FTD AnyConnect with Duo authentication and machine certificate authentication. Is it possible? How do you configure?
Hello all,
Currently I have AnyConnect (4.8.03036) VPN access through a FTD 2120 (6.3.0.3 Build 77) manged by FMC and  authenticating via Duo Authentication proxy service on a MS domain controller.
Is it possible to also use a machine certificate in addition to AD/Duo and only allow company assets with a machine cert to connect?  We have machine certs on the devices that are company owned that were generated by our Domain CA and pushed out via GPO.
Thank you!
Cristian Matei
   Never tried it with DUO, but i don't see why it wouldn't work. You would specify DUO as your authorization server in the connection profile configuration.
Cristian Matei.
We added double authentication support until 6.4
https://www.cisco.com/c/en/us/td/docs/security/firepower/640/configuration/guide/fpmc-config-guide-v64/firepower_threat_defense_remote_access_vpns.html#task_ilm_hty_bhb
If you upgrade to 6.4 or later you will be able to accomplish cert auth + duo.
-Gustavo
