue happens. Debugging on, to capture the event, and it doesn't occur.
Does any one know which debugging message I should be concentrating on?
01-15-2012 04:28 PM
Hi Mark,
Good to see you back here again
Ok so with you telling us that when you turn on debugging the issues doesn't happen, and then when you turn it off it does happen (???) I am going to just have to say you really need to log a case for this, if it is indeed a bug somewhere then it needs to be identified, it just doesn't make sense for that to happen.
Turning debugging on should not effect timing of the SIP trunk in anyway, only the CPU load on the system.
Cheers,
David.
03-02-2012 04:04 AM
I am going to reply to my own post as I now have an answer.... I guess I can't give myself a point for that!
Thanks for everyone's input on this, I have now found the issue.
Our SIP provider changed their gateway this month and the problem disapeared. Therefore, though clearly there must have been an issue on the UC520 side (otherwise the strange situation of enabling debugs affecting the result would not be happening), the old gateway must also have had an issue.
Though we have no connection with them other than a customer, I wish to mention that our provider here in the UK is Hostcomm, and they were very helpful in asisting with some additional configuration that was required to authenticate on our side after the gateway change.
If anyone does want to use them, I can give them the template/settings that I know work for us on the UC520.
Thanks again
Mark
