help with setting up basic IKEv2 site to site vpn
baselzind
Level 6
Level 6
i have FMC and ftd .I  had some experience with setting up ikev1 site to site vpn as i provide the other side with these phase1 and phase 2 info as following:
phase1:
encryption, hash , DH group , lifetime , authen method
phase 2
esp encryption , esp hash
but for IKEv2 site to site vpn is it the same steps? because I found the phase 1 for ikev2 having different parameters like
integrity algorithm , encryption algorithm , PRF algorithm , DH group  but the same for ikev2 phase 2 "esp encryption , esp hash"  . So do i ask the other side for those fields and match it so the site to site vpn would come up?
6 Replies 6
Hi @baselzind
You still need the peer (the other side) VPN to match the same algorithms you have used for encryption, integrity, PRF, DH etc. Some of the terminlogy has changed, in IKEv1 it was "hashing", in IKEv2 it's "integrity".
If you are using AES-GCM then you'd don't need to specify the integrity algorithm, as integrity is builtin with GCM.
is AES-GCM an encryption method in ikev2 exclusively?
Correct AES-GCM is used only in IKEv2. Refer to cisco guide below when selecting your IKEv2 algorithms, select NGE or Acceptable and do not select Legacy or Avoid algorthims.
https://tools.cisco.com/security/center/resources/next_generation_cryptography
Refer to this post for an example IKEv2 VPN on FMC, using AES-GCM.
balaji.bandi
You need to make a Template to match both the sides : example :
I do below for each VPN i do with Clients :
Encryption:
Encryption Method:
Prefer IKEv2, support IKEv1
Encryption Suite:
Custom: Advanced:
IKE Phase 1: AES-256, SHA1
IKE Phase 2: AES-256, SHA1
Tunnel Management:
Uncheck "Set Permananet Tunnels"
VPN Tunnel Sharing:
One VPN tunnel per each pair of hosts
Advanced Settings:
Shared Secret: XXXXXXXXXXXXXXXXXX
Advanced VPN Properties:
IKE (Phase1): DFH -> Group 2(1024 bit)
Renegotiate IKE: 1440 minutes
Uncheck "Use aggressive mode"
IPsec (Phase 2)
Check "Use Perfect Forward Secrecy"
DFH -> Group 2 (1024 bit)
Renegotiate IPsec: 3600 seconds
hope this helps you.
BB
is this template for ikev1 or ikev2?
balaji.bandi
Its universal template to collect information.
BB
