Problem between Cisco PIX 520 6.3(3) and FreeSwan 2.0.6
rene.schmid
hi,
i have troubles with a lan2lan vpn connection between my cisco pix 520 and a linux freeswan 2.0.6 firewall. kernel version 2.6.8
phase I is ok. i get the message QM_Idle
but phase II is not finished correctly.
on both sides we have no spi connection.
we want to encrypt the traffic between 2 private networks. on the linux box i get the message
ag-weid-fw:/etc# ipsec auto --up sitexs
104 "sitexs" #1: STATE_MAIN_I1: initiate
106 "sitexs" #1: STATE_MAIN_I2: sent MI2, expecting MR2
108 "sitexs" #1: STATE_MAIN_I3: sent MI3, expecting MR3
003 "sitexs" #1: protocol/port in Phase 1 ID Payload must be 0/0 or 17/500 but are 17/0
218 "sitexs" #1: STATE_MAIN_I3: INVALID_ID_INFORMATION
003 "sitexs" #1: encrypted Informational Exchange message is invalid because it is for incomplete ISAKMP SA
010 "sitexs" #1: STATE_MAIN_I3: retransmission; will wait 20s for response
010 "sitexs" #1: STATE_MAIN_I3: retransmission; will wait 40s for response
031 "sitexs" #1: max number of retransmissions (2) reached STATE_MAIN_I3. Possible authentication failure: no acceptable response to our first encrypted message
any ideas ???
please help..
rene
Patrick Iseli
Level 7
Level 7
1.) Could be PFS:
Unselect "PFS" on the /etc/ipsec.secrets file on the Freeswan. Also disable pfs /etc/ipsec.conf
conn %default
type=tunnel
pfs=NO
If PFS os on then you have to also set DH Group 5 on the FreeSwan
2.) Verify that the access-list for the interesting traffic, encryption domains are identic !!!
on pix:
PIX(config)# access-list VPN permit ip Internalnet ISubnet Externalnet ESubnet
PIX(config)# crypto map REMOTE 10 match address VPN
check also
PIX(config)# nat (inside) 0 access-list NONAT
PIX(config)# access-list NONAT permit ip Internalnet ISubnet Externalnet Esubnet
Check the debugg output on the PIX and compare it with that document:
IP Security Troubleshooting - Understanding and Using debug Commands:
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_tech_note09186a00800949c5.shtml
sincerley
Patrick
hi patrick,
thanks for reply, the access-list's on the systems are correct. pfs is not enabled.
rene
