ASA Accounting problem with tacacs
muhammad-furqan
i am trying to configure AAA accounting on ASA with tacacs but unable to get the accounting logs on ACS, but at asdm i saw asa is sending logs successfully and all are accepted, i change the protocol to radius and its working fine what is the reason if any one know
vabruno
Is the ASA you are trying to configure AAA Accounting via tacacs in EZVPN mode or client mode? and if so what version of code are you running on the ASA. Currently there is a known bug with version 8.x using tacacs via an EZVPN Client mode but Radius works fine.
I tried 7.1 and 7.2, i configured ASA as remote access VPN server
