Anyconnect connection for ISP1 fails, ISP2 works
mcgiga
I have configured two ISPs (WAN1, WAN2). VPN with anyconnect was already working for both ISPs. Today when doing final tests, VPN for ISP1 on WAN1 is not working anymore. ISP2 on WAN2 still works.
ASA log shows:
1	Starting SSL handshake with client WAN1: 10.10.10.10/50083 to  10.10.10.6/443 for TLS session
2	Device selects trust-point ASDM_TrustPoint1 for client WAN1: 10.10.10.10/50083 to  10.10.10.6/443
3	Device completed SSL handshake with client WAN1: 10.10.10.10/50083 to  10.10.10.6/443 for TLSv1.3 session
4	SSL session with client WAN1: 10.10.10.10/50083 to  10.10.10.6/443 terminated
5	Teardown TCP connection 9360 for WAN1: 10.10.10.10/50083 to identity: 10.10.10.6/443 duration 0:00:00 bytes 3906 TCP Reset-O from identity
6	Deny TCP (no connection) from  10.10.10.10/50083 to  10.10.10.6/443 flags FIN ACK  on interface WAN1
I don't have a clue what the issue could be.
mcgiga
We have found the cause in cooperation with Cisco TAC.
We needed to configure a group URL in the tunnel group profile, i. e. vpn1.domain.com/TunnelGroupName
It's unclear why this group URL is not needed for the configured backup server in the anyconnect XML. The second vpn connection was still working but not the primary one.
10 Replies 10
balaji.bandi
what model of ASA  and what Code running on that. is the ASA behind NAT for teh VPN ?
how are you load-balancing the VPN connection over DNS ?
check some configuration reference ( Also provide the config you have, removing confidential information)
https://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/68328-remotevpn-loadbal-asa.html
BB
It's a Secure Firewall 3105 running ASA. Version is 9.20(3)4. ASA is located behind both ISP routers.
There is no load balacing. ISP1 is used for VPN primary. If ISP1 fails and ASA switches to ISP2 with it's default route we connect to that WAN ip address. There are two a-records in dns for each ISP (like VPN1.domain, VPN2.domain). Anyconnect has VPN2 specified as backup server.
It's weird because everything was working. I don't know what changes could have caused it. Previously we had running 9.20(3).
I have downgraded to 9.20(3) but the issue still exists.
Hi'
Do packet capture in both WAN interface'
Use IP of anyconnect PC (real IP not IP assign from vpn pool) in your capture.
I think you have asymmetric traffic that lead to make tcp teardown.
MHM
What/how do I have to do?
Packet tracer was fine but maybe not precisely enough.
Not packet tracer' but capture
If the traffic is asymmetric then it will drop.
https://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/118097-configure-asa-00.html
MHM
I will capture it later and come back.
I tought about asymetric routing but don't know where that should happen.
Post high level diagram to have look.,
how does the ASA know the ISP1 Failed and failover required to other ISP2 ?
ISP Router managed by you ?
can you post the configuration.  also refer the document which i have posted.
how does the DNS works ? round robin ?
BB
mcgiga
Sorry can you more elaborate about TAC suggestion
Thanka a lot
MHM
