ASA5510, Win XP Pro, Split Tunneling problem
I'm using an ASA5510 for remote access IPSec VPN clients and it is configured for split-tunnelling.  The client computers are running Cisco VPN client software.  All of the client computers running Win 7 work perfect, but the client computers running Win XP Pro cannot browse the internet, they only connect to the inside network.
Can you please tell me:
1) Does XP Pro support split tunneling when using the Cisco VPN client software?
2) Does the ASA require a special config to support split tunneling with Win XP clients?
Any help is greatly appreciated!
Mitchell Smith
North Texas Networks
Jennifer Halim
Don't think there is anything special that needs to be configured on XP Pro to support split tunneling.
Please kindly ensure the following:
1) XP Pro client is using the correct group with split tunnel configured
2) When the client is connected, the split tunnel ACL is indeed pushed down to the user
3) Check the local routing table on the XP Pro once the VPN Client is connected
