LAN to LAN VPN Help
PeterHaase
I'm new to VPN's and I am trying to configure a VPN from our company to another company. I have configure the VPN and it shows as being up. When I am logged into our router I am able to ping a remote address but when I try and ping from my workstation it times out. The VPN is setup from our external IP to the other companies IPsec gateway address. I am using an access list on the VPN as their are 10 encryption domains we need to contact. Internally we use NAT for all our internet traffic. I think I am meant to configure the internal traffic not to use NAT but am unsure if this is correct or how I should be configuring it.
Any help is appreciated.
Peter Haase
5 Replies 5
rizwanr74
Level 7
Level 7
Please post your running config for the tunnel piece, for easier trouble shooting purpose.
thanks
Here is the config for the tunnel
crypto isakmp policy 20
encr aes 256
authentication pre-share
group 2
lifetime 28800
crypto isakmp key xxxxxxxxxx address 198.208.254.1 no-xauth
crypto ipsec transform-set GM esp-aes 256 esp-sha-hmac
crypto map VPNMAP 1 ipsec-isakmp
description Tunnel to198.208.254.1
set peer 198.208.254.1
set transform-set GM
match address GMTeam
crypto map VPNMAP 65535 ipsec-isakmp dynamic DMAP
The GMTeam ACL includes the 10 encryption domains we were given. The crypto map is included on our external interface.
Peter
Check what are permitted in the ACL: GMTeam includes your work-station subnet is included in ACL and be sure to nat-exempt all tunnel-bound traffic from natting.
Let me know, if this helps.
thanks
Thanks for your help, we have the VPN up and running now.
I had a deny entry in the wrong place in one ACL and I needed to nat my workstation IP tomy routers external IP for the ping test to work.
Peter
Peter
It is good to know that you solved your own problem. Thanks for posting back to the forum to tell us that is it fixed and how you fixed it. That may help some other reader of the forum to figure out their own problem.
Rick
Rick
