I need help with pap authentication
I'am trying to connect 2 Routers back to back via the AUX Port and a nullmodem cable. I get a connection without ppp-authentication. But when I enable pap or chap it seems that the password and usernames are not send. I verified this with debug ppp authentication and ppp negotiation.
Here is my config:
hostname router-2501
aaa new-model
aaa authentication login default local-case
aaa authentication ppp default local
aaa authorization exec default local
enable secret 5 <removed>
username admin privilege 14 password 7 <removed>
username guest nopassword
username router-2503 password 7 <removed>
username home password 7 <removed>
interface Async1
bandwidth 38
ip address 172.16.1.2 255.255.255.0
encapsulation ppp
async mode dedicated
ppp authentication pap
line aux 0
modem InOut
transport input all
stopbits 1
speed 38400
flowcontrol hardware
hostname router-2503
aaa new-model
username router-2501 password 7 <removed>
interface Async1
bandwidth 38
ip address 172.16.1.1 255.255.255.0
encapsulation ppp
line aux 0
modem InOut
transport input all
stopbits 1
speed 38400
Here is the debug from pap:
00:11:18: %LINK-3-UPDOWN: Interface Async1, changed state to up
00:11:18: As1 PPP: Using modem call direction
00:11:18: As1 PPP: Treating connection as a callin
00:11:18: As1 PPP: Phase is ESTABLISHING, Passive Open [0 sess, 0 load]
00:11:18: As1 LCP: State is Listen
router-2501#
00:11:20: As1 LCP: TIMEout: State Listen
00:11:20: As1 LCP: O CONFREQ [Listen] id 12 len 24
00:11:20: As1 LCP: ACCM 0x000A0000 (0x0206000A0000)
00:11:20: As1 LCP: AuthProto PAP (0x0304C023)
00:11:20: As1 LCP: MagicNumber 0x00169FE3 (0x050600169FE3)
00:11:20: As1 LCP: PFC (0x0702)
00:11:20: As1 LCP: ACFC (0x0802)
00:11:20: As1 LCP: I CONFREQ [REQsent] id 19 len 24
00:11:20: As1 LCP: MagicNumber 0x00175D48 (0x050600175D48)
00:11:20: As1 LCP: O CONFACK [REQsent] id 19 len 24
00:11:20: As1 LCP: I CONFACK [ACKsent] id 12 len 24
00:11:20: As1 LCP: State is Open
00:11:20: As1 PPP: Phase is AUTHENTICATING, by both [0 sess, 0 load]
router-2501#
I remains in this for a few minutes and then it tries to reconnect again. Can anyone help?
Best Regards
Marcos
there is a hidden command that you could use:
ppp direction callout (on the local router)
ppp direction callin (on the remote router)
Aparently, in a back-to-back scenario like yours, the routers do not know exactly who called who...
HTH,
GP
6 Replies 6
spremkumar
Level 9
Level 9
The config which you have posted makes both the routers to recieve the calls and recieve the authentication credintials using PAP.
i would suggest to key in ppp authentication pap callin and ppp pap sent-username router-2501 password xxxxx on the 2501 router.
if u need more info do go thru this lik ..
http://www.cisco.com/en/US/tech/tk713/tk507/technologies_tech_note09186a0080093c6f.shtml
regds
Hello Marcos,
try the following:
On your router-2501:
interface Async1
bandwidth 38
encapsulation ppp
-->ppp pap sent-username router-2501 password XXXX
And on your router-2503:
interface Async1
bandwidth 38
encapsulation ppp
--> ppp pap sent-username router-2503 password XXXX
HTH,
GP
I tried the ppp pap sent-username router... and got the same result.
I also tried to use chap and got the following result:
00:14:49: %LINK-3-UPDOWN: Interface Async1, changed state to up
router-2503#
00:14:49: As1 PPP: Using modem call direction
00:14:49: As1 PPP: Treating connection as a callin
00:14:49: As1 PPP: Phase is ESTABLISHING, Passive Open [0 sess, 0 load]
00:14:49: As1 LCP: State is Listen
router-2503#
00:14:51: As1 LCP: I CONFREQ [Listen] id 10 len 25
00:14:51: As1 LCP: ACCM 0x000A0000 (0x0206000A0000)
00:14:51: As1 LCP: AuthProto CHAP (0x0305C22305)
00:14:51: As1 LCP: MagicNumber 0x00194ED5 (0x050600194ED5)
00:14:51: As1 LCP: PFC (0x0702)
00:14:51: As1 LCP: ACFC (0x0802)
00:14:51: As1 LCP: O CONFREQ [Listen] id 23 len 25
00:14:51: As1 LCP: MagicNumber 0x001A2BCB (0x0506001A2BCB)
00:14:51: As1 LCP: O CONFACK [Listen] id 10 len 25
00:14:51: As1 LCP: I CONFACK [ACKsent] id 23 len 25
00:14:51: As1 LCP: State is Open
00:14:51: As1 PPP: Phase is AUTHENTICATING, by both [0 sess, 0 load]
router-2503#
00:14:51: As1 CHAP: O CHALLENGE id 1 len 32 from "router-2503"
00:14:51: As1 CHAP: I CHALLENGE id 1 len 32 from "router-2501"
00:14:51: As1 CHAP: Waiting for peer to authenticate first
router-2503#
00:15:01: As1 CHAP: O CHALLENGE id 2 len 32 from "router-2503"
00:15:01: As1 CHAP: I CHALLENGE id 2 len 32 from "router-2501"
00:15:01: As1 CHAP: Waiting for peer to authenticate first
router-2503#no debug all
00:15:11: As1 CHAP: O CHALLENGE id 3 len 32 from "router-2503"
00:15:11: As1 CHAP: I CHALLENGE id 3 len 32 from "router-2501"
00:15:11: As1 CHAP: Waiting for peer to authenticate first
All possible debugging has been turned off
router-2503#
I can see the "As1 CHAP: Waiting for peer to authenticate first" message on both routers...
It seems that both sides treat the back-to-back connection as call in and waiting for the other side to authenticate. It is shown in the debug output:
I can see this debug messages on both routers, there looking identical. So my question is, can I force one router to handle the connection as dial out ?
HTH,
GP
Hi GP,
thank you, now it works ;-)
I can use chap as authentication and pap. But when I want to use pap, I must use the ppp pap sent-username ... command. Do you have any idea why pap dosent works with the local account database?
When I use chap, it works.
Marcos
Hello Marcos,
there is a slight difference in the way CHAP and PAP operate: unlike CHAP, PAP does not automatically send the router´s hostname for authentication. The username and password value must be manually configured with the ´ppp pap sent-username´ command under the interface.
HTH,
GP
