IPSec LAN-LAN Tunnel b/w 3005 and CheckPoint
mnlatif
Level 3
Level 3
We have IPSec LAN-LAN tunnel configured between a Cisco VPN3005 and Nokia CheckPoint. However ocassionally the below message is showing up in the logs
(x.x.x.x = IP Address of Nokia CheckPoint)
17161 01/05/2004 08:46:12.440 SEV=3 AUTH/5 RPT=16 x.x.x.x
Authentication rejected: Reason = Simultaneous logins exceeded for user
handle = 730, server = (none), user = x.x.x.x, domain = <not specified>
Why would this message come up for a LAN-LAN Tunnel ? There is No Login from this peer, it is Not a Remote Access Connection.
We started seeing this message, since we upgraded the Concentrator from 4.0.1.A to 4.0.4.A.
Is it possible that Upgrade corrputed some of the database ?
Should i re-configure the Tunnel again ?
\\ Naman
mikegallagher
On the 3005, go into:
Configuration>User Management>Groups
and find the L2L tunnel you are having the issue with and click "Modify Group". Click the "General" tab and make sure "Simulanteous Logins" is >0.
HTH,
Mike
