IPsec Over DMVPN Underly Problems
mohammedsalih
hi every on
i have an issue with DMVPN Tunnel with IPsec.
i will explain the design of the network as much i can.
i have an ASR-1000 router (HUB), and i have more than 9 tunnel work on it
every tunnel has it's own underly network (Different Service Provider)
like example:
tunnel 1 (Satellite connection VSAT)
tunnel 2 (Optical Fiber connection)
and etc ...
i have two tunnels with the same source interface tunnel 1 and tunnel 9 t hat work Over Satellite connection (Underly Network)
the overly i enabled eigrp over dmvpn
all tunnels work perfectly expect tunnel 1 and 9 that have the same underly network.
the latency of satellite is so high
when i ping to spoke the time is 500 ms.
tunnel 1 has more than 100 peer
tunnel 9 has 15 peer
the issue is with tunnel 1 and 9 with Satellite Connection (VSAT Connection)
everything  ok for a while, suddenly some of Spoke routers lost connection with ASR
and when i check, i have seen these problem:
1-on some spoke routers
soke1-RT#sh crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst src state conn-id status
X.X.X.X Y.Y.Y.Y QM_IDLE 9115 ACTIVE
spoke1-RT#sh dmvpn
Legend: Attrb --> S - Static, D - Dynamic, I - Incomplete
N - NATed, L - Local, X - No Socket
T1 - Route Installed, T2 - Nexthop-override
C - CTS Capable
# Ent --> Number of NHRP entries with same NBMA peer
NHS Status: E --> Expecting Replies, R --> Responding, W --> Waiting
UpDn Time --> Up or Down Time for a Tunnel
Interface: Tunnel10101, IPv4 NHRP Details
Type:Spoke, NHRP Peers:1,
# Ent Peer NBMA Addr Peer Tunnel Add State UpDn Tm Attrb
1 X.X.X.X Y.Y.Y.Y NHRP 3w5d S
the tunnel state is (NHRP) and eigrp goes down
especially when i write the SHARED command on the Hub tunnel 1 interface (tunnel protection)
2-other spoke routers
GFC-RT#sh crypto isakmp sa
IPv6 Crypto ISAKMP SA
in this case Spoke routers delete the IPsec connection and the dmvpn goes down,
it will never come up untill i forced to shutdown and no shutdown the tunnel to make it come up again.
when these problems happens i checked the underly connection there is no problem and everything work fine.
all remaining tunnels from 2 to 8 work perfectly with out any issue.
i will put the configuration of HUB and Spoke router.
I see in Hub you use same interface for both tunnel BUT you use different IPsec prefile?
that wrong
you need to use same IPsec profile and use keyword shared in both tunnel
and also I dont know why you dont like add "ip nhrp map multicast dynamic" in Hub ? I remember in your previous post I recommend to use it
thanks
MHM
