EAZYVPN and DMVPN on the same router,same interface
Hi all,
           First of all, thanks in advance for the help. I have setup DMVPN and EAZYVPN on  one router. Tunnel interface on Spoke one and Spoke two are up/up and show crypto ISakmp sa shows both tunnels are in idle. However, tunnel to Spoke one(10.10.1.1) keep bouncing on and off(see below). Every 30 sec or so, the tunnel gone back to IKE phase while tunnel for spoke two(5.5.5.1) still leave active. THe configuration on the HUB side is the same for both spoke!! show crypto ipsec sec shows both side has the same life time(IOS default). Could that be an IOS debug on the spoke one?
Hub :
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 15.1(3)T2, RELEASE SOFTWARE (fc1)
HUB#sh crypto ipsec security-association
Security association lifetime: 4608000 kilobytes/3600 seconds
Spoke one:
Cisco IOS Software, C2600 Software (C2600-ADVSECURITYK9-M), Version 12.4(8), RELEASE SOFTWARE (fc1)
SPOKE1#sh crypto ipsec security-association
HUB#sh crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst             src             state          conn-id status
5.5.5.1         5.5.5.2         QM_IDLE           1002 ACTIVE
10.10.1.1       10.10.1.2       MM_NO_STATE       1134 ACTIVE (deleted)
10.10.1.1       1.1.1.10        QM_IDLE           1126 ACTIVE
10.10.1.1       1.1.1.10        QM_IDLE           1076 ACTIVE
HUB#sh crypto se
HUB#sh crypto session
Crypto session current status
Interface: Serial0/1/1
Username: testuser
Profile: AccountingPro
Group: Accounting
Assigned address: 20.20.20.1
Session status: UP-ACTIVE
Peer: 1.1.1.10 port 60201
  IKEv1 SA: local 10.10.1.1/500 remote 1.1.1.10/60201 Active
  IPSEC FLOW: permit ip 0.0.0.0/0.0.0.0 host 20.20.20.1
        Active SAs: 2, origin: dynamic crypto map
Username: testuser
Group: Accounting
Assigned address: 20.20.20.2
Peer: 1.1.1.10 port 49768
  IKEv1 SA: local 10.10.1.1/500 remote 1.1.1.10/49768 Active
  IPSEC FLOW: permit ip 0.0.0.0/0.0.0.0 host 20.20.20.2
Interface: FastEthernet0/1
Profile: DMVPN
Session status: UP-IDLE
Peer: 5.5.5.2 port 500
  IKEv1 SA: local 5.5.5.1/500 remote 5.5.5.2/500 Active
Profile: DMVPN
Session status: DOWN-NEGOTIATING
Peer: 10.10.1.2 port 500
  IKEv1 SA: local 10.10.1.1/500 remote 10.10.1.2/500 Inactive
HUB#
2.  My second issue is, I use the same interface(s0/1/1=10.10.1.1) for eazyvpn access. The client from eazyvpn is connected fine,but does not receive traffric back(statics window show no decrypted=0 and reeiced=0). The eazy vpn can't even ping the IP address assigned to the vpn client(20.20.20.2), and the client can only pin 10.10.1.1 address. Reverse router is able but the 20.20.20.0/24 network didn't show up in the ip table of the HUB router!!!
DMVPN AND EAZYVPN SERVER config..
crypto keyring dmvpnkey
  pre-shared-key address 0.0.0.0 0.0.0.0 key DMVPNLAB
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp policy 10
encr aes
group 2
crypto isakmp policy 20
encr aes
group 2
crypto isakmp policy 30
encr 3des
hash md5
group 2
crypto isakmp policy 40
crypto isakmp keepalive 30
crypto isakmp xauth timeout 90
crypto isakmp client configuration group Accounting
key eazypvn
dns 4.2.2.2
wins 4.2.2.2
domain bigBois.com
pool dmAccouting
crypto isakmp profile AccountingPro
   match identity group Accounting
   client authentication list access_in
   isakmp authorization list my_vpn
   client configuration address respond
crypto isakmp profile DMVPN
   keyring dmvpnkey
   match identity address 0.0.0.0
crypto ipsec transform-set DMVPN ah-sha-hmac esp-aes
mode transport
crypto ipsec transform-set EAZYVPN esp-3des esp-md5-hmac
crypto ipsec profile dmvpnlab
set transform-set DMVPN
set isakmp-profile AccountingPro
crypto dynamic-map Remote_Acc 20
set transform-set EAZYVPN
reverse-route
crypto map RemoteAcc client authentication list access_in
crypto map Remote_Acc client authentication list my_vpn
crypto map Remote_Acc 20 ipsec-isakmp dynamic Remote_Acc
interface Loopback0
ip address 192.168.200.1 255.255.255.0
interface Loopback2
ip address 172.16.10.1 255.255.255.0
interface Loopback3
ip address 172.16.15.1 255.255.255.0
interface Tunnel1
bandwidth 10000
ip address 4.4.4.1 255.255.255.0
no ip redirects
ip mtu 1400
no ip next-hop-self eigrp 10
ip nhrp authentication DMVPN
ip nhrp map multicast dynamic
ip nhrp network-id 7940
ip nhrp registration timeout 10
ip tcp adjust-mss 1360
tunnel source Serial0/1/1
tunnel mode gre multipoint
tunnel key 7940
tunnel protection ipsec profile dmvpnlab
interface FastEthernet0/0
description OUTSIDE
ip address 1.1.1.1 255.255.255.0
ip virtual-reassembly in
duplex auto
speed auto
interface FastEthernet0/1
description INSIDE
ip address 5.5.5.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Serial0/1/0
no ip address
shutdown
clock rate 2000000
interface Serial0/1/1
description to SPOKE1
ip address 10.10.1.1 255.255.255.0
interface Serial0/3/0
no ip address
shutdown
router eigrp 10
network 4.4.4.0 0.0.0.255
network 5.5.5.0 0.0.0.255
network 10.0.0.0
network 10.10.10.0 0.0.0.3
network 172.16.0.0 0.0.0.255
network 172.16.1.0 0.0.0.255
network 172.16.10.0 0.0.0.255
network 172.16.15.0 0.0.0.255
network 192.168.200.0
ip local pool dmAccouting 20.20.20.1 20.20.20.10
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
THanks  a bunch for the help,
Ernest
Any ideas why devices keep renewing phase 1?
