IPSEC Problem
arshad.usmani
We Have an end to End IPSEC Tunnel between Point A and Point B.
Both the End IPSEC is UP and status are as follows :-
------------Point A-------------------------
Router A#sh crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst src state conn-id slot status
57.72.23.101 116.228.146.118 QM_IDLE 2013 0 ACTIVE
IPv6 Crypto ISAKMP SA
Router A#sh crypto ipsec sa
interface: FastEthernet4
Crypto map tag: From_FastEthernet4, local addr 116.228.146.118
protected vrf: (none)
local ident (addr/mask/prot/port): (192.168.0.1/255.255.255.255/0/0)
remote ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
current_peer 57.72.23.101 port 500
PERMIT, flags={origin_is_acl,}
#pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
#pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0
#pkts not decompressed: 0, #pkts decompress failed: 0
#send errors 0, #recv errors 0
local crypto endpt.: 116.228.146.118, remote crypto endpt.: 57.72.23.101
path mtu 1500, ip mtu 1500
current outbound spi: 0x0(0)
inbound esp sas:
inbound ah sas:
inbound pcp sas:
outbound esp sas:
outbound ah sas:
outbound pcp sas:
---------Point B------------------------
Router B#sh crypto isakmp sa vrf pointB | inc 116.228.146.118
57.72.23.101 116.228.146.118 QM_IDLE 157 0
Router B#sh crypto ipsec sa vrf PointB | b 116.228.146.118
current_peer: 116.228.146.118:500
PERMIT, flags={}
#pkts encaps: 24, #pkts encrypt: 24, #pkts digest: 24
local crypto endpt.: 57.72.23.101, remote crypto endpt.: 116.228.146.118
path mtu 1500, media mtu 1500
current outbound spi: BE014FB9
inbound esp sas:
spi: 0xA690AE43(2794499651)
transform: esp-3des esp-sha-hmac ,
in use settings ={Tunnel, }
slot/subslot: 8/0, conn id: 11017, flow_id: 103, crypto map: ups_brown_net_dslbackup_map
crypto engine type: Hardware, engine_id: 2
sa timing: remaining key lifetime (k/sec): (4565127/550)
ike_cookies: 29E6AAFE 0C8FB7E9 28E0C772 EBF5FCA7
IV size: 8 bytes
replay detection support: Y
inbound ah sas:
inbound pcp sas:
As shown in Log that packet (pkts Decaps)is not De-encapsulated on Router B and is getting DrOpped.
Any Suggestion in Problem above.
arshad.usmani
I can see the packets flow from the Router A:
psha1381#sh crypto ipsec sa
local ident (addr/mask/prot/port): (57.215.221.18/255.255.255.255/0/0)
#pkts encaps: 47, #pkts encrypt: 47, #pkts digest: 47
#pkts decaps: 23, #pkts decrypt: 23, #pkts verify: 23
B) Also when, I run a icmp debug, I see the below message
Mar 13 01:59:08.233: ICMP: echo reply sent, src 57.215.221.18, dst 57.7.21.185
*Mar 13 01:59:08.237: ICMP: dst (116.228.146.118) administratively prohibited unreachable rcv from 218.1.20.50
*Mar 13 01:59:09.225: ICMP: echo reply sent, src 57.215.221.18, dst 57.7.21.185
*Mar 13 01:59:09.229: ICMP: dst (116.228.146.118) administratively prohibited unreachable rcv from 218.1.20.50
*Mar 13 01:59:10.225: ICMP: echo reply sent, src 57.215.221.18, dst 57.7.21.185
*Mar 13 01:59:10.229: ICMP: dst (116.228.146.118) administratively prohibited unreachable rcv from 218.1.20.50
