IPSec VPN Help!!
Two directly connected ASA. Their are LAN behind ASA. I have configured NAT,Global and IPSec VPN can anyone check the configuration of these firewalls and find out why am not able to pings LANs from either sides??
ASA1
ASA Version 8.0(2)
hostname ASA1
enable password 8Ry2YjIyt7RRXU24 encrypted
names
interface Ethernet0/0
nameif outside
security-level 0
ip address 10.1.1.1 255.255.252.0
interface Ethernet0/1
nameif inside
security-level 100
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/4
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/5
shutdown
no nameif
no security-level
no ip address
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
access-list 101 extended permit icmp any any echo-reply
access-list 101 extended permit ip any any
pager lines 24
mtu outside 1500
mtu inside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
icmp permit any outside
icmp permit any inside
no asdm history enable
arp timeout 14400
access-group 101 in interface outside
route outside 172.16.1.0 255.255.255.0 10.1.1.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
no crypto isakmp nat-traversal
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
service-policy global_policy global
prompt hostname context
Cryptochecksum:d41d8cd98f00b204e9800998ecf8427e
: end
ASA2
ASA Version 8.0(2)
hostname ASA2
names
nameif outside
security-level 0
ip address 10.1.1.2 255.255.252.0
nameif inside
security-level 100
ip address 172.16.1.1 255.255.255.0
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
ftp mode passive
pager lines 24
mtu outside 1500
mtu inside 1500
no failover
arp timeout 14400
route outside 192.168.1.0 255.255.255.0 10.1.1.1 1
telnet timeout 5
ssh timeout 5
console timeout 0
Cryptochecksum:00000000000000000000000000000000
: end
17 Replies 17
If you want to ping the ASA interfaces via the VPN tunnel, please add the following command on both ASA:
management-access inside
Then test ping from the ASA as follows:
From ASA1: ping inside 172.16.1.1
From ASA2: ping inside 192.168.1.1
Thanks to all of you guys. Finally its working. Normally i was not able to ping from my pc1 behind ASA1 to pc2 behind ASA2. But after giving management-access inside commands on both ASAs its working, why is it so can anyone give me the concept.
By default, you won't be able to ping the ASA interface if the traffic is not originated from that particular interface.
Eg:
if you are trying to ping ASA1 inside interface IP from ASA2 inside interface IP across the VPN, the traffic will arrive at ASA1 outside interface first. You can only ping ASA1 outside interface, but not across towards ASA1 inside interface.
With the "management-access inside" command, it allows that, and only if traffic is originating from VPN, not clear text traffic from the Internet.
Hope that answers your question.
