FDM management for anyconnect
l.buschi
Level 2
Level 2
I only need to manage remote anyconnect acces with LDAP or RADIUS authentication in a FPR HA active/standby architecture.
no NGFW needed and no other functions.
May I use FDM to manage FPR 2100 series and 3100 series?
Tks
Johnny
Fdm is not like fmc
Fdm is local mgmt i.e. you need to connect your pc directly to fw to start use fdm it not remote mgmt.
So each fw you can use fdm by directly connect your pc to fw
MHM
tiwang
Level 3
Level 3
sure you dont want to load ASA sw on them instead and run the AnyConnect under ASA and use the old ASDM to maintain them - the AnyConnect VPN Hub is really easy to maintain trough the ASDM
@l.buschi yes FDM is supported on the FPR2100 or 3100 series hardware. FDM supports LDAP/RADIUS authentication, HA and will work fine dedicated for Remote Access VPNs, although not all features are supported with FDM compared to if managed by an FMC. Running ASA software on the FPR2100/3100 hardware is support and would also meet your requirements, ASA software is not being depreciated any time soon and is still being developed.
