Bookmark
Subscribe
1269
IPsec VPN between ASA 5505 and Cisco 1941 router problem
Vey Vryy
Hi fellow Cisco learners and experts
I'm currently studying CCNA Security at the moment.
I have a problem with IPsec in ASA 5505. Both Inside LAN (PCA/PCB) and Site (PCC) can ping each other and it means "interesting" traffic is permitted and IPsec tunnel should be active.
when i check the isakmp sa and ipsec sa in ASA 5505.
It does not show anything.
For R3, isakmp sa doesn't show anything. BUT, the ipsec sa, it has something in it.
this is the topology that i have:
And this is the .pkt file : https://drive.google.com/open?id=0B41dYfwXEKDzczdrYzdDUmV1aFE
If anyone could help, would be really appreciated.
Thank you in advance.
The access-list SITE which is the crypto ACL is incorrect.
It should be
access-list SITE extended permit icmp 30.30.30.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list SITE extended permit tcp 30.30.30.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list SITE extended permit ip 30.30.30.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list SITE extended permit icmp 192.168.1.0 255.255.255.0 30.30.30.0 255.255.255.0
access-list SITE extended permit tcp 192.168.1.0 255.255.255.0 30.30.30.0 255.255.255.0
access-list SITE extended permit ip 192.168.1.0 255.255.255.0 30.30.30.0 255.255.255.0
Or you can even just put :
as it includes TCP/IP/ICMP all.
You do not need this :
access-group SITE in interface outside
Please do a :
no access-group SITE in interface outside
Also apply access-list on inside interface to allow traffic :
access-list inside_access_in permit ip any any
access-group inside_access_in in interface inside
This completes ASA configuration. After this you should definitely see the tunnel trying to come up.
Now on Router 3 :
The ISAKMP policy needs to change, we need to have group 2 just like on ASA.
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
The access-list 122 will be like :
access-list 122 permit icmp 30.30.30.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 122 permit ip 30.30.30.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 122 permit tcp 30.30.30.0 0.0.0.255 192.168.1.0 0.0.0.255
After this tunnel should definitely come up and if not then for test purpose, remove ZBF configuration from the router.
Just remove zone member from interfaces and you should be good.
As of now, the IPSEC SA output on this router is of no use and there are no encaps/decaps.
Please ensure when you remove ACL and apply it again, it is still linked to the VPN configuration.
Let me know how it goes.
Pulkit
5 Replies 5
Pulkit Saxena
I am unable to open the .pkt file. It should be .pcap to check in wirehsark.
Also, can you please "show run", "sh crypto isakmp" "show crypto ipsec" from ASA and router both ?
Pulkit
Hi Pulkit,
Thank you for your reply.
It's a packet tracer file (.pkt) and i'm using packet tracer version 7.
This is the show run in ASA:
ASA Version 8.4(2)
hostname ciscoasa
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address 1.1.1.2 255.255.255.252
route outside 0.0.0.0 0.0.0.0 1.1.1.1 1
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect icmp
service-policy global_policy global
telnet timeout 5
ssh timeout 5
dhcpd auto_config outside
dhcpd address 192.168.1.5-192.168.1.36 inside
dhcpd enable inside
crypto ipsec ikev1 transform-set VPN-TRANS esp-3des esp-sha-hmac
crypto map CRYPTO-MAP 10 match address SITE
crypto map CRYPT0-MAP 10 set peer 3.3.3.2
crypto map CRYPT0-MAP 10 set ikev1 transform-set VPN-TRANS
crypto map CRYPT0-MAP interface outside
crypto ikev1 enable outside
crypto ikev1 policy 2
encr 3des
group 2
tunnel-group 3.3.3.2 type ipsec-l2l
tunnel-group 3.3.3.2 ipsec-attributes
ikev1 pre-shared-key cisco123
#show crypto isakmp sa in ASA
There are no IKEv1 SAs
There are no IKEv2 SAs
#show crypto ipsec sa in ASA
There are no ipsec sas
R1 #show run:
hostname R1
interface GigabitEthernet0/0
ip address 20.20.20.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 1.1.1.1 255.255.255.252
duplex auto
speed auto
interface Serial0/0/0
ip address 3.3.3.1 255.255.255.252
clock rate 128000
interface Serial0/0/1
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
ip classless
ip route 192.168.1.0 255.255.255.0 GigabitEthernet0/1
ip route 30.30.30.0 255.255.255.0 Serial0/0/0
ip flow-export version 9
no cdp run
logging 20.20.20.10
line con 0
line aux 0
line vty 0 4
login
ntp authentication-key 1 md5 0822455D0A16544541 7
ntp authenticate
ntp trusted-key 1
ntp server 20.20.20.10 key 1
end
R3 #show run:
hostname R3
username Admin1 secret 5 $1$mERr$uvBzTxfWW.Iz063iT95nM.
license udi pid CISCO1941/K9 sn FTX152489OH
license boot module c1900 technology-package securityk9
encr 3des
group 5
crypto isakmp key cisco123 address 1.1.1.2
crypto ipsec transform-set VPN-TRANSFORM esp-3des esp-sha-hmac
crypto map CRYPTO-MAP 10 ipsec-isakmp
description VPN connection to PCA-B
set peer 1.1.1.2
set transform-set VPN-TRANSFORM
match address 122
ip ssh version 2
ip ssh authentication-retries 5
ip ssh time-out 60
ip domain-name ccnasecurity.com
spanning-tree mode pvst
class-map type inspect match-all IN-NET-CLASS-MAP
match access-group 101
class-map type inspect match-all REMOTE-NET-CLASS-MAP
match access-group 122
policy-map type inspect IN-2-OUT-PMAP
class type inspect IN-NET-CLASS-MAP
inspect
policy-map type inspect REMOTE-2-IN-PMAP
class type inspect REMOTE-NET-CLASS-MAP
inspect
zone security INZONE
zone security OUTZONE
zone-pair security IN-2-OUT-ZPAIR source INZONE destination OUTZONE
service-policy type inspect IN-2-OUT-PMAP
zone-pair security REMOTE-2-IN-ZPAIR source OUTZONE destination INZONE
service-policy type inspect REMOTE-2-IN-PMAP
ip address 30.30.30.1 255.255.255.0
zone-member security INZONE
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
ip address 3.3.3.2 255.255.255.252
zone-member security OUTZONE
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/0/0
access-list 101 permit icmp 30.30.30.0 0.0.0.255 any
access-list 101 permit ip 30.30.30.0 0.0.0.255 any
access-list 101 permit tcp 30.30.30.0 0.0.0.255 any
access-list 101 remark INSIDE TRAFFIC GO ANYWHERE
access-list 122 permit icmp 192.168.1.0 0.0.0.255 30.30.30.0 0.0.0.255
access-list 122 permit ip 192.168.1.0 0.0.0.255 30.30.30.0 0.0.0.255
access-list 122 permit tcp 192.168.1.0 0.0.0.255 30.30.30.0 0.0.0.255
access-list 122 remark BEHIND ASA TRAFFIC GO INSIDE
no cdp run
logging 20.20.20.10
line con 0
exec-timeout 3 0
password 7 08124945081026383C5F5E50
login local
line aux 0
line vty 0 4
exec-timeout 3 0
password 7 08124945081033232B5F5E50
login local
transport input ssh
ntp authenticate
ntp trusted-key 1
end
R3 #show crypto isakmp sa:
IPv4 Crypto ISAKMP SA
dst src state conn-id slot status
IPv6 Crypto ISAKMP SA
R3 #show crypto ipsec sa:
interface: Serial0/0/0
Crypto map tag: CRYPTO-MAP, local addr 3.3.3.2
protected vrf: (none)
local ident (addr/mask/prot/port): (192.168.1.0/255.255.255.0/1/0)
remote ident (addr/mask/prot/port): (30.30.30.0/255.255.255.0/1/0)
current_peer 1.1.1.2 port 500
PERMIT, flags={origin_is_acl,}
#pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
#pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0
#pkts not decompressed: 0, #pkts decompress failed: 0
#send errors 0, #recv errors 0
local crypto endpt.: 3.3.3.2, remote crypto endpt.:1.1.1.2
path mtu 1500, ip mtu 1500, ip mtu idb Serial0/0/0
current outbound spi: 0x0(0)
inbound esp sas:
inbound ah sas:
inbound pcp sas:
outbound esp sas:
outbound ah sas:
outbound pcp sas:
local ident (addr/mask/prot/port): (192.168.1.0/255.255.255.0/0/0)
remote ident (addr/mask/prot/port): (30.30.30.0/255.255.255.0/0/0)
inbound esp sas:
inbound ah sas:
inbound pcp sas:
outbound esp sas:
outbound ah sas:
outbound pcp sas:
local ident (addr/mask/prot/port): (192.168.1.0/255.255.255.0/6/0)
remote ident (addr/mask/prot/port): (30.30.30.0/255.255.255.0/6/0)
inbound esp sas:
inbound ah sas:
inbound pcp sas:
outbound esp sas:
outbound ah sas:
outbound pcp sas:
As you can see, only ipsec sa in R3 has something, and the rest is nothing...
It should be
Please do a :
Now on Router 3 :
encr 3des
group 2
Pulkit
Hi Pulkit,
Thank you so much for finding out mistakes that i made. I didn't check enough the IPsec parameters such as aes and diffie-hellman group.
I followed everything you told me, except this ACL:
It's because permit ip (source = any) (destination = any) is like disabling firewall's job. and also firewall by default is letting inside traffic to go outside.
It's working well now and again, thank you for your help :)
I am glad that everything is working fine now.
Yes you are right that by putting "ip any any" is like disabling firewall's job, it was more for test purpose, just to ensure that once we can have the tunnel up. However if we do not have anything on inside, everything is already allowed by default, since it is permitted from high to low.
P.S -- Please rate helpful posts.
Pulkit
