Certificat problem
e-mourad
I have configured the windows 2000 advanced server ca.
Also, i have configured the pix with 2 isakmp policy.
the first :
Protection suite of priority 10
encryption algorithm: DES - Data Encryption Standard (56 bit keys).
hash algorithm: Message Digest 5
authentication method: Pre-Shared Key
Diffie-Hellman group: #2 (1024 bit)
lifetime: 86400 seconds, no volume limit
teh second :
Protection suite of priority 20
authentication method: Rivest-Shamir-Adleman Signature
lifetime: 1000 seconds, no volume limit
For the first there is no problem. it works correctly.
but when using certificat, i have this log :
ISAKMP: encyption....What?7? in all ISAKMP proposal
I use cisco client 3.x and PIX 515E 6.2
Thanks for help
7 Replies 7
drolemc
Level 6
Level 6
That's a strange debug you are getting. My search with that string did not turn up much. However, one candidate is bug CSCdy76457 - VPN Client 3.6.1 doesnt support DES with certificates. If this indeed turns out to be the defect you are running into, you will need to switch to client version 3.5.4. HTH
The exact log is :
ISAKMP: encryption... Whats? 7?
ISAKMP: hash SHA
I use the vpn client ver 3.6.3
I have upgraded the PIX to 6.3.(4)
is it supporting DES wirth certificate ?
I have searched for 3.5.x in the Internet but i didn't find it ?
If you have this version, can you send it to me please,
my email: networking@nouvelair.com.tn
Thanks for all
After installation of the PIX IOS 6.3(4) the log become : (I have used vpn client 4.0, my PIX don't have 3DES licence.
ISAKMP (0): Checking ISAKMP transform 1 against priority 8 policy
ISAKMP: encryption AES-CBC
ISAKMP: hash SHA
ISAKMP: default group 5
ISAKMP: extended auth RSA sig (init)
ISAKMP: life type in seconds
ISAKMP: life duration (VPI) of 0x0 0x20 0xc4 0x9b
ISAKMP: keylength of 256
ISAKMP (0): atts are not acceptable. Next payload is 3
ISAKMP (0): Checking ISAKMP transform 7 against priority 8 policy
ISAKMP: hash SHA
ISAKMP: default group 2
ISAKMP: auth RSA sig
ISAKMP (0): Checking ISAKMP transform 8 against priority 8 policy
ISAKMP: hash MD5
ISAKMP (0): Checking ISAKMP transform 9 against priority 8 policy
ISAKMP: hash SHA
ISAKMP: keylength of 128
crypto_isakmp_process_block:src:193.95.55.108, dest:193.95.116.9 spt:500 dpt:500
VPN Peer:ISAKMP: Peer Info for 193.95.55.108/500 not found - peers:0
ISAKMP: larval sa found
ISAKMP (0): deleting SA: src 193.95.55.108, dst 193.95.116.9
ISADB: reaper checking SA 0x14752fc, conn_id = 0 DELETE IT!
OAK_MM exchange
ISAKMP (0): processing SA payload. message ID = 0
Hi, I've same problem.
Isacco
I have enabled the 3DES-AES on the pix but the same log appear.
I opened a TAC case.
The TAC said: "You must use only CA Server Microsoft in STANDALONE MODE to work !!"
Isacco
Thanks for response.
I already configured a standalone server but ISAKMP fail.
When enrolling the certificate, log is :
"No root CA exist" use ca authenticate"
