Help with split tunneling w/ Cisco EZVPN Network Extension Mode
So, I have a Cisco SR520W  (Will be replaced by an ASA eventually) acting as a EZVPN Server, and a  Cisco 861 acting as an EZVPN client.  Also, I have a Cisco 2621  simulating the "Internet", with a virtual interfaces setup to simulate  internet sites.  The VPN tunnel works, and I can successfully route  traffic all over my network.  However, no matter what I do I cannot get  it to access the "Internet" correctly.  I can see that if I do route  packets to the "Internet", they are replied to with a non natted  destination IP (192.168.26.2, IP of my test computer).
The SR520W LAN interface is connected to my production network, and  routing all over it works correctly.  The WAN interfaces (fa4) of the  861 and SR520W are both connected to the Cisco 2621.  The configs of my  SR520W and 861 are as follows below.
Client:  http://pastebin.com/BUjMaWDL Server:  http://pastebin.com/4LB0bg1a "Internet 2621", in case it's relevant:  http://pastebin.com/LUCmqRCj
I have solved this, I have posted the relevent configs.  I'm aware that the WAN ip address isn't valid, but I scrambled it to protect my identity
http://pastebin.com/2LXuPr2c
http://pastebin.com/pRPujJbj
