Problem with 1710 and VPN client 3.6
jeffhunter100
I am having trouble with this configuration. I can create the tunnel ok, but from the client I can not ping to devices on the lan (ex 192.168.0.20) or the inside interface of the router (192.168.0.1) or vice versa.
I have tried about 1000 variations of this and I am still not getting anywhere. Any ideas.....
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
aaa new-model
aaa authentication login userauthen local
aaa authorization network groupauthor local
aaa session-id common
enable password xxxxx (moderator edit)
username xxxx password xxxxxx (moderator edit)
memory-size iomem 25
ip subnet-zero
no ip domain-lookup
ip audit notify log
ip audit po max-events 100
ip ssh time-out 120
ip ssh authentication-retries 3
crypto isakmp policy 3
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group 3000client
key cisco123
dns 14.1.1.10
wins 14.1.1.20
domain cisco.com
pool ippool
crypto ipsec transform-set myset esp-3des esp-sha-hmac
crypto dynamic-map dynmap 10
set transform-set myset
crypto map clientmap client authentication list userauthen
crypto map clientmap isakmp authorization list groupauthor
crypto map clientmap client configuration address respond
crypto map clientmap 10 ipsec-isakmp dynamic dynmap
interface Ethernet0
description connected to Internet
ip address 200.0.0.1
no ip proxy-arp
ip nat outside
half-duplex
interface FastEthernet0
description connected to EthernetLAN
ip address 192.168.0.1 255.255.255.0
no ip proxy-arp
ip nat inside
speed auto
ip local pool ippool 192.168.1.100 192.168.1.200
ip nat inside source route-map nonat interface Ethernet0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 200.0.0.2
no ip http server
ip pim bidir-enable
access-list 101 deny ip 192.168.0.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 101 permit ip 192.168.0.0 0.0.0.255 any
route-map nonat permit 10
match ip address 101
line con 0
session-timeout 3
exec-timeout 0 0
password 7 13161F1D1B1C013838
line aux 0
line vty 0 4
session-timeout 3
password 7 10440C1F03
no scheduler allocate
end
ajagadee
How is the client connecting to the internet.
Once the client makes a successful connection and try to access something on the 192.168.0.x/24, can you look on the client statistics to see if the packets are getting encrypted or not. And if they are encyrpted, Look at the IPSec SA on the router to see if the router is decyrpting the packet and this should point you in the right direction.
Arul
Thanks Arul,
I checked that initially, it basically looked like packets would not encrypt from either side. I just figured this out about 10 minutes ago. I upgraded my IOS in the 1710 to the latest and it now works.
