IPSEC Tunnel having Spoke Side Ipv4 and Hub side IPv6
TaimurKhan
Hi all,
I wants to try to make IPSec Tunnel with one end (spoke)  having IPv4 as tunnel source and Hub end is having IPv6 address.
Is that possible? as I have tested GRE by having both ends have IPV6 and it is working.
Sorry it not possible
Both end must have same IP verion
But you can use ipv4 ovrr ipv6 or ipv6 over ipv4
MHM
MHM
@MHM Cisco World
Thanks for the reply. Kindly can u share some cisco documentation or some source as i have to present it to my management.
   Well, there's no document out there (specially from vendors), making this statement as it's just obvious. Without being impolite here, tell your management that you can't leave your house by car (IPv4 tunnel source) and reach your destination by bicycle (IPv6 tunnel destination) without shifting between the two at some point; so you start and end by car (IPv4 tunnel source and destination) and along the road you change to bicycle (IPv6 tunnel source and destination).
Best,
Cristian.
