AnyConnect Secure Mobility problem
pcfreak49
Level 7
Level 7
I have a problem I would AnyConnect Secure Mobility make from laptops, tablets how can you do that
Javier Portuguez
Level 11
Level 11
Please find the list of supported Android devices in the link below:
Release Notes for Cisco AnyConnect Secure Mobility Client 3.0.x for Android Mobile Devices
On the other hand, you should not encounter any issues on iPads.
HTH.
Portu.
Please rate any helpful posts
ju_mobile
Level 5
Level 5
You will need specific licensing for mobile devices. Apologies your explanation is not very clear in what your requirements are or without a great deal of assumption what questions your raising. Please can you clarify?
Best Regards
Ju
