12-05-2023 12:54 PM - editado 12-05-2023 01:20 PM
Hello, I'm configuring a CUBE in which all incoming calls from one source should be routed ot a specific desination, except for one number (3183518766) which should be returned to the called party replaced by another number. So, I configured two incoming dial-peers like this:
dial-peer voice 100 voip
description ***Entrantes troncal Colombia NGN-Movistar***
session protocol sipv2
destination dpg 901
incoming uri via 110
voice-class codec 100
voice-class sip tenant 100
dtmf-relay rtp-nte
no vad
dial-peer voice 104 voip
description ***Entrantes troncal Colombia NGN-Movistar caso 3183518766***
destination dpg 110
incoming called-number 3183518766
dtmf-relay rtp-nte
no vad
However, always dp 100 is selected, despite of the dialed number. I though that when call is for 3183518766 dp 104 would be selcted, as it has more matching elements (it's more specific), but I think it's working by selecting the first dp it founds for incoming uri 110 and ignores the other one.
So, do you think could be any way of using the other dp when call is for 3183518766? Or how could I make this call be routed in other way than being sent to destination dpg 901?
Thank you.
el 12-05-2023 01:14 PM
Hola, puede que me esté perdiendo algo, pero los dos 'dial-peer me parecen iguales, ¿excepto por el dpg? ¿Dónde está la diferencia?
el 12-05-2023 01:24 PM
Sorry, I must have copied it from a provisional config, 'incoming called-number' shouldn't be there, now I corrected it. The idea is that all calls go to dpg 901 except for call to 3183518766 that should go to dpg 110.
Thanks.
el 12-05-2023 01:51 PM
Bonjour,
si je me souviens bien, vous pouvez définir la préférence :
destination-pattern 901
dtmf-relay rtp-nte
no vad
preference 1 ; Set a preference value, e.g., 1
destination-pattern 3183518766
dtmf-relay rtp-nte
no vad
preference 0 ; Set a lower preference value, e.g., 0
el 12-05-2023 02:10 PM
There you not only added the preference but also replaced the destination dpg by a destination pattern. And 901 is not a dialled number, it's an outbound dial-peer. Like this there is no destination or target for these calls. Besides, I had already tried with different preferences (I usted 1 and 2 instead of 0 anda 1) but the same happened. The first dp is always chosen.
Descubra y salve sus notas favoritas. Vuelva a encontrar las respuestas de los expertos, guías paso a paso, temas recientes y mucho más.
¿Es nuevo por aquí? Empiece con estos tips. Cómo usar la comunidad Guía para nuevos miembros
Navegue y encuentre contenido personalizado de la comunidad
