Phase I problem between two 3030 concentrators.
jkeeffe
Level 7
Level 7
I'm setting up a IPsec tunnel between two 3030's and get these errors in the log when I try to bring up the tunnel (I've x'd out the tunnel peer).
1041 03/15/2005 12:14:20.650 SEV=9 IKEDBG/1 RPT=14421 xxx.xxx.xxx.xxx
Group [xxx.xxx.xxx.xxx]
constructing ID
1042 03/15/2005 12:14:20.650 SEV=9 IKEDBG/0 RPT=56569
Group [65.219.190.253]
construct hash payload
1043 03/15/2005 12:14:20.650 SEV=9 IKEDBG/0 RPT=56570 65.219.190.253
computing hash
1045 03/15/2005 12:14:20.650 SEV=9 IKEDBG/46 RPT=29137 65.219.190.253
constructing dpd vid payload
1050 03/15/2005 12:14:20.680 SEV=4 IKE/0 RPT=38438 65.219.190.253
received an unencrypted packet when crypto active!! Dropping packet.
1095 03/15/2005 12:14:28.680 SEV=6 IKE/201 RPT=785 65.219.190.253
Duplicate Phase 1 packet detected. Retransmitting last packet.
1100 03/15/2005 12:14:28.710 SEV=6 IKE/201 RPT=786 65.219.190.253
1132 03/15/2005 12:14:28.740 SEV=6 IKE/201 RPT=787 65.219.190.253
1134 03/15/2005 12:14:28.740 SEV=7 IKEDBG/65 RPT=30987 xxx.xxx.xxx.xxx
IKE MM Initiator FSM error history (struct &0x7ccb670)
<state>, <event>:
MM_DONE, EV_ERROR_CONT
MM_DONE, EV_ERROR
MM_WAIT_MSG6, EV_RESEND_MSG
MM_WAIT_MSG6, NullEvent
1139 03/15/2005 12:14:28.740 SEV=9 IKEDBG/0 RPT=56584
xxx.xxx.xxx.xxx
IKE SA MM:fa5b509f terminating:
flags 0x0100c022, refcnt 0, tuncnt 0
What could cause these PHASE I error messages?
sachinraja
Level 11
Level 11
Hi. make sure all the phase I parameters are configured correctly.. this can happen due to any mismatch in phase 1 parameters like hash, encryption, lifetime, authentication method, key exchange.. these are the phase 1 values entered at each end.. make sure the configs both the end are identical.. also make sure the crypto ACLs are same both the ends...
Raj
