Cisco VPN Client 5.0.0 not connecting
rick505d3
I am trying to establish VPN session to Cisco ASA 5525X firewall running 9.1.1 through Cisco VPN Client. Although AnyConnect is the way forward, still the legacy method would need to be supported for some time as this is part of a migration. I tried two VPN users (authenticated through AD) on two client machines running Windows 7 64-bit and Cisco VPN Client 5.0.07.0440. Both the users are successfull establishing a session from one machine to the ASA but not the other. On entering wrong credentails, the login pop-up appears immediately. On correct username/password combination, the following VPN client log messages are generated and the session drops i.e. "Not connected." in the status bar. The PCF file is the same across both client machines.
Cisco Systems VPN Client Version 5.0.07.0440
Copyright (C) 1998-2010 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 6.1.7601 Service Pack 1
119    22:49:16.933  06/23/13  Sev=Info/6          IKE/0x6300003B
Attempting to establish a connection with 203.99.111.44.
120    22:49:16.939  06/23/13  Sev=Info/4          IKE/0x63000001
Starting IKE Phase 1 Negotiation
121    22:49:16.942  06/23/13  Sev=Info/4          IKE/0x63000013
SENDING >>> ISAKMP OAK AG (SA, KE, NON, ID, VID(Xauth), VID(dpd), VID(Frag), VID(Nat-T), VID(Unity)) to 203.99.111.44
122    22:49:16.973  06/23/13  Sev=Info/5          IKE/0x6300002F
Received ISAKMP packet: peer = 203.99.111.44
123    22:49:16.973  06/23/13  Sev=Info/4          IKE/0x63000014
RECEIVING <<< ISAKMP OAK AG (SA, KE, NON, ID, HASH, VID(Unity), VID(Xauth), VID(dpd), VID(Nat-T), NAT-D, NAT-D, VID(Frag), VID(?)) from 203.99.111.44
124    22:49:16.974  06/23/13  Sev=Info/5          IKE/0x63000001
Peer is a Cisco-Unity compliant peer
125    22:49:16.974  06/23/13  Sev=Info/5          IKE/0x63000001
Peer supports XAUTH
126    22:49:16.974  06/23/13  Sev=Info/5          IKE/0x63000001
Peer supports DPD
127    22:49:16.974  06/23/13  Sev=Info/5          IKE/0x63000001
Peer supports NAT-T
128    22:49:16.974  06/23/13  Sev=Info/5          IKE/0x63000001
Peer supports IKE fragmentation payloads
129    22:49:16.977  06/23/13  Sev=Info/6          IKE/0x63000001
IOS Vendor ID Contruction successful
130    22:49:16.977  06/23/13  Sev=Info/4          IKE/0x63000013
SENDING >>> ISAKMP OAK AG *(HASH, NOTIFY:STATUS_INITIAL_CONTACT, NAT-D, NAT-D, VID(?), VID(Unity)) to 203.99.111.44
131    22:49:16.977  06/23/13  Sev=Info/6          IKE/0x63000055
Sent a keepalive on the IPSec SA
132    22:49:16.977  06/23/13  Sev=Info/4          IKE/0x63000083
IKE Port in use - Local Port =  0xCA7C, Remote Port = 0x1194
133    22:49:16.977  06/23/13  Sev=Info/5          IKE/0x63000072
Automatic NAT Detection Status:
   Remote end is NOT behind a NAT device
   This   end IS behind a NAT device
134    22:49:17.000  06/23/13  Sev=Info/5          IKE/0x6300002F
135    22:49:17.000  06/23/13  Sev=Info/4          IKE/0x63000014
RECEIVING <<< ISAKMP OAK TRANS *(HASH, ATTR) from 203.99.111.44
136    22:49:17.211  06/23/13  Sev=Info/4          IPSEC/0x63700008
IPSec driver successfully started
137    22:49:17.211  06/23/13  Sev=Info/4          IPSEC/0x63700014
Deleted all keys
138    22:49:23.207  06/23/13  Sev=Info/4          IKE/0x63000013
SENDING >>> ISAKMP OAK TRANS *(HASH, ATTR) to 203.99.111.44
139    22:49:23.393  06/23/13  Sev=Info/5          IKE/0x6300002F
140    22:49:23.393  06/23/13  Sev=Info/4          IKE/0x63000014
141    22:49:23.393  06/23/13  Sev=Info/4          IKE/0x63000013
142    22:49:23.401  06/23/13  Sev=Info/5          IKE/0x6300005E
Client sending a firewall request to concentrator
143    22:49:23.401  06/23/13  Sev=Info/4          IKE/0x63000013
144    22:49:23.427  06/23/13  Sev=Info/5          IKE/0x6300002F
145    22:49:23.427  06/23/13  Sev=Info/4          IKE/0x63000014
146    22:49:23.427  06/23/13  Sev=Info/5          IKE/0x63000010
MODE_CFG_REPLY: Attribute = INTERNAL_IPV4_ADDRESS: , value = 10.2.193.69
147    22:49:23.427  06/23/13  Sev=Info/5          IKE/0x63000010
MODE_CFG_REPLY: Attribute = INTERNAL_IPV4_DNS(1): , value = 10.2.5.2
148    22:49:23.428  06/23/13  Sev=Info/5          IKE/0x63000010
MODE_CFG_REPLY: Attribute = INTERNAL_IPV4_DNS(2): , value = 10.1.5.2
149    22:49:23.428  06/23/13  Sev=Info/5          IKE/0x6300000D
MODE_CFG_REPLY: Attribute = MODECFG_UNITY_SAVEPWD: , value = 0x00000000
150    22:49:23.428  06/23/13  Sev=Info/5          IKE/0x6300000D
MODE_CFG_REPLY: Attribute = MODECFG_UNITY_SPLIT_INCLUDE (# of split_nets), value = 0x00000001
151    22:49:23.428  06/23/13  Sev=Info/5          IKE/0x6300000F
SPLIT_NET #1
subnet = 10.0.0.0
mask = 255.0.0.0
protocol = 0
src port = 0
dest port=0
152    22:49:23.428  06/23/13  Sev=Info/5          IKE/0x6300000E
MODE_CFG_REPLY: Attribute = MODECFG_UNITY_DEFDOMAIN: , value = example.org
153    22:49:23.428  06/23/13  Sev=Info/5          IKE/0x6300000D
MODE_CFG_REPLY: Attribute = MODECFG_UNITY_PFS: , value = 0x00000000
154    22:49:23.428  06/23/13  Sev=Info/5          IKE/0x6300000E
MODE_CFG_REPLY: Attribute = APPLICATION_VERSION, value = Cisco Systems, Inc ASA5525 Version 9.1(1) built by builders on Wed 28-Nov-12 11:15 PST
155    22:49:23.428  06/23/13  Sev=Info/5          IKE/0x6300000D
MODE_CFG_REPLY: Attribute = MODECFG_UNITY_SMARTCARD_REMOVAL_DISCONNECT: , value = 0x00000001
156    22:49:23.428  06/23/13  Sev=Info/5          IKE/0x6300000D
MODE_CFG_REPLY: Attribute = Received and using NAT-T port number , value = 0x00001194
157    22:49:23.445  06/23/13  Sev=Info/4          IKE/0x63000056
Received a key request from Driver: Local IP = 10.2.193.69, GW IP = 203.99.111.44, Remote IP = 0.0.0.0
158    22:49:23.445  06/23/13  Sev=Info/4          IKE/0x63000013
SENDING >>> ISAKMP OAK QM *(HASH, SA, NON, ID, ID) to 203.99.111.44
159    22:49:23.477  06/23/13  Sev=Info/5          IKE/0x6300002F
160    22:49:23.477  06/23/13  Sev=Info/4          IKE/0x63000014
RECEIVING <<< ISAKMP OAK INFO *(HASH, NOTIFY:STATUS_RESP_LIFETIME) from 203.99.111.44
161    22:49:23.477  06/23/13  Sev=Info/5          IKE/0x63000045
RESPONDER-LIFETIME notify has value of 86400 seconds
162    22:49:23.477  06/23/13  Sev=Info/5          IKE/0x63000047
This SA has already been alive for 7 seconds, setting expiry to 86393 seconds from now
163    22:49:23.477  06/23/13  Sev=Info/5          IKE/0x6300002F
164    22:49:23.477  06/23/13  Sev=Info/4          IKE/0x63000014
RECEIVING <<< ISAKMP OAK INFO *(HASH, NOTIFY:NO_PROPOSAL_CHOSEN) from 203.99.111.44
165    22:49:23.478  06/23/13  Sev=Info/4          IKE/0x63000013
SENDING >>> ISAKMP OAK INFO *(HASH, DEL) to 203.99.111.44
166    22:49:23.478  06/23/13  Sev=Info/4          IKE/0x63000049
Discarding IPsec SA negotiation, MsgID=F3E3C530
167    22:49:23.478  06/23/13  Sev=Info/4          IKE/0x63000017
Marking IKE SA for deletion  (I_Cookie=CD65262E1C3808E4 R_Cookie=912AE160ADADEE65) reason = DEL_REASON_IKE_NEG_FAILED
168    22:49:23.478  06/23/13  Sev=Info/5          IKE/0x6300002F
169    22:49:23.479  06/23/13  Sev=Info/4          IKE/0x63000058
Received an ISAKMP message for a non-active SA, I_Cookie=CD65262E1C3808E4 R_Cookie=912AE160ADADEE65
170    22:49:23.479  06/23/13  Sev=Info/4          IKE/0x63000014
RECEIVING <<< ISAKMP OAK INFO *(Dropped) from 203.99.111.44
171    22:49:24.310  06/23/13  Sev=Info/4          IPSEC/0x63700014
Deleted all keys
172    22:49:26.838  06/23/13  Sev=Info/4          IKE/0x6300004B
Discarding IKE SA negotiation (I_Cookie=CD65262E1C3808E4 R_Cookie=912AE160ADADEE65) reason = DEL_REASON_IKE_NEG_FAILED
173    22:49:26.849  06/23/13  Sev=Info/4          IKE/0x63000001
IKE received signal to terminate VPN connection
174    22:49:26.855  06/23/13  Sev=Info/4          IPSEC/0x63700014
Deleted all keys
175    22:49:26.855  06/23/13  Sev=Info/4          IPSEC/0x63700014
Deleted all keys
176    22:49:26.855  06/23/13  Sev=Info/4          IPSEC/0x63700014
Deleted all keys
177    22:49:26.855  06/23/13  Sev=Info/4          IPSEC/0x6370000A
IPSec driver successfully stopped
Any ideas why the second Windows 7 client is not working ?
Rick.
Rick
Thanks for the additional output. It does show the xauth authentication step, which is good to see. But it does not offer much clarity about what is causing the problem.
My attention is drawn to a couple of message from the logs which are consistent in both sessions for which you have posted logs.
32     00:36:08.178  06/24/13  Sev=Info/5          IKE/0x6300005E
I am not sure that we see any response to this but it makes me wonder if this is somehow involved in the problem. Is it possible that there is any difference in firewall setup and operation between the two clients?
I also am interested in this series of messages
48     00:36:08.210  06/24/13  Sev=Info/4          IKE/0x63000056
I am not sure why the Driver is doing a key request at this point, and I wonder why the remote IP is 0.0.0.0?
It is followed by a packet in which the ASA provides the value of the SA lifetime - which would seem to be on the track toward successful connection. which is followed by
55     00:36:08.350  06/24/13  Sev=Info/5          IKE/0x6300002F
56     00:36:08.350  06/24/13  Sev=Info/4          IKE/0x63000014
in which the ASA indicates that no proposal was chosen. So it appears that the ASA is not happy about something.
If we are not finding indications from the client that identify the problem then perhaps we need to look at the ASA. Are any log messages generated on the ASA during this attempt to establish VPN that might show us the problem? Would it be feasible to run debugs on the ASA during a test from this machine?
Rick
Rick
5 Replies 5
Richard Burts
Rick
It seems from messages 146 through 156 that negotiation was successful and the client is receiving parameters from the ASA. But I do not see anything in the log messages that indicates the authentication process. I wonder if anything else happened that is not reflected in these logs? I would suggest that you check the logging setting in the client, make sure that all categories are set to high, and run the test again and post the complete log output from the client.
Through message 162 the messages seem to indicate that processes are headed toward a successful connection. Then message 164 says that no proposal was chosen (coming from the ASA). So I wonder if something is going on with the ASA. Are there any log messages from the ASA when this happens? Is it feasible to run debug on the ASA during this test?
Rick
Rick
Thanks Rick, the following output is generated when Log Settings are set to all High.
1      00:36:00.051  06/24/13  Sev=Info/4          CM/0x63100002
Begin connection process
2      00:36:00.098  06/24/13  Sev=Info/4          CM/0x63100004
Establish secure connection
3      00:36:00.098  06/24/13  Sev=Info/4          CM/0x63100024
Attempt connection with server "203.99.111.44"
4      00:36:00.098  06/24/13  Sev=Info/6          IKE/0x6300003B
5      00:36:00.098  06/24/13  Sev=Info/4          IKE/0x63000001
6      00:36:00.113  06/24/13  Sev=Info/4          IKE/0x63000013
7      00:36:00.113  06/24/13  Sev=Info/4          IPSEC/0x63700008
8      00:36:00.113  06/24/13  Sev=Info/4          IPSEC/0x63700014
Deleted all keys
9      00:36:00.144  06/24/13  Sev=Info/5          IKE/0x6300002F
10     00:36:00.144  06/24/13  Sev=Info/4          IKE/0x63000014
11     00:36:00.144  06/24/13  Sev=Info/5          IKE/0x63000001
12     00:36:00.144  06/24/13  Sev=Info/5          IKE/0x63000001
Peer supports XAUTH
13     00:36:00.144  06/24/13  Sev=Info/5          IKE/0x63000001
Peer supports DPD
14     00:36:00.144  06/24/13  Sev=Info/5          IKE/0x63000001
Peer supports NAT-T
15     00:36:00.144  06/24/13  Sev=Info/5          IKE/0x63000001
16     00:36:00.144  06/24/13  Sev=Info/6          IKE/0x63000001
17     00:36:00.144  06/24/13  Sev=Info/4          IKE/0x63000013
18     00:36:00.144  06/24/13  Sev=Info/6          IKE/0x63000055
19     00:36:00.144  06/24/13  Sev=Info/4          IKE/0x63000083
IKE Port in use - Local Port =  0xE953, Remote Port = 0x1194
20     00:36:00.144  06/24/13  Sev=Info/5          IKE/0x63000072
21     00:36:00.144  06/24/13  Sev=Info/4          CM/0x6310000E
Established Phase 1 SA.  1 Crypto Active IKE SA, 0 User Authenticated IKE SA in the system
22     00:36:00.160  06/24/13  Sev=Info/5          IKE/0x6300002F
23     00:36:00.160  06/24/13  Sev=Info/4          IKE/0x63000014
24     00:36:00.160  06/24/13  Sev=Info/4          CM/0x63100015
Launch xAuth application
25     00:36:00.176  06/24/13  Sev=Info/6          GUI/0x63B00012
Authentication request attributes is 6h.
26     00:36:08.038  06/24/13  Sev=Info/4          CM/0x63100017
xAuth application returned
27     00:36:08.038  06/24/13  Sev=Info/4          IKE/0x63000013
28     00:36:08.163  06/24/13  Sev=Info/5          IKE/0x6300002F
29     00:36:08.163  06/24/13  Sev=Info/4          IKE/0x63000014
30     00:36:08.163  06/24/13  Sev=Info/4          IKE/0x63000013
31     00:36:08.163  06/24/13  Sev=Info/4          CM/0x6310000E
Established Phase 1 SA.  1 Crypto Active IKE SA, 1 User Authenticated IKE SA in the system
33     00:36:08.178  06/24/13  Sev=Info/4          IKE/0x63000013
34     00:36:08.194  06/24/13  Sev=Info/5          IKE/0x6300002F
35     00:36:08.194  06/24/13  Sev=Info/4          IKE/0x63000014
36     00:36:08.194  06/24/13  Sev=Info/5          IKE/0x63000010
37     00:36:08.194  06/24/13  Sev=Info/5          IKE/0x63000010
38     00:36:08.194  06/24/13  Sev=Info/5          IKE/0x63000010
39     00:36:08.194  06/24/13  Sev=Info/5          IKE/0x6300000D
40     00:36:08.194  06/24/13  Sev=Info/5          IKE/0x6300000D
41     00:36:08.194  06/24/13  Sev=Info/5          IKE/0x6300000F
SPLIT_NET #1
subnet = 10.0.0.0
mask = 255.0.0.0
protocol = 0
src port = 0
dest port=0
42     00:36:08.194  06/24/13  Sev=Info/5          IKE/0x6300000E
43     00:36:08.194  06/24/13  Sev=Info/5          IKE/0x6300000D
44     00:36:08.194  06/24/13  Sev=Info/5          IKE/0x6300000E
45     00:36:08.194  06/24/13  Sev=Info/5          IKE/0x6300000D
46     00:36:08.194  06/24/13  Sev=Info/5          IKE/0x6300000D
47     00:36:08.194  06/24/13  Sev=Info/4          CM/0x63100019
Mode Config data received
49     00:36:08.210  06/24/13  Sev=Info/4          IKE/0x63000013
50     00:36:08.256  06/24/13  Sev=Info/4          IPSEC/0x63700014
Deleted all keys
51     00:36:08.350  06/24/13  Sev=Info/5          IKE/0x6300002F
52     00:36:08.350  06/24/13  Sev=Info/4          IKE/0x63000014
53     00:36:08.350  06/24/13  Sev=Info/5          IKE/0x63000045
54     00:36:08.350  06/24/13  Sev=Info/5          IKE/0x63000047
This SA has already been alive for 8 seconds, setting expiry to 86392 seconds from now
57     00:36:08.350  06/24/13  Sev=Info/4          IKE/0x63000013
58     00:36:08.350  06/24/13  Sev=Info/4          IKE/0x63000049
Discarding IPsec SA negotiation, MsgID=F6670759
59     00:36:08.350  06/24/13  Sev=Info/4          IKE/0x63000017
Marking IKE SA for deletion  (I_Cookie=3F8BF9480B75C4A2 R_Cookie=A8A3F19D035B6D01) reason = DEL_REASON_IKE_NEG_FAILED
60     00:36:08.350  06/24/13  Sev=Info/5          IKE/0x6300002F
61     00:36:08.350  06/24/13  Sev=Info/4          IKE/0x63000058
Received an ISAKMP message for a non-active SA, I_Cookie=3F8BF9480B75C4A2 R_Cookie=A8A3F19D035B6D01
62     00:36:08.350  06/24/13  Sev=Info/4          IKE/0x63000014
63     00:36:10.955  06/24/13  Sev=Info/6          CVPND/0x63400006
Service reports: "Running".
64     00:36:11.860  06/24/13  Sev=Info/4          IKE/0x6300004B
Discarding IKE SA negotiation (I_Cookie=3F8BF9480B75C4A2 R_Cookie=A8A3F19D035B6D01) reason = DEL_REASON_IKE_NEG_FAILED
65     00:36:11.860  06/24/13  Sev=Info/4          CM/0x63100012
Phase 1 SA deleted before first Phase 2 SA is up cause by "DEL_REASON_IKE_NEG_FAILED".  0 Crypto Active IKE SA, 0 User Authenticated IKE SA in the system
66     00:36:11.860  06/24/13  Sev=Info/5          CM/0x63100025
Initializing CVPNDrv
67     00:36:11.860  06/24/13  Sev=Info/6          CM/0x63100046
Set tunnel established flag in registry to 0.
68     00:36:11.860  06/24/13  Sev=Info/4          IKE/0x63000001
69     00:36:11.876  06/24/13  Sev=Info/4          IPSEC/0x63700014
Deleted all keys
70     00:36:11.876  06/24/13  Sev=Info/4          IPSEC/0x63700014
Deleted all keys
71     00:36:11.876  06/24/13  Sev=Info/4          IPSEC/0x63700014
Deleted all keys
72     00:36:11.876  06/24/13  Sev=Info/4          IPSEC/0x6370000A
Rick.
Rick
Rick
Rick
Thanks Rick, much appreciate your replies. Yes you are right the ASA was not happy about something and that something was "crypto dynamic-map Internet_dyn_map 20 set nat-t-disable" being configured. This was configured on the old firewall ASA5540 running 7.2.4 and we didn't had any issues. With the new ASA5525X running 9.1 and migrated config, it didn't like it. Removed the line and it worked.
Rick.
Rick
I am glad that my suggestion pointed you toward the problem. I am glad that you have solved it. Thanks for posting back to the forum to tell us that you have solved it. And thanks for using the rating system to mark the question as answered. It makes the forum more useful when people can read a question and can know that a solution was found. Your marking has contributed to this process.
Rick
Rick
