Using CCA 2.5 or CCA 1.9 with UC520
b_rasheed
Can I use CCA 2.5 to upgrade from CME 4.2/CUE 3.0 on UC520 to CME7.0/CUE 7.0 or should I use CCA1.9?
Thanks.
mcasimirc63
Level 4
Level 4
Use 2.5.  There have been many important and much needed updates from 1.9 to 2.5
mcasimirc63
Level 4
Level 4
Thanks a lot Marcus, my main concern was the compatibility issue that's all.
I did my upgrade and it went very smooth with CCA 2.5
Thanks again.
