Cisco secure client error: Authentication failed due to problem naviga
Jaguar2026
Community Member
Cisco secure client error: Authentication failed due to a problem navigating to the single sign-on URL.
Any suggestions on how to fix this error?
2 Accepted Solutions
Ben Weber
Hey @Jaguar2026
This points to an issue with the SAML/SSO redirect prior to the VPN establishing. A few things to check:
1. Is the device clock synced with an NTP server?
2. Is the default browser (embedded browser) blocked or disabled by a SIG?
3. Is there any interception of the traffic between device and SSO portal? Could it be blocked in Umbrella/Secure Access/another SIG?
4. Is the SSO portal URL correct?
5. Any chance pop-ups are blocked in the browser?
If you check all of that and it still isn't working, then we will have to go deeper into the problem.
Good luck!
- BW
Please rate posts if they have been helpful.
Jaguar2026
Community Member
It is working now, it was a problem with the browsers.
Thank you
Ben Weber
Hey @Jaguar2026
Good luck!
- BW
Jaguar2026
Community Member
Thank you
