ISDN problem
ilyaskhan
Community Member
Hi,while configuring ISDN line between 2 sites, i came across a problem regarding the line not coming up. One side has a 2600 series router and the other a 800 series. Ive taken a debug of some commands at the 800 series router side:
Debug dialer events:
6w0d: BR0 DDR: place call
6w0d: BR0 DDR: Dialing cause ip (s=192.168.3.15, d=192.168.0.
6w0d: BR0 DDR: Attempting to dial 065320750
6w0d: BRI0: wait for isdn carrier timeout, call id=0x8B0A
6w0d: BRI0: wait for isdn carrier timeout, call id=0x8B0B
6w0d: BRI0: wait for isdn carrier timeout, call id=0x8B0C
Debug isdn events:
6w0d: ISDN Recvd L1 prim 3 dsl 0 state 0 ctrl_state 0
6w0d: ISDN BR0 EVENT: isdn_sw_cstate: State = 0, Old State = 4
6w0d: ISDN BR0: Physical layer is IF_DOWN
6w0d: ISDN BR0: Could not bring up interface
6w0d: ISDN BR0: Shutting down ISDN Layer 3
6w0d: ISDN BR0: Shutting down ME
6w0d: ISDN BR0: Outgoing call id = 0x8B34, dsl 0
6w0d: ISDN BR0: Event: Call to 065320750 at 64 Kb/s
6w0d: ISDN BR0: process_bri_call(): call id 0x8B34, called_number 065320750, spe
ed 64, call type DATA
6w0d: CCBRI_Go Fr Host InPkgInfo (Len=25) :
6w0d: 1 0 1 8B 34 0 4 2 88 90 18 1 83 70 A 80 30 36 35 33 32 30 37 35 30
6w0d:
6w0d: CC_CHAN_GetIdleChanbri: dsl 0
6w0d: Found idle channel B1
6w0d: ISDN BR0: Activating
6w0d: ISDN BR0 EVENT: isdn_sw_cstate: State = 4, Old State = 4
6w0d: ISDN BR0: LIF_EVENT: ces/callid 1/0x8B34 HOST_DISCONNECT_ACK
6w0d: ISDN BR0: Error: Unfound B-channel on Disconnect_Ack - callid 0x8B34
6w0d: ISDN BR0: Outgoing call id = 0x8B35, dsl 0
6w0d: ISDN BR0: process_bri_call(): call id 0x8B35, called_number 065320750, spe
6w0d: 1 0 1 8B 35 0 4 2 88 90 18 1 83 70 A 80 30 36 35 33 32 30 37 35 30
6w0d:
6w0d: ISDN BR0: LIF_EVENT: ces/callid 1/0x8B35 HOST_DISCONNECT_ACK
6w0d: ISDN BR0: Error: Unfound B-channel on Disconnect_Ack - callid 0x8B35
6w0d: ISDN Recvd L1 prim 3 dsl 0 state 3 ctrl_state 0
6w0d: ISDN BR0: L1 persistent Deactivated
6w0d: ISDN BR0: Outgoing call id = 0x8B36, dsl 0
6w0d: ISDN BR0: process_bri_call(): call id 0x8B36, called_number 065320750, spe
6w0d: 1 0 1 8B 36 0 4 2 88 90 18 1 83 70 A 80 30 36 35 33 32 30 37 35 30
Debug isdn q931:
Any idea about the problem? if required i can get the debug from the 2600 series side as well.
Please refer to below (look for ---Symptom: The ISDN Call does not Connect Successfully)
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_tech_note09186a0080094bb8.shtml
Hope this help:)
MD
6 Replies 6
Richard Burts
It looks to me like the router is having trouble bringing up the interface. The output of show isdn status might be helpful. It would also be helpful if you would post the config (at least all the parts that relate to ISDN).
Rick
Rick
makchitale
Level 11
Level 11
Can you please capture the following on both the routers:
deb isdn q931
deb ppp nego
Thanks, Mak
ilyaskhan
Community Member
Here is a file containing some debug outputs from the HQ 2600 series.I entered the following commands on both sides with respect to isdn configuration:
On the Global Configuration level:
username (Other Side Hostname) password !@#$%
dialer-list 1 protocol ip permit
isdn switch-type basic-net3
On the interface level:
ip address 192.168.100.x 255.255.255.0
encapsulation ppp
dialer map ip 192.168.100.x name (Other side Hostname) (Other side telephone number)
dialer-group 1
ppp authentication chap
no shutdown.
Thats it.Other than this ive added a static route for the destination networks and nothing more. Any ideas??
Hope this help:)
MD
Thanks for sending the file with the debug output.
It looks to me that the show isdn status indicates that things are looking normal on the router.
I think there is a clue about what is happening in the debug isdn q931 output. In particular look at these lines of output:
00:25:47: ISDN BR0/0: RX <- CALL_PROC pd = 8 callref = 0x9C
00:27:00: ISDN BR0/0: RX <- DISCONNECT pd = 8 callref = 0x9D
00:27:00: Cause i = 0x829F - Normal, unspecified
The output just before this has indicated that you placed the call. The first line here indicates that you received a call_proceeding response which is normal in call setup. But the next line indicates that you receive a disconnect.
This leads me to believe that the problem is on the router on the other end of the connection attempt. Could you post similar output from that router (especially show isdn status, debug isdn q931. The output of debug dialer events and debug isdn events might also be useful.
Rick
Rick
ilyaskhan
Community Member
Hi..got the problem solved..after checking all debug and stuff, finally came to know through a LED that line was down from the service provider on the remote side. Once that got fixed, things started working fine from there. thanks for the help.
