How to figure out what my company is using for VPN?
Hello -
I am trying to get set up on my company's VPN, but no one here has experience setting it up on a mac. I tried using the information I was given in the native Mac VPN, but I was told there is no shared secret, or certificate.
I have the client files that everyone used to set their PCs up, and connection information (minus a shared secret). No one seems to know what kind of VPN it is. Is there a way to figure that out from what I have?
Thank you!
JP Miranda Z
Hi regina_chiumina,
You can try running the following commands on the ASA:
sh vpn-sessiondb (anyconnect or svc)
sh vpn-sessiondb ra-ikev1
sh vpn-sessiondb summary
Make sure you have at least one client connected when running those commands.
Hope this info helps!!
Rate if helps you!!
-JP-
JP Miranda Z
Hi regina_chiumina,
Rate if helps you!!
-JP-
Marvin Rhoads
If the client file is pcf file type, the VPN is the old style IPsec VPN.
If it's an xml profile, the VPN is an SSL VPN (AnyConnect).
