Auto Connect to RAVPN using AnyConnect
fatalXerror
Level 5
Level 5
Hi Guys,
Good Day!
Is there's a way in AnyConnect with an ASA 9.1 as my headend to have an automatic connection once the endpoint boots up? I mean no user interaction required for the RAVPN to have a successful establish connection?
Thank you.
Philip D'Ath
Yes.  You need to use certificates for authentication so no user prompts are required.
Here is the reference for the start before login feature:
http://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/107598-sbl.html
If you want local authentication, then configure the ASA as a CA server.
Then configure the AnyConnect client to get a certificate via SCEP from the ASA CA server.
Hi p.dath,
Good day!
So Self-Signed Cert of the ASA will not able to work right?
You can make it work - but when you can buy an SSL123 certificate from GoDaddy for about $100 per year - how hard do you want to work to make a self signed certificate work?
