Connecting to ASA5540 using ASDM
jayeshkamdar
I just got my ASA5540 and working on configuring it. So far I have configured the IP and able to telent to it but some reason I can use ASDM to connect to. Is there a special feature that I have to enable to connect using ASDM?
Please let me know. Thanks for your help.
m.sir
Level 7
Level 7
you need enable the HTTPS server and let a host on the inside interface access ASDM,
enter the following commands (for example let host with an address of 192.168.1.2 access to ASDM) :
ASA(config)# crypto key generate rsa modulus 1024
ASA(config)# http server enable
ASA(config)# http 192.168.1.2 255.255.255.255 inside
ASA(config)# write mem
M.
Hope that helps rate if it does
