Issue connect with AnyConnect
MarcoM
Hi all,
i have a strange issue with Vpn Anyconnect on a platform ASA 5510 with version 9.0(3) and ASDM 7.1(3).
I configured Anyconnect IKEv2 with self-signed certificate.
When connect with Anyconnect client (version 3.1.02040) its fail with this error:
Same issue with WebLaunch cannot install client.
Please help me.
In attach step of configuration AnyConnect.
Thanks all for reply.
9 Replies 9
Jeet Kumar
I checked your configuration and your configuration is fine.
Please make sure the primary protocol on the connection profile should be Ipsec and not ssl.
If possible could you please upload the client profile as well.
Jeet Kumar
Hi Jeet,
thanks for reply. In attach client profile. i also attached screen of Connection Profiles.
Thanks.
MM
Hi Marco.,
It si possible for you to messgae me the following, if you don't want to pste it here email me.
sh run webvpn
sh run tunnel-group VpnAnyConnect
sh run group-policy VpnAnyConnect
sh version
I will check it and will get back to you.
Hi Jeet,
in attach config required.
Let me know please.
Thanks in advance.
for few days i hav had the same issue. The problem could be the Group Policy settings.
You dont use the standard GP right?
Markus
Hi Markus,
no i use custom GP (as you see on screenshot attached).
How you fixed?
Thanks.
MM
Please use the standard GP. It will be work.
Jeet Kumar
Hi Jeet,
there is news?
let me know please.
Thanks.
