IKEV2 Problem
UniWAQ
Hallo All ,
I am trying to configure IKEV2 with SVTI but I am facing following error, could you guide me about that.
R4#show crypto ikev2 sa
 IPv4 Crypto IKEv2  SA
Tunnel-id Local                 Remote                fvrf/ivrf            Status
1         192.168.2.4/500       192.168.12.1/500      none/none            IN-NEG
      Encr: Unknown - 0, Hash: None, DH Grp:0, Auth sign: Unknown - 0, Auth verify: Unknown - 0
      Life/Active Time: 86400/0 sec
 IPv6 Crypto IKEv2  SA
R1#show crypto ikev2 sa
1         192.168.12.1/500      192.168.2.1/500       none/none            IN-NEG
R1#show running-config | sec crypto
crypto ikev2 proposal IKEv2_PROPOSAL
 encryption aes-cbc-256 aes-cbc-192 3des
 integrity sha512 sha256 md5
 group 14 5 2
crypto ikev2 policy IKEv2_POLICY
 match fvrf any
crypto ikev2 keyring IKEv2_KEYRING
 peer R4
  address 192.168.2.1
  pre-shared-key local cisco
  pre-shared-key remote cisco
crypto ikev2 profile IKEv2_PROFILE
 match identity remote address 192.168.2.1 255.255.255.255
 identity local address 192.168.12.1
 authentication remote pre-share
 authentication local pre-share
 keyring local IKEv2_KEYRING
crypto ikev2 fragmentation mtu 100
crypto ipsec transform-set IPSEC_TRANSFORM1 esp-aes 256 esp-sha512-hmac
 mode tunnel
crypto ipsec profile IPSEC_PROFILE
 set transform-set IPSEC_TRANSFORM1
 set ikev2-profile IKEv2_PROFILE
R4#show running-config | sec crypto
 group 14 5 2
 match fvrf any
 peer R1
 match identity remote address 192.168.12.1 255.255.255.255
 identity local address 192.168.2.1
 mode tunnel
 With Regards.
Waheed
Deepak Kumar
Configuration is looking same. Can you verify your IOS version on your device because we noticed the bug also for the same.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCua90097/?referring_site=bugquickviewredir
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
amekhanoshin
Sorry, wrong branch. Please delete/ignore this.
