Need help, VPN between 1841 router & PIX 501
bsallison
Trying to setup a VPN between an 1841 router at HQ with static IP connecting to remote office with a PIX 501 and a persistent IP (not static, but Mediacom has mapped PIX MAC this IP so I always get same public IP even on equip reboot). I have configured both sides but tunnel will not come up, must be missing something.
See attached configs.
THANK YOU!
38 Replies 38
Ok but removing access-list should not affect your connection in or out as we will be making the interfaces open for any traffic.
Removed ACL 100 and 101, tried to ping form router side device, no reply.
RainingRose#sho crypt isakmp sa
dst src state conn-id slot status
enable debugs on router and try to capture:
debug cry isa
debug cry ipsec
router shows:
216.203.117.82 12.206.137.5 QM_IDLE 1 0 ACTIVE
PIX shows:
secondstory# sho crypt isakmp sa
Total : 1
Embryonic : 0
dst src state pending created
216.203.117.82 12.206.137.5 QM_IDLE 0 1
But not response to ping traffic from either direction.
your tunnel is UP! Check on the PIX also for
"show crypto isakmp sa" if the tunnel state is QM_idle
Now not able to ping could be a routing issue and not VPN.
Can you also paste "show crypto ipsec sa" outputs
Ok, I am on router side and now I can ping remote device on PIX side.
interface: FastEthernet0/1
Crypto map tag: IPSEC, local addr 216.203.117.82
protected vrf: (none)
local ident (addr/mask/prot/port): (10.2.1.0/255.255.255.0/0/0)
remote ident (addr/mask/prot/port): (10.5.5.0/255.255.255.0/0/0)
current_peer 12.206.137.5 port 500
PERMIT, flags={origin_is_acl,}
#pkts encaps: 12, #pkts encrypt: 12, #pkts digest: 12
#pkts decaps: 30, #pkts decrypt: 30, #pkts verify: 30
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0
#pkts not decompressed: 0, #pkts decompress failed: 0
#send errors 0, #recv errors 0
local crypto endpt.: 216.203.117.82, remote crypto endpt.: 12.206.137.5
path mtu 1500, ip mtu 1500
current outbound spi: 0xE669710B(3865669899)
inbound esp sas:
spi: 0x57AAE66C(1470817900)
transform: esp-des esp-md5-hmac ,
in use settings ={Tunnel, }
conn id: 3001, flow_id: FPGA:1, crypto map: IPSEC
sa timing: remaining key lifetime (k/sec): (4433298/1228)
IV size: 8 bytes
replay detection support: Y
Status: ACTIVE
inbound ah sas:
inbound pcp sas:
outbound esp sas:
conn id: 3002, flow_id: FPGA:2, crypto map: IPSEC
sa timing: remaining key lifetime (k/sec): (4433301/1183)
IV size: 8 bytes
Status: ACTIVE
outbound ah sas:
How do I fix ACL on router, because 100 & 101 are still removed?
Cool you got it working.
you can plug access-list 100 to private interface of router , it does not need any modification.For 101 , i have added to allow esp and udp 500 ISAKMP.
interface FastEthernet0/0
ip access-group 100 in
no access-list 101
no access-list 101
access-list 101 remark auto generated by Cisco SDM Express firewall configuration
access-list 101 remark SDM_ACL Category=1
access-list 101 permit udp host 216.203.122.200 eq domain host 216.203.117.82
access-list 101 permit udp host 216.203.115.234 eq domain host 216.203.117.82
access-list 101 permit tcp any host 216.203.117.83 eq 1494
access-list 101 permit tcp host 66.211.4.130 host 216.203.117.84 eq 1433
access-list 101 permit tcp host 66.211.4.130 host 216.203.117.83 eq 1433
access-list 101 permit tcp host 147.202.24.152 host 216.203.117.84 eq 1433
access-list 101 permit tcp host 147.202.24.152 host 216.203.117.83 eq 1433
access-list 101 permit tcp any host 216.203.117.83 eq ftp
access-list 101 permit tcp any host 216.203.117.83 eq 5360
access-list 101 permit tcp any host 216.203.117.83 eq 5366
access-list 101 permit tcp any host 216.203.117.83 eq 3389
access-list 101 permit tcp any host 216.203.117.83 eq 5365
access-list 101 permit tcp any host 216.203.117.83 eq 5364
access-list 101 permit tcp any host 216.203.117.83 eq 5361
access-list 101 permit tcp any host 216.203.117.85 eq smtp
access-list 101 permit tcp any host 216.203.117.85 eq 389
access-list 101 permit esp any host 216.203.117.82
access-list 101 permit udp any host 216.203.117.82 eq 500
access-list 101 permit tcp any host 216.203.117.85 eq www
access-list 101 permit tcp any host 216.203.117.85 eq 5362
access-list 101 permit tcp any host 216.203.117.85 eq 443
access-list 101 permit ip 10.5.5.0 0.0.0.255 10.2.1.0 0.0.0.255
access-list 101 deny ip 10.2.1.0 0.0.0.255 any
access-list 101 permit icmp any host 216.203.117.82 echo-reply
access-list 101 permit icmp any host 216.203.117.82 time-exceeded
access-list 101 permit icmp any host 216.203.117.82 unreachable
access-list 101 deny ip 10.0.0.0 0.255.255.255 any
access-list 101 deny ip 172.16.0.0 0.15.255.255 any
access-list 101 deny ip 192.168.0.0 0.0.255.255 any
access-list 101 deny ip host 0.0.0.0 any
access-list 101 deny ip any any
interface FastEthernet0/1
ip access-group 101 in
check and post results
Saju
Pls rate helpful posts
OK, I can ping both directions. Routing issue, 10.2.1.6 (router side) has a static NAT, I can not ping this device from remote side nor access the Exchange stuff on that box. I am guessing static NAT is the related to the issue.
Ideas?
Brian,
First of all do not forget to rate me :)
As for static NAT is concerned . you can create another access-list entry in crypto acl for it both sides.
since it being NAT'ed to 216.203.117.85 .
Add acl entry
access-list 111 permit ip host 216.203.117.85 10.2.1.0 0.0.0.255 10.5.5.0 0.0.0.255
and mirror image of this on the PIX .
DOes not like the ACL cmd, marker at the 10.5.5.0 character.
Corrected!try now
On Router
access-list 111 permit ip host 216.203.117.85 10.5.5.0 0.0.0.255
On Pix
access-list 111 permit ip 10.5.5.0 255.255.255.0 host 216.203.117.85
OK, I can ping from PIX side to 10.2.1.6, though it says reply is from 216.203.117.85.
I can ping from the 10.2.1.6 device to remote devices on PIX side.
10.2.1.6 (216.203.117.85) is my Exchange server and does DNS for my domain. I should be able to go https://shampoo/exchange & bring OWA or use https://10.2.1.6/exchange, but neither work. As you can see from config, PIX is giving off DHCP addresses to client workstation & handing out 10.2.1.6 as Pri DNS server, but I don't think that is working?
Little more help.....
how about
https://216.203.117.85/exchange
Does this work?
Yes, that works. But how do we know that went across VPN versus across regular Internet?
Are you suggesting I change the DNS server given off by PIX DCHP, be that .85 address?
I just want to make sure that address is being reached across VPN.....
To check that , can you post "show crypto ipsec sa" from PIX pls.?
