Voicemail notification not working
Sblazer614
We have SIP trunks on our UC540 and when a voicemail is left the system does notify and call the cell phone.  The call does request the mailbox users ID, but won't accept any digits and eventually hangs  up.
Has anyone experienced this event?
David Trad
Hi Sblaze614,
Is the system dialing back out over the SIP trunk? And if so what CoDEC is it using??
What happens if you long press each key, and I mean at least a good 1 second per press.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
No luck with the long press. Not sure of the SIP Codec.
Steve Blazer
Director of Sales
Serving Ohio for over 45 years
Sblazer@data-talk.com
614.784.7110 direct
614.545.7110 fax
This e-mail message is intended only for the person or entity to which it is addressed and is confidential, subject to copyright and may be legally privileged. Any unauthorized review, use or disclosure is prohibited. If you received this in error, please contact the sender and delete all copies and attachments.
Sblazer,
Do you have the same issue when you call into an Auto Attendant?
If so, this is most likely due to the DTMF settings on your dial-peer or your SIP provider doesn't support RFC2833.  Make sure you have this on your outgoing/incoming dial peer:
voice-class sip dtmf-relay force rtp-nte
or
dtmf-relay sip-notify
