HUB & SPOKE environment with ASA5512 as the HUB and ASA5505 as spoke.
Ken Mackay
I can't seem to get by the error's. Phase 1 completes, then the errors start, 7.0.0.2 recieved non-routine notify message no proposal choosen, connection terminated for peer 7.0.0.2 reason peer terminate remote proxy N/A local Proxy N/A, 7.0.0.2 removing peer from correlator table failed, no match, seesion being torn down reason user requested, group 7.0.0.2 automatic NAT detection status remote end is not behind NAT device, this end is not behind NAT device. The other end the ASA5512 I get IP 7.1.0.2 no valid authentication type found for the tunnel group, Remote end is not behind NAT device, the DAP records were selected for connection DfltAccessPolicy, Phase 1 completed, All IPSEC SA proposals found unacceptable, IP 7.1.0.2 QM FSM error, removing peer from correlator table failed no match, 7.1.0.2 session being torn down reason Phase 2 Mismatch, 7.1.0.2 session disconnected type IKEV1, recevied encrypted packet with no matchin SA dropping.
I have searched internet and found many results however as changes implemented I always end back at this point. Any HELP would be greatly appreciated. Lost two days in the LAB. I will post configs. This a test soon to go into production. Thanks
Ken
ASA1# sho run
: Saved
ASA Version 9.1(2)
hostname ASA1
domain-name TEST1.CA
enable password 8Ry2YjIyt7RRXU24 encrypted
names
interface GigabitEthernet0/0
 nameif Outside
 security-level 100
 ip address 7.0.0.2 255.255.255.0
interface GigabitEthernet0/1
 nameif AS1toR1
 security-level 50
 ip address 1.0.0.2 255.255.255.0
interface GigabitEthernet0/2
 nameif AS1toR2
 security-level 50
 ip address 3.0.0.2 255.255.255.0
interface GigabitEthernet0/3
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/4
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/5
 shutdown
 no nameif
 no security-level
 no ip address
interface Management0/0
 management-only
 nameif management
 security-level 0
ftp mode passive
dns domain-lookup Outside
dns domain-lookup AS1toR1
dns domain-lookup AS1toR2
dns domain-lookup management
dns server-group DefaultDNS
 name-server 201.201.201.201
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network obj-1.0.0.0
object network 2.0.0.0
 subnet 2.0.0.0 255.255.255.0
object network 6.0.0.0
 subnet 6.0.0.0 255.255.255.0
object network 7.1.0.0
 subnet 7.1.0.0 255.255.255.0
object network 8.0.0.0
 subnet 8.0.0.0 255.255.255.0
object network 9.0.0.0
 subnet 9.0.0.0 255.255.255.0
object-group network DM_INLINE_NETWORK_3
 network-object 1.0.0.0 255.255.255.0
 network-object 3.0.0.0 255.255.255.0
 network-object object 2.0.0.0
 network-object object 8.0.0.0
object-group network DM_INLINE_NETWORK_4
 network-object object 6.0.0.0
 network-object object 9.0.0.0
object-group network DM_INLINE_NETWORK_1
object-group network DM_INLINE_NETWORK_2
object-group network DM_INLINE_NETWORK_5
object-group network DM_INLINE_NETWORK_6
access-list HEADEND extended permit ip any any
access-list hq-to-vpnend extended permit ip object-group DM_INLINE_NETWORK_3 object-group DM_INLINE_NETWORK_4
access-list vpnend-to-hq extended permit ip object-group DM_INLINE_NETWORK_1 object-group DM_INLINE_NETWORK_2
access-list Outside_cryptomap_15 extended permit ip object-group DM_INLINE_NETWORK_5 object-group DM_INLINE_NETWORK_6
access-list Outside_access_in extended permit ip any any
access-list Outside_access_in extended permit icmp any4 any4
access-list AS1toR2_access_in extended permit icmp any4 any4
access-list AS1toR2_access_in extended permit ip any any
access-list AS1toR1_access_in extended permit ip any any
access-list AS1toR1_access_in extended permit icmp any4 any4
pager lines 24
logging enable
logging asdm informational
mtu Outside 1500
mtu AS1toR1 1500
mtu AS1toR2 1500
mtu management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
access-group Outside_access_in in interface Outside
access-group AS1toR1_access_in in interface AS1toR1
access-group AS1toR2_access_in in interface AS1toR2
router ospf 1
 network 1.0.0.0 255.255.255.0 area 0
 network 3.0.0.0 255.255.255.0 area 0
 network 7.0.0.0 255.255.255.0 area 0
 log-adj-changes
route Outside 0.0.0.0 0.0.0.0 7.0.0.1 125
route Outside 6.0.0.0 255.255.255.0 7.0.0.1 125
route Outside 9.0.0.0 255.255.255.0 7.0.0.1 125
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
eou allow none
http server enable
http 192.168.1.2 255.255.255.255 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
sysopt connection preserve-vpn-flows
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA-TRANS esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-128-MD5-TRANS esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-192-SHA-TRANS esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-192-MD5-TRANS esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-256-SHA-TRANS esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-256-MD5-TRANS esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-3DES-SHA-TRANS esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-3DES-MD5-TRANS esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-DES-SHA-TRANS esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-DES-MD5-TRANS esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set MAP-VPN1 esp-3des esp-md5-hmac
crypto ipsec ikev2 ipsec-proposal AES256
 protocol esp encryption aes-256
 protocol esp integrity sha-1 md5
crypto ipsec ikev2 ipsec-proposal AES192
 protocol esp encryption aes-192
crypto ipsec ikev2 ipsec-proposal 3DES
 protocol esp encryption 3des
crypto ipsec ikev2 ipsec-proposal DES
 protocol esp encryption des
crypto ipsec security-association pmtu-aging infinite
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 5 match address Outside_cryptomap_15
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 5 set pfs
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 5 set ikev1 transform-set MAP-VPN1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 5 set reverse-route
crypto dynamic-map DYNMAP 10 set pfs
crypto dynamic-map DYNMAP 10 set ikev1 transform-set MAP-VPN1
crypto dynamic-map DYNMAP 10 set reverse-route
crypto map Outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map HQ2REMOTE 10 ipsec-isakmp dynamic DYNMAP
crypto map HQ2REMOTE interface Outside
crypto ca trustpool policy
crypto ikev1 enable Outside
crypto ikev1 policy 1
 authentication pre-share
 encryption 3des
 hash md5
 group 2
 lifetime 28800
telnet timeout 5
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
vpn-addr-assign local reuse-delay 30
vpn load-balancing
 interface lbpublic Outside
 interface lbprivate AS1toR1
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
 enable Outside
 no anyconnect-essentials
group-policy DfltGrpPolicy attributes
 wins-server value 10.10.10.10
 dns-server value 201.201.201.201
 vpn-idle-timeout none
 vpn-tunnel-protocol ikev1 l2tp-ipsec ssl-clientless
 split-tunnel-network-list value HEADEND
 default-domain value TEST1.CA
 webvpn
  activex-relay disable
tunnel-group DefaultL2LGroup ipsec-attributes
 ikev1 pre-shared-key *****
tunnel-group DefaultRAGroup general-attributes
 secondary-authentication-server-group LOCAL
 authorization-server-group LOCAL
 nat-assigned-to-public-ip Outside
tunnel-group DefaultRAGroup ipsec-attributes
 peer-id-validate nocheck
 ikev1 user-authentication none
tunnel-group DefaultWEBVPNGroup general-attributes
tunnel-group DefaultWEBVPNGroup ipsec-attributes
tunnel-group-map default-group DefaultL2LGroup
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
 profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly 24
  subscribe-to-alert-group configuration periodic monthly 24
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:022709234965ad8943628e790ed5ed1f
: end
ASA1#
ASA2# sho run
: Saved
ASA Version 8.2(5)
hostname ASA2
domain-name TEST2.CA
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
 switchport access vlan 14
interface Ethernet0/1
 switchport access vlan 24
interface Ethernet0/2
 shutdown
interface Ethernet0/3
 shutdown
interface Ethernet0/4
 shutdown
interface Ethernet0/5
 shutdown
interface Ethernet0/6
 shutdown
interface Ethernet0/7
 switchport access vlan 4
interface Vlan1
 no nameif
 no security-level
 no ip address
interface Vlan4
 nameif management.
 security-level 0
 ip address 192.168.1.101 255.255.255.0
 management-only
interface Vlan14
 nameif Outside
 security-level 100
 ip address dhcp setroute
interface Vlan24
 nameif Inside
 security-level 50
 ip address 6.0.0.2 255.255.255.0
ftp mode passive
dns domain-lookup management.
dns domain-lookup Inside
 network-object 2.0.0.0 255.255.255.0
 network-object 8.0.0.0 255.255.255.0
 network-object 6.0.0.0 255.255.255.0
 network-object 9.0.0.0 255.255.255.0
access-list REMOTEEND extended permit ip any any
access-list hq-to-vpnend extended permit ip object-group DM_INLINE_NETWORK_5 object-group DM_INLINE_NETWORK_6
access-list Outside_access_in extended permit icmp any any
access-list Inside_access_in extended permit ip any any
access-list Inside_access_in extended permit icmp any any
pager lines 24
logging enable
mtu management. 1500
mtu Outside 1500
mtu Inside 1500
no failover
arp timeout 14400
access-group Inside_access_in in interface Inside
router ospf 1
 network 6.0.0.0 255.255.255.0 area 0
 network 7.1.0.0 255.255.255.0 area 0
 log-adj-changes
route Outside 1.0.0.0 255.255.255.0 7.0.0.2 125
route Outside 2.0.0.0 255.255.255.0 7.0.0.2 125
route Outside 3.0.0.0 255.255.255.0 7.0.0.2 125
route Outside 8.0.0.0 255.255.255.0 7.0.0.2 125
 network-acl REMOTEEND
eou allow none
http server enable
http 0.0.0.0 0.0.0.0 management.
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set MAP-VPN1 esp-3des esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set MAP-VPN1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set reverse-route
crypto map HQ2REMOTE 15 match address vpnend-to-hq
crypto map HQ2REMOTE 15 set pfs
crypto map HQ2REMOTE 15 set connection-type originate-only
crypto map HQ2REMOTE 15 set peer 7.0.0.2
crypto map HQ2REMOTE 15 set transform-set MAP-VPN1
crypto map HQ2REMOTE 15 set security-association lifetime seconds 28800
crypto map HQ2REMOTE 15 set security-association lifetime kilobytes 4608000
crypto map HQ2REMOTE 15 set reverse-route
crypto map HQ2REMOTE 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto isakmp enable Outside
crypto isakmp policy 15
 encryption 3des
 hash md5
 group 2
 lifetime 28800
crypto isakmp ipsec-over-tcp port 10000
vpn-addr-assign local reuse-delay 5
telnet timeout 5
ssh timeout 5
console timeout 0
dhcp-client client-id interface Outside
ssl encryption 3des-sha1
webvpn
 enable Outside
 vpn-tunnel-protocol IPSec l2tp-ipsec svc webvpn
 split-tunnel-network-list value REMOTEEND
 default-domain value TEST2.CA
 smartcard-removal-disconnect disable
tunnel-group 7.0.0.2 type ipsec-l2l
tunnel-group 7.0.0.2 ipsec-attributes
tunnel-group-map default-group 7.0.0.2
 parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
call-home
 profile CiscoTAC-1
  no active
Cryptochecksum:0d04273f55e788e2a4ad4d025084d33d
: end
ASA2#
75 Replies 75
Ken
If that has made no difference can you also try adding this to your DefaultL2LGroup on the ASA 9.1 -
"peer-id-validate nocheck"
Jon
