Cisco BRAS 7206 vxr problem.
m.rabidinov
PPPoE BRAS: Cisco 7206 vxr.
VOIP gateways: Micronet SP5002
We have a periodic problems with pppoe connection from multiple Micronet voip gateways to Cisco BRAS.
The problem appears when Cisco 7206vxr is up about 20 days. But in the same time, pppoe connection passes with the same login from Windows XP.
After reboot Cisco 7206vxr, Micronet gateways connect to Cisco by pppoe.
I can't determine problem, because micronet voip gateways is in the different vlans, and they are get down synchronously.
I made wireshark dumps:
38    70.452619    Micronet_04:70:7b    Broadcast    PPPoED    Active Discovery Initiation (PADI)
39    70.471507    Cisco_64:06:1a    Micronet_04:70:7b    PPPoED    Active Discovery Offer (PADO) AC-Name='Router_PPPoE'
40    70.472433    Micronet_04:70:7b    Cisco_64:06:1a    PPPoED    Active Discovery Request (PADR) AC-Name='Router_PPPoE'
41    70.491187    Cisco_64:06:1a    Micronet_04:70:7b    PPPoED    Active Discovery Session-confirmation (PADS) AC-Name='Router_PPPoE'
42    70.501079    Micronet_04:70:7b    Cisco_64:06:1a    PPP LCP    Configuration Request
43    70.514853    Cisco_64:06:1a    Micronet_04:70:7b    PPP LCP    Configuration Request
44    70.514861    Cisco_64:06:1a    Micronet_04:70:7b    PPP LCP    Configuration Ack
45    70.516765    Micronet_04:70:7b    Cisco_64:06:1a    PPP LCP    Configuration Nak
47    72.504574    Cisco_64:06:1a    Micronet_04:70:7b    PPP LCP    Configuration Request
48    72.506177    Micronet_04:70:7b    Cisco_64:06:1a    PPP LCP    Configuration Nak
50    73.497205    Micronet_04:70:7b    Cisco_64:06:1a    PPP LCP    Configuration Request
51    73.512713    Cisco_64:06:1a    Micronet_04:70:7b    PPP LCP    Configuration Ack
52    74.520646    Cisco_64:06:1a    Micronet_04:70:7b    PPP LCP    Configuration Request
53    74.522356    Micronet_04:70:7b    Cisco_64:06:1a    PPP LCP    Configuration Nak
55    76.497523    Micronet_04:70:7b    Cisco_64:06:1a    PPP LCP    Configuration Request
56    76.512830    Cisco_64:06:1a    Micronet_04:70:7b    PPP LCP    Configuration Ack
57    76.536470    Cisco_64:06:1a    Micronet_04:70:7b    PPP LCP    Configuration Request
58    76.538138    Micronet_04:70:7b    Cisco_64:06:1a    PPP LCP    Configuration Nak
60    78.552634    Cisco_64:06:1a    Micronet_04:70:7b    PPP LCP    Configuration Request
61    78.554239    Micronet_04:70:7b    Cisco_64:06:1a    PPP LCP    Configuration Nak
63    79.497819    Micronet_04:70:7b    Cisco_64:06:1a    PPP LCP    Configuration Request
64    79.513658    Cisco_64:06:1a    Micronet_04:70:7b    PPP LCP    Configuration Ack
65    80.568411    Cisco_64:06:1a    Micronet_04:70:7b    PPP LCP    Configuration Request
66    80.570102    Micronet_04:70:7b    Cisco_64:06:1a    PPP LCP    Configuration Reject
68    82.498164    Micronet_04:70:7b    Cisco_64:06:1a    PPP LCP    Configuration Request
69    82.515001    Cisco_64:06:1a    Micronet_04:70:7b    PPP LCP    Configuration Ack
70    82.584484    Cisco_64:06:1a    Micronet_04:70:7b    PPP LCP    Configuration Request
71    82.586212    Micronet_04:70:7b    Cisco_64:06:1a    PPP LCP    Configuration Reject
72    82.602230    Cisco_64:06:1a    Micronet_04:70:7b    PPP LCP    Configuration Request
73    82.604031    Micronet_04:70:7b    Cisco_64:06:1a    PPP LCP    Configuration Reject
74    82.619716    Cisco_64:06:1a    Micronet_04:70:7b    PPP LCP    Configuration Request
88    82.755757    Cisco_64:06:1a    Micronet_04:70:7b    PPP LCP    Termination Request
89    82.756870    Micronet_04:70:7b    Cisco_64:06:1a    PPP LCP    Termination Ack
90    82.772974    Cisco_64:06:1a    Micronet_04:70:7b    PPPoED    Active Discovery Terminate (PADT)
Cisco config:
Current configuration : 12976 bytes
! Last configuration change at 16:14:26 KGST Tue May 18 2010 by tuxper
! NVRAM config last updated at 16:25:21 KGST Tue May 18 2010 by tuxper
version 12.2
service timestamps debug uptime
service timestamps log datetime msec localtime
service password-encryption
service counters max age 5
hostname Router_PPPoE
boot-start-marker
boot system disk2:c7200-advipservicesk9-mz.122-33.SRD4.bin
boot-end-marker
logging buffered 64000
no logging console
enable password 7 071D294A4D101F1F1E140C061C382D74716B
aaa new-model
aaa group server radius PPPOE-RADIUS-SERVER
server-private xxx.x.x.x auth-port 3812 acct-port 3813 key 7 yyyyyyyyy
aaa group server radius ISG-RADIUS-SERVER
server-private xx.x.x.x auth-port 4812 acct-port 4813 key 7 yyyyyyyyyy
aaa group server radius CISCO-AAA-SERVER
server-private xxx.x.x.x auth-port 2812 acct-port 2813 key 7 yyyyyyyyyyyyyy
aaa group server tacacs+ ACCT-TACACS-SERVER
server-private xx.x.x.x key 7 yyyyyyyyyyyyyyyyy
aaa authentication login default local group CISCO-AAA-SERVER
aaa authentication enable default group CISCO-AAA-SERVER enable
aaa authentication ppp PPPoE group PPPOE-RADIUS-SERVER
aaa authorization network PPPoE group PPPOE-RADIUS-SERVER
aaa authorization subscriber-service default local group ISG-RADIUS-SERVER
aaa accounting update periodic 1440
aaa accounting exec default start-stop group CISCO-AAA-SERVER
aaa accounting commands 1 default stop-only group ACCT-TACACS-SERVER
aaa accounting commands 15 default stop-only group ACCT-TACACS-SERVER
aaa accounting network PPPoE start-stop group PPPOE-RADIUS-SERVER
aaa accounting network ISG start-stop group ISG-RADIUS-SERVER
aaa server radius dynamic-author
client xxx.x.x.x server-key 7 yyyyyyyyyyyyy
auth-type all
ignore session-key
ignore server-key
aaa session-id common
clock timezone KGST 6
ip subnet-zero
ip source-route
ip cef
ip name-server xxxxxxxxx
subscriber service password 7 xxxxxxxxxxxxxxxx
redirect server-group REDIR-SERVER
server ip xxx.xxx.xxx.xxx port 9999
archive
log config
  logging enable
  notify syslog contenttype plaintext
  hidekeys
path ftp://xxxxxxxxxx@xxx.xxx.xxx.xxx.xx/bras7206-//xxxxxxxxxx@xxx.xxx.xxx.xxx.xx/bras7206-
write-memory
time-period 10080
username tuxper password 7 yyyyyyyyyyyy
username evrey password 7 yyyyyyyyyyyyy
bba-group pppoe global
virtual-template 1
sessions max limit 8000
sessions per-vlan limit 4000
interface Loopback0
ip address xx.xxx.xx.xx 255.255.255.255
interface GigabitEthernet0/1
description 7600_Uplink
ip address yy.yy.yy.yy 255.255.255.252
ip ospf network point-to-point
media-type rj45
speed 1000
duplex full
no negotiation auto
no cdp enable
interface GigabitEthernet0/2
description 7600_Uplink_pppoe_vlan
mtu 9000
no ip address
media-type rj45
speed auto
duplex auto
no negotiation auto
vlan-range dot1q 25 26
  pppoe enable group global
  exit-vlan-config
vlan-range dot1q 300 399
  exit-vlan-config
vlan-range dot1q 401 461
  exit-vlan-config
vlan-range dot1q 600 620
  exit-vlan-config
vlan-id dot1q 20
  exit-vlan-config
interface GigabitEthernet0/3
no ip address
shutdown
media-type rj45
speed auto
duplex auto
no negotiation auto
interface Virtual-Template1
description PPPoE
mtu 1492
ip unnumbered Loopback0
ppp authentication chap pap PPPoE
ppp authorization PPPoE
ppp accounting PPPoE
ppp eap refuse
ppp ms-chap refuse
ppp ms-chap-v2 refuse
ppp ipcp dns zzz.zzz.zzz.zzz zzz.zzz.zzz.zzz
router ospf 1
router-id yyy.yy.yy.yy
log-adjacency-changes
summary-address ii.iii.ii.0 255.255.254.0
summary-address ttt.ttt.ttt.0 255.255.255.0
summary-address ttt.ttt.ttt.0 255.255.254.0
redistribute connected subnets
redistribute static subnets
network uuu.uuu.uuu.uuu 0.0.0.3 area 0
default-information originate
ip classless
no ip http server
no ip http secure-server
!line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
session-timeout 30
exec-timeout 60 0
length 0
international
line vty 5 15
ntp clock-period 17179974
ntp peer vvv.vvv.vvv.vvv
ntp peer vvv.vvvv.vvv.vvv
end
This problem has appeared twice, and was resolved reboot Cisco 7206vxr BRAS.
It's not good. I need help!
P.S. I'm ready to provide any needed information.
paolo bevilacqua
It would be useful to see the contect of thse PPP LCP,
Alos, which exact IOS are you using ?
paolo bevilacqua
I can attach wireshark dump.
Is it enough?
IOS: c7200-advipservicesk9-mz.122-33.SRD4.bin
Thank you for help!
P.S. I can send a wireshark dump when pppoe is up, it was made after reboot Cisco bras 7206.
