11-13-2015 12:21 PM - edited 02-21-2020 08:33 PM
11-13-2015 12:54 PM
It would seem that the issue with Tunnel1 might be simple to investigate - check for routes to the tunnel destination. We need more information to be able to understand the issue with Tunnel0.
Rick
11-13-2015 08:40 PM
check the route for tunnel destination and if keepalive are configured removed and check. If possible share the tunnel information and route information. To investigate further.
How do you resolve a CGR with the following info; "Tunnel0 is down (Internal-Handshake-Fail errDisable)
and Tunnel1 is down (No route to tunnel destination address)?" respectively....Thanks in anticipation
