Not able to configure serial interface for dialout using external modem
kapoors
I have 2610 and i want dialout to Cisco RAS PRI using serial interface on which external modem is connected
makchitale
Level 6
Level 6
What type of serial interface do we have here? Async serial or sync serial? Also what type of external modems do we have here?
I would assume you have a async external modem & need to connect the same to an asyn port on the 2600, a similar config is seen below (he modem is connected to aux port for dialout)
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a0080094579.shtml
If you have an async/sync module then inorder to make it asyn will need to add the command "physical-layer async"
conf term
interface serial x
Thanks, Mak
kapoors
I have sync serial interface and DLINK modem.
The modem connections and cables are ok , i have tested by reverse telnet.
It is still not working , i am getting any output of debug chat for dial out
Sorry for the bad news but a synchronous serial port can not communication with a asynchronous modem. You must use a asychronous port. I'm not for sure wether the 2610 as both A/S port.
Bill
