Pls Help me, DHCP and RoTS only work for one Vlan
yaakov
Community Member
I have been trying to set up a RoTS/DHCP server on a router to provide inter-vlan routing/DHCP server services to two vlans:
Here is my coding, bear in mind this is only for the left side of LAN 1, the other side is pretty much the same. I can only get vlan 10 to get dhcp leases. Vlan 20 gets an apipa address:
Switch(config)#vlan 10
Switch(config-vlan)#name 10
Switch(config-vlan)#exit
Switch(config)#vlan 20
Switch(config-vlan)#name 20
Switch(config)#int range fa0/1-2
Switch(config-if-range)#switchport mode access
Switch(config-if-range)#switchport access vlan 10
Switch(config-if-range)#exit
Switch(config)#int fa0/5
Switch(config-if)#switchport mode access
Switch(config-if)#switchport access vlan 20
Switch(config-if)#exit
Switch(config)#int g0/1
Switch(config-if)#switchport mode trunk
Switch(config-if)#
%LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to down
%LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to up
Switch(config-if)#switchport trunk allowed vlan 10,20
Switch(config-if)#
Switch(config-if)#
Router>en
Router#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#int g0/0/0
Router(config-if)#no sh
Router(config-if)#
%LINK-5-CHANGED: Interface GigabitEthernet0/0/0, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to up
Router(config-if)#exit
Router(config)#int g0/0/0.10
Router(config-subif)#
%LINK-5-CHANGED: Interface GigabitEthernet0/0/0.10, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0.10, changed state to up
Router(config-subif)#encapsulation dot1Q 10
Router(config-subif)#ip add 192.168.10.1 255.255.255.0
Router(config-subif)#exit
Router(config)#ip dhcp excluded-address 192.168.10.1 192.168.10.10
Router(config)#ip dhcp pool 10V96SP
Router(dhcp-config)#network 192.168.10.0 255.255.255.0
Router(dhcp-config)#default-router 192.168.10.1
Router(dhcp-config)#dns-server 172.19.0.110
Router(dhcp-config)#domain-name yaakovrimon.com
Router(dhcp-config)#exit
Router(config)#int g0/0/0.20
%LINK-5-CHANGED: Interface GigabitEthernet0/0/0.20, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0.20, changed state to up
Router(config-subif)#encapsulation dot1Q 20
Router(config-subif)#ip add 192.168.20.1 255.255.255.0
Router(config)#ip dhcp excluded-address 192.168.20.1 192.168.20.10
Router(config)#ip dhcp pool 20V96SP
Router(dhcp-config)#network 192.168.20.0 255.255.255.0
Router(dhcp-config)#default-router 192.168.20.1
Router(config)#
Router#
%SYS-5-CONFIG_I: Configured from console by console
0 Replies 0
