11-08-2017 08:20 AM - edited 03-12-2019 04:43 AM
Hello All,
I'm working on a solution for a client, whereby they have two two sites, with sub ms connectivity and diverse paths (multiple dedicated fibers/wavelengths taking different physical paths through the city, diverse building entrances, etc...), and would like to migrate to a solution where the two ASA's they have in an active/passive configuration can be split between the locations.
The caveat is that aside from the failover links themselves, they (and I) don't want to stretch the outside/inside subnets between the sites. The original thought was to use a loopback or virtual IP to terminate traffic, and use BGP to advertise that VIP/interface depending on who's active (as BGP will only be active on the active ASA), and maintain config sync and member health using two diverse failover links. Something anycast-"ish"
I realize this is an unsupported/non-standard configuration... but I'm wondering if there is any way to do this.
Limitations I've run into so far
- ASA doesn't support loopbacks
- Because the outside network isn't shared between sites, non-monitored external interfaces on two different subnets would be required
- I tried setting up a same-security-level subnet that is shared between sites, if only for a monitored interface, to terminate VPN traffic on... but I keep getting "unable to find egress interface"
So yeah... Any bright ideas?
11-08-2017 09:24 AM
11-08-2017 09:56 AM
Hi, thanks for the reply and suggestion. Yeah I'd already considered that, however one of the design goals is to not have to manage two separate devices/policies/configurations. Ideally the config is replicated... otherwise yes, using routing makes things much simpler/easier and less restrictive.
On the other hand, while it does make things pretty straight forward with regards to SSL/Anyconnect tunnels... replicating/maintaining 50+ S2S configs/shared keys/etc... could become cumbersome...
Are there any products (cisco or third party) out there that might handle and/or help with this?
