How to Go directly into priv mode with local account and AAA configured
CiscoBrownBelt
Level 6
Level 6
I would like to know how to go directly into priveledge mode using local account (if TACACs is down). I tried doing different "if-authenticated configs" and it still prompts for an enable password to go into enable mode. Also, is there anything else I need to add under line console 0 if I want to always use local accounts to access the line con 0?
Here are my AAA configs:
aaa authentication login default group tacacs+ local line enable
aaa authentication enable default group tacacs+ enable
aaa authorization exec default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
6 Replies 6
johnd2310
Level 8
Level 8
what is the configuration of the local user account? It should be something like:
username XXXX secret XXXX priviledge XXXX
For console login to use local account, make sure you have a local account and try the following:
aaa authentication login console-login local
line console 0
     login authentication console-login
John
**Please rate posts you find helpful**
Yes it is priv 15 for user account.
I thought the AAA authentication will apply to all mgmt. ports (mgmt., line con, vty, etc.)?
Yes username is priv 15.
If I don't add the AAA authentication config and line con 0 config you described, will I still be prompted to enter my TACACs creds if the server is up when attempting to console into a device?
the below gets you directly into enable mode when using the local account, is this what you are looking for ?
username admin privilege 15 secret cisco
aaa new-model
line vty 0 4
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
Oh ok so I should take out the "line enable" from my 1st AAA config line, and then add: privilege level 15 under line vty 0 4? what about vty 5 15?
Exactly.
And yes, configure vty 5 15 in the same way as 0 4.
