How to fix case sensitive for tunnel-group name
jewfcb001
Level 4
Level 4
Hi All ,
I try to configure for group-url https://x.x.x.x/test  and client try to connect anyconnect vpn but  while client key
https://x.x.x.x/Test  client cannot connect because case sensitive for tunnel-group name . I'm not sure cisco has the solution for solve this situation.
Thank you.
I check cisco doc and guide there is no mention or restrictions of case you use for tunnel url.
MHM
@MHM Cisco World
Thank you for response .
I mean
Example
tunnel-group test webvpn-attributes
group-alias test enable
group-url https://x.x.x.x/test enable
In anyconnect programe If need to connect this tunnel-group  , client need connect to https://x.x.x.x/test  cannot use Test or TEST
I'm not sure, do you clear my point ?
